Garmin Quest II SA External Antenna
Does anybody in the CT area have an external antenna for a Quest 2 that i can use for trouble shooting? Mine decided not to acquite satelites any longer and I want to see if an external antenna will work.
Re: Garmin Quest II SA External Antenna
Thys, jy sukkel nou mos nou al lank met die Quest 2 (ek dink dis no presies 'n jaar.... ), gaat gooi daai ding nou eens en vir altyg op jou kroeg se rak. viewtopic.php?f=102&t=19966&hilit=garmin+quest" onclick="window.open(this.href);return false;ThysdJ wrote:Does anybody in the CT area have an external antenna for a Quest 2 that i can use for trouble shooting? Mine decided not to acquite satelites any longer and I want to see if an external antenna will work.
Seems like you are attached to it...... :roll:
Ek sukkel nie met hom nie, ek wil net weet of hy nou uiteindelik regtig ISM is. Anyway, makie sakie, hy het weer begin werk. Hy doen diens in die Blou Limo as 'n speedo en trip-logger..
Ek moet se hy is nogals sterk.. het hom so bietjie rondgeklap en so 2 keer laat val en toe werk hy weer..
Gaaf, praat weer, same time next
