Sound Questions
- Cookie Monster
- Town: Port Elizabeth
- Real Name: Justin
Sound Questions
Hi Guys
Quick question I am really into my sound as FD will know so he will know what I mean when I say sound is so difficult to install in the old SFA :!: Now I am not a BOOM BOOM junky but here is the problem I installed a Sony head unit with a fair bit of on board power 50w into 4 channels which as normal is horrible over estimated reall power is more like 15w in 4ohm stable . However in my opinion the Sony has the best sound I have heard other then really exzotic stuff. Now the sound I get out 4 6x9 Sony Xplod speakers in the doors is fine in the mid range and trebble it just does not cut it low down now I know I have to add a amp to drive the 6x9s to the potential however I have heard a similar setup in a Isuzu DC with a Rockford Fosgate Punch power amp but it still sounds CRAP!!! And please remember it is not volume I want I want quality though I do like to turn up the odd song I like my music taste is very wide everything from a bit of classical to rave. Now 6x9`s Generaly dont last as I told y buddy with the Isuzu and gess what 2 of his 6x9`s are now damaged :roll: . Now here is the thing I need to fit a small sub behind the rear seat has anyone done this in the Hilux and what is the max size will a 10inch fit if I construct a incloser that will fit and give the max volume available. I know it wont be ideal but its the best I can cum up with. :roll:
Re: Sound Questions
Hi Justin,
I also have a Sony Head unit coupled to pre-existing 6x9 speakers in the doors, I think Pioneer, not sure. They are fitted in all four doors. The SFA was never designed with quality sound in mind, but the door-mounted speakers do offer a remarkable improvement in audio quality over what the Toyota Engineers originally planned for us.
I must admit I have never even thought of adding a sub, to be honest, I don't really advise it for a small area such as in a car because you will never get the full benefit of the sub's capabilities in any case - the sound waves tend to cancel out in such a confined space.
Truth to tell, I doubt I would ever have cut my doors & door panels myself, I bought the car like this.
Sadly, I don't think there is too much one can do in a SFA to really offer great sound, except maybe for wearing a pair of high quality headphones
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
HI FD
I think the problem here is more to do with the fact that the head unit is a little bit light for the speaker so if I just add a amp they would sound alot more controlled . However I would like to add a sub so that they dont have to work so hard I hope I am making sence 8)
- Niel
- Real Name: Niel
Re: Sound Questions
Hi Justin
Speak to Riceburner, apparently he installed a nice system in his DC. I don't have the detail.
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
Hi Justin
Having done sound installations on hatchbacks and bakkies over the years I can say that adding a small sub into the system will make a huge difference in the lower range of Hz. By adding a sub you may find that you will be able to replace your exising 6x9s with a speaker more suited for midrange such as a 6 inch 2 way. (as you like Sony, there Xplode range has the 6's I believe). I have never added a box to a lux but I have done many on the old mazda rustlers which as i'm sure you know has pretty much the same space constrictions.
A 8 or 10 inch sub fitted in a smallish custom built box would fit nicely behind the rear seat with the only problem being that you lose a little of the sound but being only for low down bass it is not really too serious. The other option is to box the same said sub over the tunnel between the rear and front seats with the sub facing forward, but you might find this to produce a bit more than you want. If it were my vehicle I would go with the first one and test it, whipping up a box isnt too difficult, some places even sell ready made ones that would fit.
The first thing to do is to measure how much space you have behind the back seat and then find something that will fit. Don't forget the slant of the seat! There are subs called limpets now called the flat series, pioneer made, they are thinner than normal subs (and pricier) and allow you to create a thinnner box. Be careful as to the size of the box though, it does affect the sound you get.
I don't know if you guys have a autostyle in PE but they have a box specifically for bakkies going for R195 (pic included) that might fit in the lux as it would be made for single cab bakkies.
http://www.autostyle.co.za/prodview.php ... dstr=&str=
Hope this helps. :D
Hope this helps. :D
- Town: Strand
- Vehicle: Hilux D/C 4x4, '97
Re: Sound Questions
Hi-Fi corporation and Cash Crusaders sell these thin boxes to go behind the seats, mostly for taxis for about R200, but the speakers are crap. Just put a decent speaker in the box. They will fit nicely behind the seat!
Re: Sound Questions
The sound qualities of these thin boxes will not require discussion... they have no sound qualities
Best is to change your style of music, less thump & more "Taraa..."
Re: Sound Questions
Or else install a nice 6 or 8 cyl engine. Then you can turn down the radio and listen to that baby purr...
Re: Sound Questions
...especially if its a Diesel Engine, those things always produce a big cat sound... grrrrrrrrrrrrrrr...benhur wrote:Or else install a nice 6 or 8 cyl engine. Then you can turn down the radio and listen to that baby purr...
Re: Sound Questions
Ag nee gaga poefies man, ga poe. Jy kan mos nou nie daai geraas nice noem nieFamily_Dog wrote:...especially if its a Diesel Engine, those things always produce a big cat sound... grrrrrrrrrrrrrrr...benhur wrote:Or else install a nice 6 or 8 cyl engine. Then you can turn down the radio and listen to that baby purr...
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
Well I was thinking more along the lines of extending the box to run the full lenth of the back seat and maybe down to the floor on either side of the seats. But a nice 6cylinder would be great but its no Bruce Springsteen. Well maybe the best thing is to check is to calculate how much box space I can get and then decide what sub to use 8 or 10inch.
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
Re: Sound Questions
I have a 2800w XTC amp with 4 tweeters and two Infinity mids and a 12" Infinity SUb. Alpine head unit.
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
My problem is were and how to mount the sub
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
As I mentioned already, the best place is behind the back seat. Start by checking the base distance from the back of the seat to the cab wall and then the same at the top of the seat, you will find you can only go so far up. Also, dont forget to measure how high you are going up, then with those three measurements you can draw a basic outline and get the angle of the back seat. Use a mock up of cardboard if necessary. Then depending on your space allowances, a decision can be made wether to use a 8", 10" or 12" sub. The sub will drive directly into the rear of the seat and I wouldnt think it would need any mounting as the seat would keep it in check.
Riceburner, I assume that 12" is behind the seat, could you post a pic for CM
(Do we all know what ASSUME did It made an ASS out of U and ME :!: )
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
Would a 12 inch sub fit behind the back seats I would think that it would be a little tight behind there.
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
You are right CM a 12" is rather large for behind the back seat but other than putting it in the BAK, there is no where else for it.
Personally I think it is a bit of overkill (that being said I had 2x 12" in my golf). A way that springs to mind is to attach the sub to the back seat, i.e screw it in and not use the box at all, effectively using the area behind the seat as the box. This may work but I can't say that I've ever tried it. it would mean that a 12" could be used but would also mean that nothing else could be put back there for fear of damaging the sub.
I will take some measurements this weekend and check against the 12"s I have but also take note that although a 12 is larger in diameter it might not be in thickness when compared to a 8 or 10".
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
I agree however it does mean that you may not be able to mount at as far down as the 10 or 8 I think the 10 would be a little better as my focus is more on sound quality then all out SPL so to speak. As I am surounded by diffrent BMW`s all day I get to see some really awsome instalations and sometimes I find the more pretty instalations dont really cut it when in comes to sound quality. I think part of the problem is I am spoilt at home with the Harmon/Kardon Kef setup. :?
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
Re: Sound Questions
For a Hilux, an 8" sub will give you enough low frequency response for good solid tight bass (not taxi resonance) provided you get the enclosure volume and dimensions right according the speaker manufacturers spec. Remember also that you get subs for free air enclosures (ported) and those for sealed enclosures. I always like good tight bass that feels like an 18 wheeler hitting you from behind
Otherwise, get a 12" with a nice 2kW mono-block amp and then you can find where all the rust and body putty actually are hidden
Sifu-Lux....I will miss you
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
Here's a website you should go check out. It supplies you with all the info needed to make the correct size, ported or sealed, enclosure.
You can download the calculators and use them but you will need the info sheet of the specific sub you want to use.
Some manufacturers have their info on their websites so you could play around with a few before even buying.
Hope it helps.
http://www.ajdesigner.com/speaker/asealedexample.php
Hope it helps.
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
Thanks Scooter I will check it out Andrew I think you are right I a not looking for a noise 8) I want similar sound to my Kef`s
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
I think that all of us would like to have the perfect system but of course most of the time money does not allow us to buy the best there is.
So..... A good system can be put together using the Sony, Pioneer etc of the world (which lets face it are the best you can get on a tight budget).
The main thing to remember is that putting to little power through a speaker causes bad sound and putting to much power through a speaker causes bad sound.
that is to say, match your speakers with the amplifier correctly and in this case you need to first match your box and Sub correctly. (have box dimensiond first then choose sub)
Again, IMHO I would get rid of the 6x9s you have in the doors and replace them with a decent mid range 6inch and perhaps a set of tweeters up front. The 6x9 gives overall sound but the ear cannot differentiate between it all so its sound is not as clear as it would be with a split system.
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
7MGTE, although nice, I don't quite think that's what CM is after.
Do you still have an engine in the front or do you just bounce down the road?
Is that from your vehicle? if so, how about some dimensions and pics? :D
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
Yip Scooter not quite what I am looking for but pritty cool
- Sifu-Lux
- Real Name: Andrew
- ismail
- Real Name: Ismail
Re: Sound Questions
Hi Cookie Monster
I'm new to forum, so hi all
I'm quite into my sound as well, dont play it as loud anymore but still into good sounding audio
I had a 2.4D single cab 96 model, with mids and tweeters (in the doors) and a 8" sub behind the seat, played blady nice, so transferred it to my 2700i when i sold it.
I would recommend the lightning audio splits about R1000 in the front doors and a 8" lightning audio sub R600 and a lightning audio amp too, price depending on rating of the amp, even a Rockford setup if you want to spend the extra bucks. Wont be hectically loud but you will enjoy your music
Ismail
Ismail
I surf more than I work
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
Welcome Ismail, a few wise words for your first post.
I am not familiar with lighning audio, tell us a bit more? You got pics of the subs mounting in your 2.7? :D
Rockford tends to be way too pricy for the average sound enthusiast and you will get great quality sound from lots of other options. I have always been partial to Pioneer with the exception being the amp, my last one was the Starsound Gladiator, which will be for sale shortly as I have no use for it anymore.
But each to their own I say . For CM I thought it would be good for him to stay with Sony and to match his speakers with the headunit (yes this is not a must but.......) as Sony would have done their testing and created everything to work together. I guess I'm saying that you should try and match everything, if thats not possible then try at least match the speakers.
- ismail
- Real Name: Ismail
Re: Sound Questions
thanks Scooter
lightning audio is actually a cheaper version of rockford just under another name, "cheaper version" still sounds quite nice, really to complete with the cheaper brands, the rockford agents stock them,
ill take some pics of the install and post them soon.
Re: Sound Questions
Howzit Monster Cookie
My system is assembled as follows:
Sony Xplod head unit (ipod adaptable) - R 1,950
Sony Xplod 1200W 4 channel amp - R 1,500
Sony Xplod 12" Sub and box - R 1,850
Sony Xplod two 6 x 9 450W speakers (front) - R 800
Sony Xplod two tweeters (dash) - R 300
Sony Xplod two Mids 7" 300W (rear doors) - R 600
Cross overs for Mids and tweeters - R 500
R 7,500
This will give you awesome sound, and although not very cheap, should also not break the bank.
R 7,500
Re: Sound Questions
Justin,
This sounds like something we both would want.
What say we go to Pretoria and do a Mafia-style hit, share equally...
You can have the sub, I'll take everything else.
- Scooter
- Town: JHB
- Real Name: Scott
Re: Sound Questions
7MGTE, where the photos. Cookie Monster is looking for ideas to mount a sub and I'm sure he would appreciate a few pictoral ideas.
How about it?
F_D, don't joke, I received an email (you may have got it as mail travels the world) about a little golf that was stolen in mamelodi, the pictures showed it 1 hour after the theft, it was just a shell . These guys work quickly jong. :evil:
How about it?
- Cookie Monster
- Real Name: Justin
Re: Sound Questions
Hi guys been away for a while 7MGTE I would love some photos for ideas Ismail thanks for the advice but I think I will stick with the sony for the moment but maybe your idea with the sub will work great have you got any pics maybe?
Andrew mmm dont think I really want a taxi by the way I have some prices that you were looking for I just need to get clarification on Monday from Duncan.
Scooter thanks for your help
Re: Sound Questions
Howzit guys,
I should get my cabby back this week from its engine upgrades, and will post pictures as soon as possible.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Re: Sound Questions
Hi cookie monster
I am in the process of fitting a Pioneer 12" "shallow mount" sub to my IFS 'lux.
Both Pioneer and Sony make "shallow mount" subs that are escentially free air subs that can run in a ver small box - some specs state 1/2 a cubic foot volume which is generally very small for a sub.
After some serious homework I have found that it is possible to fit the box and a custom amp rack (to house 1 amp) behind the rear seat without too much hassle. It does mean that it sits at about the same angle as the seat itself i.o.w. the side of the box is besically triangular.
The one problem I am still trying to solve though, is serious resonance - seemingly caused by the rear wall of the cab. I am thinking of installing something like Dynamat to fix this (finance permitting ) otherwise it plays down nice and low, and frees up the other speakers to play mid and trebble - which they can do better at anyway!
BTW what Sony headunit have you got? The xplod GT-280 has a nice setup where you can set your x-over point for both high and low pass and still adjust high, mid, low and sub independantly. Yes it is not an RDS radio, but for all its features AND an remote control - all for under R1000! I'm loving mine!!
Just my 2c worth.
Just my 2c worth.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- LouisZ
Re: Sound Questions
What I did in mine was to get high quality speakers(I think it was 4") that was 100 watts installed in the dash, make 100% sure it it properly secured.( Bad sound always start with speakers that is not properly fastened or fastened on the wrong surface) Back Speakers was Sony's aswell, 10Watt either 8 or 10" rounds, 3 ways. Then Wiring is also important, not thick but more the quality copper and also how it connect to the speaker and radio, and yet again, fastening the speaker to the rear door, make sure you fasten it to the metal, not the board.
No amplifier was in but the sound was great! done alot of sound a years back, and if it it need to be,FD have those nice boards on the doors that also make a difference to sound, if you make it yourself, only use either 16 or 19mm thick Supawood, Nothing else.
Louis
Louis
Re: Sound Questions
Yep, they are made from vinyl-clad MDF as well. You will note we made the cut-out slightly larger so as to fit better speakers, the originals are Pioneer but have seen better days. But as long as they sound OK, they stay. When the rattles start, in with the new!
