Ctek 250s dual query
ismail
Vehicle: Hilux '03 2700i SC 4x4
Real Name: Ismail
Fri Apr 29, 2016 10:47 pm
Hi guys.
Quick one who's installed a 250s dual in their vigo. I hooked up one for the first time this evening and can't get it to switch on.
I did have a big learning curve on wiring the spotlights to find out about negative switching etc.
Is there something I'm missing I followed the manual step by step but the unit just is not switching on.
Will appreciate any help
I surf more than I work
ismail
Real Name: Ismail
Fri Apr 29, 2016 10:51 pm
Oh yes
1. alternatur/ main battery positive to input of the charger.
2. Output negative to second battery negative
3. Output positive to positive of second battery.
Am I missing a common ground or something.
george
Vehicle: Prado 90 VX 3.4 V6
Club VHF Licence: HC107
Sat Apr 30, 2016 7:30 am
Jip.you are missing a common ground. I will check the wiring when I am in the shop this morning.there should be a link between negative of main and aux battery. I will just make 100% sure later
Town: Bellville
Vehicle: Langpad (RAV4)
Sat Apr 30, 2016 7:47 am
peechas please ...
Ismail sit n paar fotos op van wat jy gedoen het.
En as jy kan, sit n paar byskrifte by van watter draad van waar kom/gaan .... klink of jy dalk die inkomende "ground" mis. En moenie dit van die body optel nie, hardloop n swart draad van battery 1 tot by die Ctek.
Town: Bellville
george wrote:Jip.you are missing a common ground. I will check the wiring when I am in the shop this morning.there should be a link between negative of main and aux battery. I will just make 100% sure later
JIP, TWEE swart drade nodig ....
george
Sat Apr 30, 2016 9:03 am
Hi Chris.Hoekom 2 drade?
Must say in the manual there is no clear pic.We have this one in the shop that shows it better.
ismail
Real Name: Ismail
Sat Apr 30, 2016 9:14 am
Yip thanks guys was a common ground not connected. Sorted and running now.
I really don't understand why the manual does not indicate this. But the the unit is running sweetly :)
ismail
Real Name: Ismail
Sat Apr 30, 2016 9:16 am
Thanks also for the responses over the long weekend I thought I'm the only one home this weekend.
Town: Bellville
Sat Apr 30, 2016 9:33 am
Oops...
George ek het jou geantwoord ... my reply is weg.
DRIE neutraal drade nodig.
1ste battery
PV
2de battery
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Mon May 02, 2016 5:34 pm
ChrisF wrote:Oops...
DRIE negatiewedrade nodig.
1ste battery
PV
2de battery
:D: net ingeval iemand die neutrale drade soek
Johan Kriel
Prado
Town: Bellville
Mon May 02, 2016 6:23 pm
thanx :thumbup:
solank hulle net nie die earth draad begin soek nie ... :twisted: :twisted:
I tapped all the Negatives from the battery, was a bit easier in my installation.
I already had the 25mm wire from a previous installation, for a dc-2-dc installation I wont use more than 6mm
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Tue May 03, 2016 12:24 pm
The neg from primary batt is needed to reference the voltage coming in from the alternator, iow the ctek couldn't measure the voltage & therefor did not switch on. It's like putting only the pos lead of your multimeter on the batt & expecting a reading ;-)
Also tied the negatives at the battery with only one going to the Ctek, less mechanical strain on the connectors
ismail
Real Name: Ismail
Wed May 04, 2016 10:57 am
Stef, I agree with your comments but I did follow the manual, as this was my first 250s install and thought maybe there was some sort of fancy tech that I did not know of,
Town: Bellville
Wed May 04, 2016 11:08 am
Ismail you got it working - and you now KNOW your system.
Should something go wrong in the bush you KNOW where to start scratching .....
Those that place an order and drive out with a complete installation are very much "exposed" should something go wrong in the bush ....
PS - worst case in the bush - place the leads from battery 1 and 2 on the same connection point .... Ctek wont work, but your battery sees the alternator and you can keep the fridge going ... DO note this CAN drain your primary battery over night, thus only an emergency repair, and to switched OFF over night.
marlin control
Town: cape town
Vehicle: hilux 4x4
Real Name: andrew
Club VHF Licence: HC-200
Mon May 29, 2017 11:41 pm
Can i connect the cetec 5 amp charger together with the solar panel onto the solar connector of the d250s.
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Tue May 30, 2017 10:26 pm
Rather connect the ctek charger directly to a battery. When solars are connected to the 250 dual it will hopefully simultaneously charge the battery.
Johan Kriel
Prado
LouisZ
Wed May 31, 2017 9:04 pm
To make it work.
Negative to main battery.
2nd negative to Aux battery if you don't use PV. If you do a 3rd negative
All This will go onto the Ctek - terminal. Its bad they don't show it on the instructions. But that how its done.
Also remember if the supply voltage(From alternator) is less than 12.8volts it wont kick in, check your voltage on the vehicle if your alternator works correct.
