VIgo Diff Drop Kit
Anything else you wanna sell
Forum rules
When advertising something in this section the following rules apply:
1. You must include the price in the subject line and / or in the post.If you don't specify a price we will delete your ad.Click here if you are unsure
2. You must upload a photo. If you don't upload a photo we will delete your ad. Click here to find out how
3. If it is an "auction" item you must state so in the subject line instead of the price. Auctions can be valid for a maximum period of 14 days.
4. It must be 4x4/outdoor/vehicle related.
5. Once the items has been sold you must edit your post and put SOLD in the subject line.
EXAMPLE: Set of 31" BF Tyres for sale - R3500
or SOLD - Set of 31" BF Tyres for sale - R3500 - SOLD
6. Don't be a spammer. Introduce yourself and be part of the forum before trying to place an ad.
7. You MUST have a minimum Post Count of 10 before advertising here.
All for 4x4
Commercial Member
Commercial Member
Vehicle: 4x4
Real Name: Dawie
Tue Aug 05, 2014 3:47 pm
Middag
Ek wil hoor is daar n aanvraag vir n Diffdrop kit op die Toyota Hilux Vigo?
TOYODA
Vehicle: '07 Hilux V6 A/T 4x4 & '89 YN67R with Ford V6 3.0 & '12 Suzuki Jimny (SWAMBO)
Real Name: Tiaan
ORRA Call Sign: X139
Tue Aug 05, 2014 7:47 pm
Ek dink dit gaan dalk neer kom op die prys.
As die prys reg is, sal iemand dit koop...
Maar die groot probleem kom in dat ons in SA nie 'n "kit" het wat die voorste suspensie van die Vigo meer as 3" lig nie. Miskien moet julle aan so 'n kit dink... :think:
Jacques1965
Vehicle: Hilux D4D 4x4
Real Name: Jacques
Sun Apr 23, 2017 1:17 pm
Ek is besig met portal hubs vir Hilux D4D. Laat weet as iemand belangstel. Dit is n 4'' - 5'' lift.
jacques kotze
Town: Nelspruit.
Vehicle: Prado 4,0 V6, dual battery & 3.0 D4d S/C 4x4,front replacement,12000lbs winch.
Real Name: Jacques
Sun Apr 23, 2017 2:20 pm
Wat sal so dif kos ? gaan jy kry vir voor en agter ? Prys sal baie bepaal, almal sal dit wil he, maar die geld..
lukestoyzx
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Mon Apr 24, 2017 2:03 pm
Wish I could speak your lingo! I'm just guessing but is sounds like your asking about diff drop when doing big lift in an ifs truck? Don't bother! What you gain in lift you'll loose in droop which is just as important as up travel! If ya simply doing it to fit big rubber then do a body lift instead.
Jacques1965
Real Name: Jacques
Tue Apr 25, 2017 2:49 pm
this is to gain ground clearance as well as to alter diff ratio. You can lift your body as much as you like, the diff stays the same height from the ground. With bigger tyres the vehicle just looks mean but no gain when going offroading.
lukestoyzx
Town: Griffith
Real Name: Luke
Tue Apr 25, 2017 11:04 pm
When you do a lift above 3 inches you only need to fit a diff drop kit to lower the diff housing so your cv angles are flatter. Has nothing to do with gearing! Changing ratios is a whole different ball game. So whats the point of doin a suspension lift bigger than that if you just have to lower the diffs again and essentially lowering your clearance! Doin a body lift give you clearance in your guards to fit larger tyres which does give you more clearance! Fitting bigger tyres is the only way you truly gain more clearance under your diffs!
Return to “Anything Else for sale”
