Dawid's Hilux
- Town: Port Elizabeth
- Vehicle: 2009 Suzuki Jimny
- Real Name: Dawid
Dawid's Hilux
I have a 1996 2.8D DC Hilux which is being converted to a 3.0D at the moment. It is pretty standard still except for the OME leaf springs and the Rancho shocks.
2009 Suzuki Jimny (Mini Hilux)
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
- Niel
- Real Name: Niel
Re: Dawid's Hilux
Hi David
Welcome to the forum. The van looks in good condition.
- Vehicle: Hilux 2200 D/C AUS specs
Re: Dawid's Hilux
it looks great,welcome to the forum,enjoy the TOYOTA feeling
n vark bly maar n vark
Re: Dawid's Hilux
Hi Dawid,
Welcome here!
Let us know how the conversion goes.
Welcome here!
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
- Cookie Monster
- Real Name: Justin
Re: Dawid's Hilux
Hi Dawid
Welcome to the forum , You should join us some time to go and play
- Real Name: Dawid
Re: Dawid's Hilux
I finally got the bakkie back yesterday after 8 weeks.
I must say it was worth the wait. With the 5L motor, the driveability has improved so much. I drive much lighter on the gas pedal now, the response is much better and smoother. Slow corners in town can now be done in 3rd gear instead of 2nd as before. All the vital signs seems in order so far. The temperature is just below 90°C on the highway and steady on 90°C in town. I noticed 2 oil drops on the floor last night. Will monitor that. Hopefully it is just some spilled oil which is running down. Can't wait to fill the tank and monitor the consumption. My old 2.8D motor was rather thirsty.
Cost:
Motor - R16500-00
Fitment with oil, filter, timing belt, carry over of some parts + VAT: R4400-00
A rather expensive exercise, but hopefully worth it!
Cost:
Motor - R16500-00
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
- Real Name: Dawid
Re: Dawid's Hilux
Since the conversion was completed a week ago, I've only driven the bakkie for about 50km. As luck would have it, the alternator decided to give in the very next day. Fortunately is was the old alternator off the 3L motor. So I sent them the 70A alternator which came with the 5L motor. At 17h00 I phoned them to get a progress report (Friday afternoon), sorry it does not fit. I had to remind them that it originally came off that motor and that I probably still have the mounting bracket at home. So I dropped it off at the Garage Sunday night. Monday after work I went to collect the vehicle. Sorry, the bracket does not fit onto the chassis. :x
I went to the autolec to see for myself. Turns out that the bracket also forms the engine mounting and the angle to the chassis is different. The autolec wanted to overhaul the old one at between R350 - R800 since I won't find a suitable bracket. I then had a look in the Gregory's manual and there they showed both alternators. I phoned Taitsaam Spares the next morning and R80-00 later I had the bracket. Had it dropped off at the garage at 09h30 only to discover at 14h30 that the receptionist is still using it as a paper weight! :x :? :roll:
Anyway it now seems that the 'new' alternator will work and I should get the bakkie back this afternoon, hopefully! Got a new clutch master cylinder as well. I first need to clean up the firewall paint a bit and will then fit the master cylinder. Will try and put some kilos on this weekend.
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
Re: Dawid's Hilux
Hi Dawid,
Auto Electricians seem to be much the same everywhere, no more pride in their work. Luckily, you can still find the odd Auto-Elec who does take pride in his work.
Please post some pictures of your engine in this thread:
viewtopic.php?f=8&t=24
Enjoy your Hilux!
Enjoy your Hilux!
- Real Name: Dawid
Re: Dawid's Hilux
Ok I'll do so as soon as I have it back during daylight.
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
- Vehicle: '96 D/C Raider
- Real Name: Bennie
Re: Dawid's Hilux
Yis Dawid I hope your troubles is now a thing of the past.
