Gauges
Hi-Hilux
Town: Tsumeb
Vehicle: 1991 Hilux2.2 ---1987 Hilux D/C Hella 1000, Rancho RS9000XL shocks, Good Year M/TR, Warn Winch, STK bullbar, Extended shacles, Kenwood VHF-SOLD
Real Name: Trevor
Gauges
Post by Hi-Hilux »
As jy drie van die ronde gauges in jou lux moes sit, wat is die 3 belangrikstes wat jy sou in sit? Ek praat van die volt, amp, olie druk, olie temp en water gauge goed. Weet nie wat mens alles kry nie, dink daar is n vacuam een ook
Re: Gauges
Oil pressure .... for obvious reasons.
Water temp ...... also for obvious reasons
Amps ..... If the ally stops charging it could be an indicator that you've lost a fan belt. Very often this drives the water pump as well so it acts as an early warning. If the charge rate drops, one of the diodes is probably blown, but at least you will know in advance to conserve battery power and not run lights / wipers / climate control / radio unnecessarily.
M2CW
Re: Gauges
Post by CasKru »
Mud Dog wrote:Oil pressure .... for obvious reasons.
M2CW
I second this :shifty: :shifty:
