Power Supply Unit
Posted: Tue Jan 12, 2016 8:35 am
by etiennel22
Good day,
Hope anyone can help me.
Does anyone know what this brown round thing is? after some googling I think it is a fuse.
It is from a 12VDC 3,2A UPS Power Supply Unit.
Thank you
Regards
Re: Power Supply Unit
Posted: Tue Jan 12, 2016 8:48 am
by ChrisF
do you have a photo from a different angle ?
typically capacitors that release smoke .....
but I dont see any "farad" value .... but then again very often components on commercial pc-boards dont display all info ...
Posted: Tue Jan 12, 2016 8:51 am
by etiennel22
I will upload another photo tonight.
But from what I can gather it might be this,
http://za.rs-online.com/web/p/products/2260967/" onclick="window.open(this.href);return false;
Posted: Tue Jan 12, 2016 8:56 am
by Family_Dog
How many wires from it? You'll have to look at the other side of the PCB for that. It looks more like a full-wave bridge rectifier to me, so will probably have four equidistant leads.
Whatever, it certainly looks like it is now "fused".
Edit: Aah, might be a Wickmann fuse!
Posted: Tue Jan 12, 2016 9:01 am
by Stef
Looks like a fuse yes. Cylindrical (electrolytic) caps are normally used in power supplies are usually marked clearly ito Polarity as well and bulges at the top when blown.
Posted: Tue Jan 12, 2016 9:03 am
by etiennel22
Family_Dog wrote:How many wires from it? You'll have to look at the other side of the PCB for that. It looks more like a full-wave bridge rectifier to me, so will probably have four equidistant leads.
There is 2 wires from it going into the PCB
Posted: Tue Jan 12, 2016 9:40 am
by Jaws
You are correct it's a
Bussmann fuse
Posted: Tue Jan 12, 2016 12:11 pm
by etiennel22
So can I buy a new one and just replace it?
Sent from my GT-I9500 using Tapatalk
Posted: Tue Jan 12, 2016 12:51 pm
by ChrisF
buy a couple ..... the fuse is not the problem - just an indicator of the actual over current .....
Posted: Tue Jan 12, 2016 2:36 pm
by Stef
+1 Replace and switch on without load, if it blows again there is a short/faulty component on the board.
Posted: Tue Jan 12, 2016 3:14 pm
by etiennel22
Stef wrote:+1 Replace and switch on without load, if it blows again there is a short/faulty component on the board.
Thank you, will give it a try
Posted: Wed Jan 20, 2016 7:49 pm
by etiennel22
Got the replacement fuses. But as soon as I plug in the unit it blows again. So I guess there is something else wrong.
Posted: Thu Jan 21, 2016 2:30 pm
by Stef
Sounds like you have a dead short somewhere between L -N.
Posted: Thu Jan 21, 2016 2:34 pm
by etiennel22
Anyway to determine where that would be?
Posted: Thu Jan 21, 2016 4:01 pm
by Stef
Easiest is to measure with a multi-meter to see if that is the case...then follow the actual tracks on the back to see if there is any obvious shorts like a piece of wire/solder or maybe against the enclosure when assembled etc.
With that eliminated, check the major components one by one
Posted: Thu Jan 21, 2016 4:10 pm
by etiennel22
Will give it a go when I get a chance. Thanks
Posted: Mon Feb 22, 2016 11:59 am
by etiennel22
Finally got time to test the unit. So it seems the yellow Polypropylene Film Capacitor next to the Fuse is also dead.
Found a place that sell those capacitors hopefully I can get the unit working tonight. Holding Thumbs
