Best engine transplant for 94 hilux surf
Modification to your Toyota Surf or 4Runner
Town: krugersdorp
Vehicle: audi
Real Name: Muhammad
Fri Nov 03, 2017 6:55 pm
Hi guys
I have an automatic 94 surf. Diesel non turbo engine,think its 2.4
Engine seized ,looking for good suggestions for replacing engine .
Sent from my EVA-L09 using Tapatalk
Sat Nov 04, 2017 7:52 am
If you have the motor rebuilt would probably be the cheapest option. Also retains the original engine number and vehicle originality for a better resale value.
If you can find a 2nd hand replacement Toyota 2.4 diesel motor, you might have to do bearings and rings anyway. You would also have to have the engine number changed on the registration papers.
These two options wouldn't need any modifications.
Otherwise fit a Ford 2.5 WL motor, it's also diesel but you would have to make modifications to engine mounts, clutch and bell housing amongst a few other bits and bobs. Although not Toyota, these are excellent and reliable motors.
If you want to move away from diesel, then the V6 Toyota 3.4 FVZ is a good option. Some surf models came out with this motor, so matching a bell and gearbox shouldn't be too difficult - you might have to change diff ratios though.
If you opt for a Lexus V8 1UZ, then it may be best to use the Lexus box, either manual or auto but you might also have to change the diffs for ones that can handle the torque (KZ diffs should be fine).
Town: krugersdorp
Vehicle: Prado 90 V6 3.4 Auto
Real Name: Martin
ORRA Call Sign: X100
Wed Nov 08, 2017 7:01 pm
hi Muhammad
look at engine for africa they import motors from japan
toyota 3c turbo also works well if you can find one
Return to “Surf & 4Runner”
