4x4 6V 3L ESSEX FORD 1993
Posted: Sun Nov 02, 2014 7:02 pm
by HUGO MYBURGH
My Van started to jerk before servicing. After i replaced all the filters, plugs and points, coil, condensor, fuel pump, distributor cab, rotor, ignition timing, serviced the distributor and carburator i cant get my 4x4 started, what can it be. I lost compression on nr 6 then losing the exhuast valve, and then got compression again, but even so i still can not get my truck started. My concern is that there is not enough suction on the carburator, where must i start looking for the problem please, can anyone give me some possibilities to look at.
Re: 4x4 6V 3L ESSEX FORD 1993
Posted: Sun Nov 02, 2014 10:38 pm
Welcome Hugo! :thumbup: :thumbup:
Phew, you did a lot of things at one time so the fault could be anywhere. Carb - not sure what all you did to service it, but the gasket / seal to the manifold must not leak / suck air, also make sure that all vacuum lines are good and connected to where they should be. If you changed the needle and seat, you have to adjust the float level. Auto or manual choke? Working? If electric auto choke, is the solenoid wire connected?
Is the new fuel pump working? Fuel filling the float chamber? Didn't get the return line mixed up with the line to the carb?
Shouldn't be a reason not to start unless wildly out of spec, but did you set the gap on the new plugs?
Coil lead good, not broken or not making proper connection (not pushed fully home)?
Bougi cords correctly routed in firing order? Rotor facing no.1 cylinder cord when at TDC on ignition stroke? Not 180° out? Did you set the point gap correctly?
Perhaps retrace your steps and check it all as you go. :think:
Posted: Mon Nov 03, 2014 6:58 am
by Family_Dog
My guess is that the distributor might be 180° out of phase. Very easy to do that, caught me out once as well. Assuming, of course, that you removed it for servicing.
Posted: Mon Nov 03, 2014 9:45 am
by Pote
If all above is checked and it still wont start.
Have you checked the fibre gear in the front of the motor. The Essex motors are notorious for stripping those gears...
Posted: Mon Nov 03, 2014 10:34 am
by HUGO MYBURGH
Hi Pote ,i only checked the fiber gear through the feul pump hole,but it seemed fine.or should i remove the timing cover.thanks
Posted: Mon Nov 03, 2014 10:48 am
by Pote
Hi Hugo.
Iwould first go through all the stuff suggested by the two "Dogs", and only then start stripping on the motor.
Posted: Mon Nov 03, 2014 10:52 am
by Pote
Another thing these motors are prone to do is have a tappet noise. No matter how carefully you set it.
But with a bit of careful grinding and elbow grease it is easily rectified..
Posted: Mon Nov 03, 2014 12:05 pm
by ThysdJ
A noisy tappet is a happy tappet... dont go mess with Ford V6 tappets.. they are supposed to make a noise... :twisted: :twisted: :twisted:
Posted: Mon Nov 03, 2014 12:24 pm
by Hoppy
The points-gap should be 0.4mm and not 0.63 like the book says, unless it's a very old Fomoco distributor, that's usually the problem
Posted: Mon Nov 03, 2014 12:44 pm
by Pote
Hoppy wrote:The points-gap should be 0.4mm and not 0.63 like the book says, unless it's a very old Fomoco distributor, that's usually the problem
I had one of these motors in my first Hilux.
The first thing I did was have the distributor reconditioned and converted to Electronics.. Cost about R1500 if I remember correct.
Posted: Mon Nov 03, 2014 1:17 pm
by bduk
Make sure the condenser and point's wires doesn't short where they connect to each other in the distributor. Had that problem once after servicing mine.
Posted: Mon Nov 03, 2014 8:15 pm
by HUGO MYBURGH
Thank you to all concerened.Here is what i have done so far.Changed points and condensor.changed coil +coil lead.Replaced rotor+distibuter cap.Replaced elect feul pump'.Checked fibre gear through petrol pump hole(seems fine).Took distrubuter out and found one spring loose and repaired it.Still no joy,did a compression test with my finger and found no 6 piston have no comp,then i loosened the exhaust valve a bit and got comp,still no joy it still backfires through carb.i then chocked it by hand but it does not suck a lot.sparkplugs on piston 3+6 is wet with fuel but others are dry.points gap set to 0,45mm on bosch dist ,plug gap at 0,62mm.i also made the points gap smaller and larger with no joy.i set the timing at tdc then 4 deg then 6 and so on up to 14 deg,but still no joy,i also turned timing a 180 deg out but still no joy.I will keep you all updated,thanks again for all concirned help
Posted: Mon Nov 03, 2014 8:30 pm
by 4x4BEES
Ek weet niks van mechanics af nie, maar ek het al gelees van die earth draad wat kan rond neuk hier op die forum.
