220 Volt AC generator for vehicle
Tue May 26, 2015 6:43 pm
There was a guy at the shop today with this product and I wondered;
Now that we all use inverters, is there still a need/use for this?
Is it maybe more stable/robust than an inverter?
Is a 220 Volt AC generator you hook onto your vehicle's engine.
a 4.5 Kw system cost about R20k for the whole system.
http://fabcopower.com/generat/bgen.htm" onclick="window.open(this.href);return false;
Comes from the US of A
Would you pay R20k for it and what will you use it for?
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Club VHF Licence: HC105
Tue May 26, 2015 8:23 pm
I guess you could run power tools off it, basically converting your vehicle into a genny. 20K, no thanks, you could by a decent generator for half that price, also would be cheaper than running the engine.
Scout motto:be prepared....
www.4x4direct.co.za
Tue May 26, 2015 8:54 pm
Ja nee daai maak ook nie vir my sin nie. Kan ook nie sien dat daai generatortjie 4.5Kw uitsit as mens hom vergelyk met die units wat so 5.2Kw uitsit nie.
Mossienel
Town: Paarl
Vehicle: Hilux 2011 2.5d4d DC 4x4
Tue May 26, 2015 9:06 pm
Dis net een van daai diesel genarator wat hulle by builders warehouse verkoop. Net sonder die raam, engine en wieletjies
Tue May 26, 2015 9:13 pm
CasKru wrote:Ja nee daai maak ook nie vir my sin nie. Kan ook nie sien dat daai generatortjie 4.5Kw uitsit as mens hom vergelyk met die units wat so 5.2Kw uitsit nie.
^^ Agreed. The thought of a 220v supply under the bonnet next to a hot petrol engine does not over-excite me as well.
Tue May 26, 2015 9:33 pm
I guess for a guy like Jacques in the Free State who installs masts in the middle of nowhere it must be a handy tool because you do not have to carry your big (half the price) gennie on the back of your Hilux and it takes up half the load bin. Your gennie is always there, cannot forget it at home and you do not have to take extra fuel.
Remember years ago you had one of those which you could even use to weld with.
Tue May 26, 2015 10:20 pm
Built in batteries and inverter is quiet, is always available as long as you have battery power that's charged for free (almost, if you take the cost of your panel over time), you don't have to run your motor and it's about ¼ of the price.
If on the other hand, as Pieter mentioned, you have to run some heavier machinery, a stand-alone genny is far more versatile.
Town: Bellville
Vehicle: Langpad (RAV4)
Wed May 27, 2015 6:33 am
pietpetoors wrote:I guess for a guy like Jacques in the Free State who installs masts in the middle of nowhere it must be a handy tool because you do not have to carry your big (half the price) gennie on the back of your Hilux and it takes up half the load bin. Your gennie is always there, cannot forget it at home and you do not have to take extra fuel.
My neighbour has lot a fair number of working hours due to load shedding.
Yet a genny that could drive his 230mm grinder and other heavy tools would by too big and bulky and would adversely affect their packing space in the Caddy .....
even then, on most sites he would have to run LONG leads from the parking area to where he actually needs the power.
JamesC
Town: Potchefstroom
Vehicle: SRX 2.5 4x4 D/C
Real Name: James
Wed May 27, 2015 9:03 am
Nice idea...not for leisure market.
But for guys on the road doing repairs to vehicles and so on, very handy.
I had to spec a similar setup with deep cycles and dc chargers, then this is reasonable and no batteries in the back of the van.
Fleet of trucks, maintenance guy...might sell
James Cameron
0834431879
Toppie4x4
Vehicle: Hilux 4.0 V6 DC 4x4
Wed May 27, 2015 1:54 pm
years ago we had a similar alternator on our maintenance vehicle that we used for welding purposes. Dual purpose it was a normal alternator and a welder, tow in one.
Bazzer
Vehicle: Toyota Hilux 2700i DC 4x4, Toyota Hilux 3.0D4D 4x4 Auto
Wed May 27, 2015 2:14 pm
I have one of these, have not installed it yet as I need to replace the alternator as well.
http://www.unipower.co.za/" onclick="window.open(this.href);return false;
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Thu May 28, 2015 10:45 am
Piet,
I had one of these fitted to my old SFA which helped a few times in the bush where I could weld, drill or grind...
It also had a three point plug which were used for power tools...
Very handy to have and were a lot cheaper then, but also still very expensive for the time...
The vehicle had to idle/Rev at about 2000 rpm to generate the required amount of power to operate the power tools or to weld...
When I upgraded to the Vigo, I had nowhere to mount this in the new vehicle...
HABOOB means "Dust Storm"
mubark_faleh
Fri May 29, 2015 6:22 pm
السلام عليكم
أرسلت بواسطة iPhone بإستخدام Tapatalk
Thabogrobler
Club VHF Licence: x223
Fri May 29, 2015 11:32 pm
mubark_faleh wrote:السلام عليكم
Hahaha!!!!
This is do funny!
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Sun May 31, 2015 6:20 pm
Haboob wrote:Piet,
I also had one of these fitted to my first SFA.In my case the alternator light never comes on when the ignition was on (ACC).(Was it the same in your case Edge)That always worries me because I will never know when the fan belt breaks or the alternator stop charging.Otherwise it was a very handle tool to have.
hansman
Town: pretoria
Vehicle: hilux sfa
Real Name: hans
Sun May 31, 2015 8:24 pm
Hello
Ek het n paar jaar gelede op hierdie on board gen af gekomOns het +/- 13000 Humvees in Irak gehad toegerus met hierdie gensets.AurraGen model G5000. Dit is net vrek duur hier is die site http://www.dtic.mil/ndia/golf.pdt" onclick="window.open(this.href);return false;
Die goed werk maar soos gese VREK duur,baie interressant kyk gerus
Groete
Hansman&Vaaltyn
NB Eendag as ek groot is!!!!
Sun May 31, 2015 9:22 pm
"Page Not Found
This page does not exist or has been moved.
Please check the URL for errors and try again.
Contact the Defense Technical Information Center if this problem persists."
hansman
Town: pretoria
Vehicle: hilux sfa
Real Name: hans
Mon Jun 01, 2015 10:06 am
Hello
Ja ek sien die site maak nie oop nie.Ek het gaan kyk deur die volgende in die google address bar te tik AuraGen Viper g5000 toe het hy oop gemaak en so in die middle was die genie
Groete Hansman&Vaaltyn
