LED Bars
Thu May 30, 2013 1:24 am
Often the simplest ideas are the best. A few days ago I saw this in a posting by Edge .......
Edge wrote:I have a double row of about six LED's on a piece of aluminium flat bar with a hook bent on the one end, with two stoppers on the one side over which I can then wind about 10 meters of flex cable. I use this as an extension lead for light near the braai fire or light around the camp. It also can be hooked over a tree branch or onto the support of the awning.
....... and being practically minded (at least, I like to think so), I thought the idea had a lot of merit. Looked at the alu that I had and decided it was going to be easier to use some 12 x 2mm flat steel bar, than cut strips of alu. Bent the hooks after drilling a hole so that it could hang on a nail / screw as well. Washed the strips off in phosphoric acid, rinsed, dried and treated with anti-rust before painting.
Made up a couple 30mm lengths of Bright LED strips (I have stock that I got from Pieter) and glued them to the metal strips.
Walla! Easy 12v camping / utility lights! They are lightweight, don't take up much space and will run for days off a small 8a/h motorised gate battery. (Will put them to the test next weekend.)
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Club VHF Licence: HC105
Thu May 30, 2013 6:55 am
Very cool idea,i like :thumbup:
Scout motto:be prepared....
www.4x4direct.co.za
Email: neil@4x4direct.co.za
Stubs
Town: Onrusrivier Hermanus
Vehicle: 89, Hilux D/cab 3.0L V6 Ford !!
Real Name: Stuart
Thu May 30, 2013 8:12 am
now thats cool Andy, you havent patented it yet....hehehe, but no seriously very simple but clever way to utilize the LED strips.....I like
Thu May 30, 2013 8:39 am
That is very nice Andy. Will work very well for many things, even when working on the vehicle
Thu May 30, 2013 9:01 am
Edge's idea, not mine. :D:
Thu May 30, 2013 9:17 am
Your idea has just given me an idea for the braai....
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Thu May 30, 2013 2:43 pm
simple & practical :thumbup: I'll use that one for the tent the upcoming long WEnd...with permission...
Thu May 30, 2013 7:45 pm
Stef wrote:simple & practical :thumbup: I'll use that one for the tent the upcoming long WEnd...with permission...
:lol: :lol: ................. and if I said "No" ? :twisted: ;-)
Thu Feb 12, 2015 8:21 am
After posting this thread, I made a few more of these 'camping' lights (6 in total) and used them often - no good being stuck away in a box and find that the batteries have gone south after an extended period of not being charged.
I used them on outings, hunting trips and even around the house with load shedding before I did the permanent solar PV panel thing. Even used them just for the sake of saving electricity, but didn't save that much - the batteries were still being charged from mains.
Anyhow, the purpose of this post is a warning to anyone that has used the idea and made their own similar units.
With the regular packing and unpacking the connection at the LED strip took some strain and unbeknown to me started arcing under the heat shrink. This is what happened .....
Luckily it didn't start a fire!
At the time I made these units I glued the heat-shrunk ends to the bar to prevent this. It's not good enough!
I have now re-done the units with a slightly longer 'overlap' of the base metal and secured the connection end with a small cable-tie so that there can be no movement.
george
Vehicle: Prado 90 VX 3.4 V6
Club VHF Licence: HC107
Thu Feb 12, 2015 8:26 am
Maybe add a in-line fuse.
Thu Feb 12, 2015 8:35 am
george wrote:Maybe add a in-line fuse.
Also an option, but would the fuse blow if the heat build up is from an arcing connection and not a short? I think not. Stabilizing the connection so that it cannot work loose would be the main solution IMO. :think:
I examined it carefully before and during the 'clean-up' and it had not made contact with the base metal and also didn't appear to have shorted out, but certainly a fuse would still be a good idea in any event. ;-)
Hangover
Town: Deneysville
Real Name: Stef
Thu Feb 12, 2015 8:50 am
Nou moet ek weer vanand garage toe....