Moet asb nie lag nie, ek vra net of jy al ook daarna gekyk het. Jammer vir die onkunde :blushing: :blushing:
Posted: Mon Nov 03, 2014 9:57 pm
by HUGO MYBURGH
Dankie 4x4bees nee ek sal nooit lag nie nog nooit te oud om te leer nie maar sal definitief more na die aard draad kyk (gelukkig is ek n elektrician)
Posted: Tue Nov 04, 2014 2:46 pm
by HUGO MYBURGH
Goodday to all.I have removed the timing cover and fiber gear is ok and it is not loose on the metal part.The timing marks are allinged when no 1 piston is at TDC.I then removed the right hand side head to see why i lost comp on no 6 piston but everything is ok.I noticed while stripping that the inlet manifold bolts were not very tightly bolted down,could this also cause backfiring through the carburator.thank you very much to all.
Posted: Tue Nov 04, 2014 2:58 pm
by HUGO MYBURGH
I took a few pictures of the engine as i dismanteled it,can i post them here and how do i paste them here,advise please
Posted: Tue Nov 04, 2014 5:48 pm
Pics need to re-sized to 800 x 600 ..... read here on how to do it all. ;-)
Posted: Wed Nov 05, 2014 11:24 am
by HUGO MYBURGH
AFTER REPLACING MANY PARTS TILL TODAY I COULDNT GET MY VAN STARTED, SO I DISMANTELED THE WHOLE ENGINE, TO MY SUPPRISE I COULD NOT Find ANY PROBLEM, I WOULD LIKE YOUR COMMENTS WHETHER YOU CAN SEE POSSIBLE PROBLEMS THANKS NEXT SET OF PHOTOS WILL BE POSTED SHORTLY
Posted: Wed Nov 05, 2014 11:41 am
by HUGO MYBURGH
HERE IS THE REST OF MY FORD V6 3L ANY COMMENTS PLEASE DOES IT LOOK OKAY OR NOT
Posted: Wed Nov 05, 2014 12:05 pm
by HUGO MYBURGH
MY TRUCK
Posted: Wed Nov 05, 2014 7:23 pm
by Family_Dog
Probably should have mentioned this sooner.... is there petrol in the tank? ;)
Posted: Wed Nov 05, 2014 8:04 pm
Just wondering .... I'm assuming that you didn't interfere with the valve timing (cam gear position) ..... :think:
Posted: Wed Nov 05, 2014 9:37 pm
by HUGO MYBURGH
Thank you to both dogs.The only thing that i found was that the inlet manifold bolts was not tightened properly(loose),could this cause backfiring through the carburator,the timing marks on the photo is like i found it lighned up with no 1 piston at TDC so the valve timing is ok,with the inlet manifold loose i would not have enough suction on the carburator .thus explaining why only no3 and 6 plugs were wet with feul and all the other plugs dry.what is the cold valve clearances and what is the torque settings for the inlet manifold and for the heads please.How do i change the fan idler bearing in the timing cover mine is noisy
Posted: Thu Nov 06, 2014 8:46 pm
by HUGO MYBURGH
ok guys i replaced the head gaskets and inlet manifold gaskets.set the tappets in sequance the valve timing is correctt the marks allign,the ignition timing is correct(checked by a ford mechanick)the carburator solenoids are ok they click when power is on.i suplyed direck power to the coil i also checked the earth wire to the manifold which is ok it startes but still backfires and wont rev.it only idels very rouhg rouhhly and back fires.please help
Posted: Thu Nov 06, 2014 9:18 pm
by 4x4BEES
Dirty fuel or carb??
Breather/supply lines to and from tank?
