Choosing a Dual Battery System
oxydog
Vehicle: '98 Hilux SFA 2.8D 4X4 D/C, '06 Hilux 4.0 V6 4X4 D/C
Real Name: Jarus
Club VHF Licence: J67
Post by oxydog »
Hi Hiluxers,
We'll be installing a DBS in the Vigo within the next week or two and I would like some opinions on these:
T-Max solenoid system
CTek DC to DC
National Luna
What is important to me, is that the battery must be fitted under the bonnet.
Thanks guys
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
BenRich
Vehicle: Hilux 4.0 V6 4x4 BF Goodrich KM2 MT Old Man Emu Suspension, ONCA Rocksliders, Safari Snorkel, Stofpad Bashplate's National Luna Duel Battery System, Engel Fridge
Real Name: Bennie
Re: Choosing a Dual Battery System
Post by BenRich »
I also drive a VIGO and went the NL way about three weeks ago. I also wanted the battery under the bonnet as there is enough space available. Very happy so far :thumbup:
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
Deep cycle, high cycle or cranking battery? The battery you are going to use will determine what charging system you are going to fit for the system to perform optimally.
Solenoid on a deep cycle is not really going to work 100% as the alternator doesnt have enough vooma to charge the D/C battery fully. And a semi-charged D/C battery is as good as almost no battery.. DC/DC is the answer here as it steps up the charging voltage to suit the D/C battery's requirements..
For the other types of batteries (quick charging) the solenoid (either T-Max or N/L) will be sufficient...
oxydog
Real Name: Jarus
Post by oxydog »
BenRich wrote:I also drive a VIGO and went the NL way about three weeks ago. I also wanted the battery under the bonnet as there is enough space available. Very happy so far :thumbup:
Thanks Bennie - that's what I have on the SFA. Also very happy, just lost my battery a while ago because it stood in the garage for too long without being charged - not the NL DBS's fault though.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
ThysdJ wrote:Deep cycle, high cycle or cranking battery? The battery you are going to use will determine what charging system you are going to fit for the system to perform optimally.
Hi Thys - Thanks, that is exactly why I love this forum so much - honest, sensible answers within minutes. I suspect we'll be going for a deep cycle again, so it sounds like a DC/DC is the way to go!
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Post by Johan Kriel »
+1
However, deep cycle and DC to DC charger is a bit more expensive but the battery will last longer especially with a larger fridge, that will discharge the battery deeper. With a small fridge one may get away with a high cycle battery and solinoid sytem which is much cheaper.
High cycle charged a bit quicker than a deep cycle also, but the AGM and lead crystal deepcycles do also charge much quicker than the lead acid deepcycles and can be discharged much deeper without ruining the battery.
Johan Kriel
Legend 50
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Thys is SPOT ON !! :)
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Post by Haboob »
Chris, Did you find out how to connect the battery monitor to the D 250 S ?
HABOOB means "Dust Storm"
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
nope.
I use the indicator on the NL fridge, so I have not looked any further into this.
I do have a multimeter in Elders if I want more accurate readings ...
Traveler
Vehicle: Pathfinder 2.5 LE AT
Real Name: Heinrich
Club VHF Licence: X81
Post by Traveler »
Are you guys aware that a DC/DC charger under the bonnet reduces charge as the temperature increases??
So you are driving along under the impression that your battery is charging with the expensive toy under the bonnet doing its work?? But as the temp increases which can easily exceed 60DegC your charger is protecting itself and you are getting less charge to the battery...... Consider that you maybe should mount the charger inside the cab behind the dash and still have your battery inside the engine bay.
As Thys and Bennie states, DC/DC over time is better for that expensive Deep Cycle battery. The other advantage of DC/DC is you do not need to run very expensive thick gauge cable. This charger will be high on my list of options, if not option number 1: http://www.hcdpelectronics.co.za/print_ ... od=DCDC30A" onclick="window.open(this.href);return false; it also comes with input for a future solar panel.
I had a NL Solenoid for years and it gave me excellent service without complaints, and I can recommend it.
Know what you don't know.
Aquanaut
Town: Durban
Vehicle: Hilux 3.0D4D
Real Name: Basil
Post by Aquanaut »
I have a NL system fitted to my vehicle, battery is situated in the load bin and is portable if I need to remove it at a camp site. I have a 105amp Deep Cycle battery which runs my Engel fridge/Freezer, I have had no problems with mine.