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
Thu Feb 12, 2015 8:52 am
Better safe than sorry. :D:
Masekind
Town: Lichtenburg
Vehicle: 2005 Hilux 4x4 v6, LR tank, ARB Bumper. (iJzer)
Real Name: Drikus
Thu Feb 12, 2015 9:33 am
Baie nice idee sal ook soe iets moet doen dankie
Vlak vark
Town: Phalaborwa
Sat Feb 14, 2015 6:30 pm
ek het n 2 meter pvc pyp wat split een kant n meter strip op wat met cable ties vas is. na die koneksie het ek n s in die draad gemaak en met n cable tie vasgemaak sodat die koneksie nie kan los kom nie al haak jou voet die draad. werk soos n bom. maak die yster langer en sit n cable tie op.
Dis basies wat ek gedoen het deur die LED strip bietjie op te skuif. ;-)
louis fourie
Club VHF Licence: X101
Sun Feb 15, 2015 6:07 am
Vlak vark wrote:ek het n 2 meter pvc pyp wat split een kant n meter strip op wat met cable ties vas is. na die koneksie het ek n s in die draad gemaak en met n cable tie vasgemaak sodat die koneksie nie kan los kom nie al haak jou voet die draad. werk soos n bom. maak die yster langer en sit n cable tie op.
Wat van 'n foto of twee. Dan kan ons dom ouens ook vestaan:oops:
Vlak vark
Town: Phalaborwa
Sun Feb 15, 2015 3:52 pm
Louis, ek is ongelukkig in nelspruit in die hospitaal met my suiker. sodra ek uitkom vat ek n kiekie of twee vir jou :thumbup:
Town: Bellville
Vehicle: Langpad (RAV4)
Sun Feb 15, 2015 5:04 pm
ek cable tie die draad na die LED ook vas aan die yster :)
GEEN beweging op die soldeersel.
ANDER idee - daai magnetiese signs wat die manne so op die kant van n voertuig plak - kry van dit en sny dit in strokies. Plak die LED strip op dit. Die magneet sit mos vas teen die voertuig se staal :) MAKLIK om die lig te skuif tot waar jy hom wil hê :)
kry sommer van die nuwe 12 LED ligte by 4x4Direct :) :) Wit en GEEL :) :) :)
louis fourie
Sun Feb 15, 2015 5:45 pm
Vlak vark wrote:Louis, ek is ongelukkig in nelspruit in die hospitaal met my suiker. sodra ek uitkom vat ek n kiekie of twee vir jou :thumbup:
Dankie
Sent from my IdeaTab S6000-H using Tapatalk
louis fourie
Sun Feb 15, 2015 5:46 pm
ChrisF wrote:ek cable tie die draad na die LED ook vas aan die yster :)
Chris
Het jy aandele in 4x4Direct?:twisted:
Sun Feb 15, 2015 6:24 pm
As hy nog nie nie het nie, probeer hy baie hard :lmao: :lmao:
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Mon Feb 16, 2015 10:08 am
Andy, what mine also has added is a T-piece at the bottem to which the cable leads past after the LED lights. I then wind it back between the T-piece and the hook on top which stops the cable from sliding off either end. My hook is also bigger and rounded so that I can hang it over/around tree branches where I camp...
See my first post...
Hope this helps to clear up your shorting problem, as my system had had no problems for more than five years that I have had it in opperation...
HABOOB means "Dust Storm"
Mon Feb 16, 2015 1:09 pm
Yeah, but you didn't post any pics, so I was unable to understand!! :twisted: :twisted:
Haboob
Real Name: Edge
Tue Feb 17, 2015 10:57 am
You have seen that light in opperation on our first trip to Hoggs Back...
You know my computer skills & that I haven't the faintest idea how to post pitchas, especially from the tablet...
That you could not even master...
Tue Feb 17, 2015 1:50 pm
Ahem! If you recall, I found the embedded picture resize toll on your tablet, showed you how to access and how to use it, but the problem was that you didn't have an interface between your PC and tablet to transfer the pics to the tablet. :twisted: :twisted:
Haboob
Real Name: Edge
Tue Feb 17, 2015 3:38 pm
Can this be repeated in Engels, so that I can also verunderstand it...
You know I do not understand Computer JARGON...
Andy, remind me next time I come to East London with the Camper, so that I can show you...
Probably on Saturday close to LUNCH time...
No we are not comming for lunch, we alreadsy declined one offer just down the road from you...
Tue Feb 17, 2015 7:25 pm
Cool, I should be home. ;-)