Posted: Fri Nov 07, 2014 8:22 am
by Skroppie
I also have the same engine in my Sheep
When I first bought it I had a similar problem where it would idle perfectly
but as soon as you increase the revs the power would drop, it would misfire, backfire and even get flames thrown from the exhaust
I replaced dizzys, point and condencer and serviced the carb, but nothing would change
After a while we noticed that playing around with the points gap made it slightly better but never got it right
Then I decided to change the points for the "elecronics" in this page
viewtopic.php?f=3&t=8302&p=90421&hilit= ... ord#p90421" onclick="window.open(this.href);return false;
This sorted my problem completely
Hope this helps
Posted: Fri Nov 07, 2014 5:08 pm
by HUGO MYBURGH
My van started.I put new points back with new condesor,it starts and idels fine but still backfires when accerating.thanks guys.will keep you updatedHelp please
Posted: Sat Nov 08, 2014 1:57 pm
by HUGO MYBURGH
Ok guys my van is RIGHT( it was the condensor)Thank you for all the inputs.the 3rd condensor.
Posted: Sat Nov 08, 2014 3:57 pm
:thumbup: :thumbup: good to hear! ;-)
Posted: Sat Nov 08, 2014 5:22 pm
by Froll
:thumbup: :thumbup: :thumbup:
Posted: Sat Nov 08, 2014 5:34 pm
by HUGO MYBURGH
Tank you to all concirned,i will never buy cheap points and condensors again,buy enchilin only.thanks for all your inputs
Posted: Thu Nov 20, 2014 3:32 pm
by HUGO MYBURGH
Hi guys its me again,i went to pietermaritzburg for a doctors check up and just before dundee on my way back to vryheid my van started to cut out and backfire until it came to a halt,upon checking what the fault could be i noticed that there is very little fuel coming through to the carburetor,it takes about 5min to fill a 2lt bottle is this enough for a v6 and can this cause a backfire situation please help i am desparate .thank you
Posted: Fri Nov 21, 2014 4:29 pm
by Scott
Have you got a manual or electric fuel pump as the V6 manual pump was known to overheat and stop pumping.
Posted: Fri Nov 21, 2014 7:46 pm
by HUGO MYBURGH
Hi Scott it,s a electric pump.I replaced it today and it,s pumping well now,but it is still not starting.I get a small spark from the coil(2nd coil)I supplyed 12v directly to the coil to see if it isnt a supply problem but its still a small spark,you have to hold the coil wire 1mm from the earth to get a spark,both coils do the same.can both new coils be defective
Posted: Fri Nov 21, 2014 7:59 pm
by The Legend
Hugo get away with that points,condensor,coil etc and switch over to electronic dizzy.Surely that will be the end of your problems.
Posted: Sat Nov 22, 2014 6:47 pm
by HUGO MYBURGH
Hi Lolli it was the points,will buy electronic i think it is pertnonic,where do i get it from :subscribed:
Posted: Sun Nov 23, 2014 11:43 am
by HUGO MYBURGH
Hi to all,i think that i found the recent problem,when i fitted a new electric feul pump i made the mistake of drawing power for the feul pump from the pos side of the coil,thus increasing the current through the points,causing the points to burn very quickly and not thinking it can be the points again and searching else where,thanks for all your inputs
Posted: Sun Nov 23, 2014 8:08 pm
by The Legend
Hugo
Ek is bly jou problem is uit gesortteer.Ek sal nietemin nogtans kyk vir n eletroniese dizzie as ek jy was.Dit is net soveel meer betroubaarder en maak dienste ook soveel makliker.
Posted: Tue Nov 25, 2014 9:37 pm
by HUGO MYBURGH
I am looking to purchase a new or good condition distributor red cap for my V6 1993, if anyone got one available please or where could i possibly try and get hold of one thanks :blackeye:
Posted: Wed Nov 26, 2014 6:56 pm
by HUGO MYBURGH
Hi guys what can you do to upgrade a 3l v6 essex motor to the max kilowatt for every day use(warm maak)Hope to hear lots of suggestions :mocking:
Posted: Mon Dec 01, 2014 9:45 pm
by 4x4BEES
Have you sorted out the current problems?
Voor jy dit warm maak, maak seker dit werk onder normaale omstandighede :twisted:
