ThisLED Bar has its own built in on/off switch. The LED strip is mounted in a aluminum casing with two mounting brackets.
It has a total of 18x 5mm LEDs (5050 SMD). The front is covered with a silicon layer which makes it splash proof and easy to clean
Connects directly to the vehicles 12 Volt DC
Ideal for trailers, caravans, off-road vehicles and even shacks.
Like most of my products this is our popular no name brand imported from China. We could add a name and fancy packaging at an extra R150.00, but decided against it.
188 mA
2.4 Watt
L=330mm - W=17mm - H=10mm
You can buy it online at
http://www.4x4direct.co.za/shop/index.p ... cts_id=101
Aluminium LED bars from R80.00 each
Re: 330mm LED bar with 18x LEDs
This is so cheap the advert should say SVNL 21.....
Pieter gaan nou mos 'n hart-aanval kry....
Maar hoe meen meneer nou?OOOOMS wrote:This is so cheap the advert should say SVNL 21.....
Ek dink die ouens se goed is baie overrated....wou ma net ook noem...
http://www.foxandsons.co.za/LED%20Strip ... umeno.html" onclick="window.open(this.href);return false;
En hulle goed is vreeeek duur....
Re: Aluminium LED bars from R80.00 each
I received new stock of the Aluminium LED Bars
I now have:
6 LED bars - R80.00
12 LED bars - R110.00
18 LED Bars - R140.00
All have a built in switch:
See http://www.4x4direct.co.za/shop/index.p ... x&cPath=15
I also have a nice LED bar of which the head can swivel 180 degrees. I know the guys with yacht use the same thing.
It sells for R250.00 each
See http://www.4x4direct.co.za/shop/index.p ... cts_id=220
I now have:
6 LED bars - R80.00