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
I use 658 batteries instead of deepcycles, my previous one lasted 6 years and had no charging problems, replaced it with a 115A deep cycle and had to throw it out in less than a year, back on the 90A 658 again, but i will add the solar panel on my next trip.
aev@iburst.co.za
oxydog
Real Name: Jarus
Post by oxydog »
Hey, got it installed (eventually). Decided in the end to go for the Luna system with a Deltec deep cycle. Very professional job done by LA Sport. Watch thread for pics.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
I asked them to fit 2 Hella plugs. You never know!
Plugs in the back, next to ammo boxes.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
The battery fits nicely under the bonnet, directly behind the right headlamp.
Battery inside engine compartment.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
The controller is also under the bonnet. On recommendation from the guys at LA Sport, I decided to also fit an isolator switch. This way, I can quickly disconnect the deep cycle when not in use.
Controller and isolator switch next to firewall.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
In my SFA, I had my inverter connected with lugs to the secondary battery in the load bin. This is a problem when you want to charge cell phones in bad weather. Fitted a Brad Harrison plug to the inverter, and a connector under the passenger seat. Much better.
Brad Harrison plug under passenger seat.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
oxydog
Real Name: Jarus
Post by oxydog »
Inverter as seen from the rear seat. This is a HUGE inverter (1500W), but still fits nicely under the seat.
Inverter as seen from back.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Racing snake
Town: Randburg
Vehicle: Fortuner
Real Name: Brian
Post by Racing snake »
Hi Jarus,
What was the total cost for the N/L system with the deep cycle battery?
oxydog
Real Name: Jarus
Post by oxydog »
Racing snake wrote:Hi Jarus,
Around R 5k, which included 10% discount because we got the quote on their expo day (5 May 2013). This also included all labour, the 2 Hella plugs, the Brad Harrison plug, the isolator switch and all cabling.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
BenRich
Real Name: Bennie
Post by BenRich »
Nice job. Jy sal nie spyt wees nie
Donkey
Town: Johannesburg
Club VHF Licence: X122
Post by Donkey »
Jarus, is that a HcDP dc/dc charger? Personally I would have mounted it in the cab where it can stay dry, one dep water crossing will damage that unit. Just my 2cw :think:
Tumelo Maketekete
oxydog
Real Name: Jarus
Post by oxydog »
Donkey wrote:Jarus, is that a HcDP dc/dc charger? Personally I would have mounted it in the cab where it can stay dry, one dep water crossing will damage that unit. Just my 2cw :think:
Yes it is, and I'm well aware of the fact that it must be kept dry. I will never make such deep crossings with this truck, that's what the SFA is for! :thumbup:
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
subok
Town: Jhb - Somerset West
Vehicle: Hilux 3.0 D4D 4x4 D/C - Kitted for overlanding
Real Name: Kobus
Club VHF Licence: HC152
Post by subok »
Nice job!
Aquanaut
Town: Durban
Real Name: Basil
Post by Aquanaut »
just returned from our Botswana trip, kms of off road crawling in thick sand and dust, camped in places that hasn't seen a power plub in it's life, yet my Engel 40l fridge/freezer remained at -22 degrees through out the whole trip, my 105amp deep cycle battery performed well over three days without charging from the vehicle. When we did drive, we were on the move for at least 5 hours, enough to fully charge the battery for the next 2 or 3 days with out elctricity.
Not once did the battery indicator led's drop into the red, always about two yellows above the red lights.
Frozen meat alll the way, even lost a couple of beers because I forgot to take them out in time, pity!!
I was impressed with the National Luna.
oxydog
Real Name: Jarus
Post by oxydog »
Aquanaut wrote:just returned from our Botswana trip, kms of off road crawling in thick sand and dust, camped in places that hasn't seen a power plub in it's life, yet my Engel 40l fridge/freezer remained at -22 degrees through out the whole trip, my 105amp deep cycle battery performed well over three days without charging from the vehicle. When we did drive, we were on the move for at least 5 hours, enough to fully charge the battery for the next 2 or 3 days with out elctricity.
Sounds great! Just got back from Punda Maria camping trip without electricity - also no hassles.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Ali3n
Club VHF Licence: B338
Post by Ali3n »
Hoekom het jy ‘n isolator switch ingesit? Dis mos hoekom die split charging sisteem daar is….nie waar nie?
PRESENTLY DISADVANTAGED
oxydog
Real Name: Jarus
Post by oxydog »
Ali3n wrote:Hoekom het jy ‘n isolator switch ingesit? Dis mos hoekom die split charging sisteem daar is….nie waar nie?
Ek bly 1 km van die werk af. Deep cycle laai nog nie eers as ek by die werk aankom nie.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
