I've researched power management systems for my trailer, and this seems to be current king of the hill.
Do you guys think there is maybe something better?
HPP1 MK3c
R 4250.00
HCdP Power Panel MK3c with NEW 180W Solar Panel Charger
Product Features
220VAC to 12 Volt 12 Amp 3-state (constant current, constant voltage & float charge)Lead-Acid Battery Charger with Fast and Trickle charge indicator
Unique DC to DC 12V 12 Amp Charger (no need for a separate dual battery switch)
Optional 300W 230VAC modified sine wave inverter
Auto DC charger bypass when charging from vehicle (full 12A available to charge battery while fridge etc. runs directly from vehicles alternator)
DC to DC charger has auto ON and OFF vehicle voltage sensing switch
Battery under voltage lockout to prevent deep cycling and damage to battery
Integrated 180 Watt Solar Charge Controller
Integrated Battery Voltage Monitor
LED charge source indicator
Integral thermostatically controlled cooling fan
Integrated 220VAC Earth Leakage unit and overload Circuit Breaker.
1x 3-pin SA and 1x EURO 220VAC output sockets
Can operate from any combination of 220VAC, Battery or Solar Panel
Short circuit protection on all outputs
Supplied with mounting hardware
Supplied with all connectors required
Easy to install
http://www.hcdpelectronics.co.za/" onclick="window.open(this.href);return false;
Best power management system? HPP1 MK3c
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
- HPP1 MK3 Top View LR.jpg (11.83 KiB) Viewed 1716 times
Know what you don't know.
- tersmit
- Town: Durbanville Cape Town
- Vehicle: '06 Hilux 4x4 4.0 Auto D/C, 185a/h Dual Battery Sistem, 1500w inverter
- Real Name: Tertius
Re: Best power management system?
I think this is an awesome product !!
- Town: Springs
Re: Best power management system? HPP1 MK3c
Ok, so it has been fitted to my trailer for about a month or two.
Used it on two trips now, and I must say that I have never had a more convenient and reliable way of managing power. You either just need to be plugged into the vehicle or a 220V power point. It is fitted with an AC/DC charger and DC/DC charger. No need to change plugs for your fridge, or to connect it separately; since it has a transformer it will still run your fridge on 12V even when you are connected to 220V.
When you get home you just flip one switch and nothing will drain the battery, you can even leave it on the charge function.
Probably the single best addition to my trailer.