- Real Name: Dawid
Re: Dawid's Hilux
I posted photos of the engines before and after. Not much difference in looks but an improvement on the performance. Now to get that rear crankshaft oil seal leak sorted out...
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
- Cookie Monster
- Real Name: Justin
Re: Dawid's Hilux
The photos look good Dawid
- Cookie Monster
- Real Name: Justin
Re: Dawid's Hilux
So Dawid when are we all going to get together and go play
- Real Name: Dawid
Re: Dawid's Hilux
Wish I knew! :roll:
I should have the oil leak sorted out this week. I need to drive it a bit to make sure everything is tightened and fitted correctly. Found a hose for the alternator as well. Another dealer had one in stock. 8)
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
- Marius Murray
- Vehicle: Nissan Patrol
- Real Name: Marius Murray
Re: Dawid's Hilux
Cheeky!marius safari wrote: Isnt oil leaks limited to Landys only?
Maybe Dawid is a LR "wannabe"!
Anyway, welcome to the forum, Marius!
Remember to post your details in the Member's Rides & Meet the People sections!
(Hey Guys, I think we've got a "Nissan Spy" in our midst! )
- Niel
- Real Name: Niel
Re: Dawid's Hilux
FD, net so goed soos n blou bul supporter
- Marius Murray
Re: Dawid's Hilux
I own a Nissan Patrol, but work at Toyota Automark for the last six years. If the Cruisers were cheaper i would have owned one. But my 1982 Datsun does fine. Its also SFA!!!!
Marius Murray
SOLD PAMPOEN.
SOLD PAMPOEN.
- Niel
- Real Name: Niel
Re: Dawid's Hilux
Agreed.marius safari wrote:If the Cruisers were cheaper i would have owned one.
FD was buying but somewhere it alll went wrong :x
Re: Dawid's Hilux
Actually, it's still on order, but I'm also wondering if the model won't be out of fashion by the time it arrives! Marius, why didn't you join the forum sooner, I could have ordered through youNiel wrote:Agreed.marius safari wrote:If the Cruisers were cheaper i would have owned one.
- Niel
- Real Name: Niel
Re: Dawid's Hilux
You snooze you loose 8)
Re: Dawid's Hilux
Must admit I'm not pushing for it, I specified the "desert beige" colour. I *think* it the colour code 4R3, but it *might* be the colour code 4E9.
Marius, what would the correct colour code be for the light beige, almost the same colour of butter? The 4E9 looks dark on the Toyota Website, but the "Beige Mica Metallic" makes me wonder if this is the correct color after all. I am after the same colour that appeared on the SA4x4 magazine
Anyway, the longer I wait for it, the better the chances of Toyota deciding to bring out a Turbo-powered model...
( PS: Don't let Benhur see this... )
- Real Name: Bennie
Re: Dawid's Hilux
Oppas ek watch jou :!: :!:
- Real Name: Dawid
Re: Dawid's Hilux
Got the bakkie back yesterday to my surprise. Was expecting it later in the week. They only replaced the oil pressure sensor and some washers on the oil pipe banjo connection. They didn't replace the crank seal. No charge and told me to check it out. Went home and fitted the new alternator hose. Took 5 mins and while I was underneath the bakkie, I noticed a few drops of oil hanging on the bottom of the oil filter. This then drips onto the oil pressure sensor and further down onto the banjo connection. This made me think they did not find the fault. I then loosened the filter (which was overtightened I think) and hand tightened it. Wipe all the oil and went for a short drive. This morning the floor seemed clean. Holding thumbs that the leak is now sorted.
PS:Maybe Dawid is a LR "wannabe"!....been there...done that... :D
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
- Cookie Monster
- Real Name: Justin
Re: Dawid's Hilux
Well good luck Dawid
Re: Dawid's Hilux
Aahhh... now I understand! The Hilux "smells" that there was another vehicle there, and is now marking its territory! My dogs do the samePS:Maybe Dawid is a LR "wannabe"!....been there...done that... :D
