2.8 3l to a 4y
Modification to your Toyota Surf or 4Runner
confused hilux
Vehicle: hilux 4 runner
Real Name: johann
Sat Jan 04, 2014 8:26 am
I would like to know if it will be worth wile changing from a 2.8 3l diesel to a 2.2 4y
i have rebuilt my motor after it got hot and have the same problem
I have done evrything new head new radiator new thermostat new water pump(all is new) and it still gets hot when i go over 80 km/h or on the open road I never had the problem before I am desperate. and need help.
ORRA Call Sign: x223
Sat Jan 04, 2014 9:13 am
Rather get your car to someone that knows how to properly setup and adjust a diesel - over-fueling will also cause overheating!
For a start, also have a decent freeflow exhaust installed, minimum 63mm.
Vehicle: Hilux SFA
Real Name: Rodney
Sat Jan 04, 2014 1:02 pm
Johann what radiator does it have in at the moment?.I can give you some tips on eletric fan mods call me on zero84five276369.
Return to “Surf & 4Runner”
