Prado 120 series Engines
- farazharoon
- Town: Pakistan
- Vehicle: 2004 Prado TX
- Real Name: Faraz
Greetings to all.
Need some advice about Engines for the Prado.
Dont want to spend that much on fuel e.g the 1GR-FE 4.0L vvt is too big. Probably drinks too much petrol.
The engines I want to ask about are:
Diesel
1KD-FTV 3000CC 4cyl 125kW 2000 (D4D)
5L-E 3000cc 4cyl 68kW EFI
1KZ-TE 3000cc 96kW 1993
3L 2800cc 4cyl 67kW
Petrol
2TR-FE 2700cc 4cyl 111kW 2003 efi
3RZ-FE 2700cc 4cyl 112kW 1996
5VZ-FE 3400cc 6cyl 132kW
Any of these engines possible problem makers?
Also any advice over what kind of gearbox to go to with. Automatic or manual transmission. I mean any techinical issues with either. Is Auto transmission ok for mountains?
Please help.
Faraz Laldin
Diesel
3L 2800cc 4cyl 67kW
Petrol
Please help.
Faraz Laldin
"An eye for an eye makes the whole world blind."
--Mahatma Gandhi,
--Mahatma Gandhi,
Re: Prado 120 series Engines
I'm not a Prado specialist, but I'd say a Prado will need a decent power engine... as far as I know 90/120 Prado's with these engines were available in SA:
90 Series: 3.0 L (2982 cc) 1KZ-TE, 3.4 L (3378 cc) V6 5VZ-FE
120 Series: 3.0 L (2982 cc) straight-4 Turbo diesel 1KD-FTV... um.co.za lists this engine as an RSA option for the 120...
I'm sure other members can fill in the blanks...
Mr B
Mr B
Dump the Diesel engines, they are too under-powered and prone to giving problems - except for this one:
As far as the petrol engines go, the 2.7 engines are definitely no more economical than the V6, so I would only consider this one:
In SA, the 3RZ is also fuel injected, I don't know the other 2.7 engine at all, unless it's the latter-day 2.7 with VVT. But even this has set a few tongues wagging in disappointment, if it is indeed this one.
Eric what engine does your Prado have?? I detect a conflict of interest...Family_Dog wrote:....the 2.7 engines are definitely no more economical than the V6, so I would only consider this one:
5VZ-FE 3400cc 6cyl 132kW...
Mr_B wrote:Eric what engine does your Prado have?? I detect a conflict of interest...Family_Dog wrote:....the 2.7 engines are definitely no more economical than the V6, so I would only consider this one:
Only the best, of course... which happens to be the one under discussion... ;)
- farazharoon
- Town: Pakistan
- Real Name: Faraz
Thanks a lot for all the information. :)
It seems to be pretty clear out of the diesels 1KD is the best. (As long as you stay away from dirty diesel, true?)
And the petrols it does not matter as they are all about the same in economy? Might as well go for the bigger. I think the new 2.7L is VVTi at least the ones coming in the Fortuner. Were the old 2.7L not VVTi?
VVTi should translate to better economy right?
Eric which engine do you have? The 5VZ, petrol V6?
Any comments about manual vs automatic transmission? Is Auto ok for mountains? I heard that going downhill with Auto gearbox can cause brakes to overheat, because its keeps shifting up in the gears, true? .
--Mahatma Gandhi,
--Mahatma Gandhi,
I HAVE THE 3.4 V6, yep! Great engine, very smooth and good for hundreds of thousands of kilometres of trouble-free motoring. All you have to do is to change the Cam belt every 100,000km or so.
- farazharoon
- Town: Pakistan
- Real Name: Faraz
Thanks a bunch for your replies especially to Eric.
Sorry to be a bit pushy about this but really do want to know the answer to this if possible.
About manual vs automatic transmission? Is Auto ok for mountains? I heard that going downhill with Auto gearbox can cause brakes to overheat, because its keeps shifting up in the gears due to incline, true? .
Do auto gearbox break easier?
--Mahatma Gandhi,
--Mahatma Gandhi,
This would be true if you left it in "D" (Auto), but with most auto boxes you can select your gear "1/2/3" etc. So if you were to select 1st on a downhill you would use as little brakes as anyone else. As far as auto boxes being weaker than manual goes, it does''t sound right to me although there is a lot more that can go wrong. Maybe someone with more knowledge can clear that one up for you.About manual vs automatic transmission? Is Auto ok for mountains? I heard that going downhill with Auto gearbox can cause brakes to overheat, because its keeps shifting up in the gears due to incline, true? .
- 2.8 d/cab SFA
- Town: Boksburg
- Vehicle: Yamaha R1
- Real Name: John
Prado newer has hill descent on auto box, so no worries with auto.
Diesal rulz
Diesal rulz
John
- farazharoon
- Town: Pakistan
- Real Name: Faraz
Thanks guys for your info about Auto and manual boxes. .
Maybe I'll put up a another forum post on toyota auto boxes vs manual. To get more feedback.
When you say the "newer" Prado has hill descent are you talking about
120 series i.e after 2002?
--Mahatma Gandhi,
--Mahatma Gandhi,
- farazharoon
- Town: Pakistan
- Real Name: Faraz
This is another question concerning petrol Engines for Surf and Prado so will continue in the same threat.
Do you have to put hi-octane "premium" petrol in any of the below Engines?
3RZ-FE 2700cc 4cyl 112kW Y1996
2TR-FE 2700cc 4cyl 111kW Y2003
1GR-FE 4000cc 6cyl 215kW
Or can normal petrol be put into it?
--Mahatma Gandhi,
--Mahatma Gandhi,
I run normal octane unleaded in my 5VZ-FE, not sure what the octane rating is up here in the Highveld (±1400M A.S.L.) but the coastal areas do have a higher octane rating than upcountry.
- farazharoon
- Town: Pakistan
- Real Name: Faraz
Decided to go with 1KD as that is a very common engine here.
--Mahatma Gandhi,
--Mahatma Gandhi,
- HennieJ2
- Town: Witbank
- Vehicle: Hilux D/C D4D 4x4, Hilux KZ-TE D/c 4x4
- Real Name: Hennie Jackson
Faraz, nothing wrong with those D4D engines, especially if you use low sulphur diesel (50 ppm). Their weak point is the injectors - if they get dirty diesel, they don't last long. There is an extensive discussion on them on the 4x4Community's Toyota section.
Hennie
Hennie
