Headlight problems
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
Headlight problems
I bought my 4.0 V6 second-hand with spots, but these have not worked since I got it. I went to a spares shop to have the relay checked, where someone assisted me in testing it. The new relay made no difference, so we left it as is, but ever since, my one headlight only gives 'park', a very week dim, and an even weaker bright. We replaced the bulb, with the same results. Did we damage something, or does it rather sound like a weak connection, or earth problem?
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Re: Headlight problems
Jarus, seems like a poor earth or wiring damaged, have it checked out asap, you could even run a risk of major damage
- oxydog
- Real Name: Jarus
Thanks Mark, I'll have the guys at LAS have a look at it while they're installing the tank and slider tomorrow. They have an auto-electrician on site.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
could be something samaal but rather not risk causing any further potential damage.oxydog wrote:Thanks Mark, I'll have the guys at LAS have a look at it while they're installing the tank and slider tomorrow. They have an auto-electrician on site.
When fiddling with the fuse you might have cause a short over the relays energising circuit when switching on the head lights.oxydog wrote:Thanks Mark, I'll have the guys at LAS have a look at it while they're installing the tank and slider tomorrow. They have an auto-electrician on site.
- oxydog
- Real Name: Jarus
We didn't actually go near the fuses, as the lights were still working, and the headlights are on the same live, so no extra fuses. We've eventually completely bypassed the relay, and the problem remains.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Where does the spotlight relay get it's switching power from? Is it a factory-fit or a aftermarket home installation? It could be that there is a bum connection there....
- oxydog
- Real Name: Jarus
Looks like an aftermarket job. I'll have them redo everything tomorrow.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Sorry man.. .meant to say relay.oxydog wrote:We didn't actually go near the fuses, as the lights were still working, and the headlights are on the same live, so no extra fuses. We've eventually completely bypassed the relay, and the problem remains.
With Toyota you have to keep in mind that it's negative switching unlike some other brands
- oxydog
- Real Name: Jarus
Think I feel comfortable leaving it in the hands of the professionals. Thanks for all the info, guys.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
I think Thys is "spot on' If those after market spots are wired from the same circuit as the headlights; rewire it. The only shared connection with the existing harness will be the low beam connection that can be used as a positive for the spot relay's coil.ThysdJ wrote:Where does the spotlight relay get it's switching power from? Is it a factory-fit or a aftermarket home installation? It could be that there is a bum connection there....
In other words, when brights on, the low beam connection will become positve when the 'earth is removed' from that point & the bright filament is earthed by the stalk switch. If your headlights are the ones with 3 connectors that is...
Edit: made a mistake on the common connection (it is actually hooked up to the 12V line); rectified above....see below from another topic
On my Ltd (22R), the headlight contacts are as viewed from the back of the headlight:
left: common between high & low beam; connected to 12V through relay from fusebox
top: low beam, this point is earthed when lights are switched on
right: high beam; this point is earthed when brights are switched on (think it's red/yellow)
- oxydog
- Real Name: Jarus
Stefan, do you think the guys at LA Sport will wire it like that, or should I explicitly request that they do?
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Can't say for sure; think it's best to tell them what you want...more than likely they'll comply or just dicuss the preferred/best method.oxydog wrote:Stefan, do you think the guys at LA Sport will wire it like that, or should I explicitly request that they do?
The method I mentioned above is the way the factory fitted spots on my LTD are wired, that's how I know.
Check this topic where I did some testing viewtopic.php?f=3&t=11692&hilit=97+SFA+headlamp
I also have a drawing somewhere, not sure if I uploaded to another topic, but the post will explain how the setup works.
As Cassie and Stef says, wiring spotlights on a Hilux is a tricky business. Hilux headlights switch on the earth, not on the live, therefore you need to know what you're dealing with to get it to work right. It has been discussed a lot on the forum, and IIRC there is an article about it too with pictures, wiring diagrams etc etc...
here you go... http://www.hilux4x4.co.za/wire_spotlights/index.php" onclick="window.open(this.href);return false;
- oxydog
- Real Name: Jarus
OK, I'll make sure they understand what is expected before I hand over the truck.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
