SFA Hilux built for Mach 3
Hi All,
I was just reading up on the SR 71 BlackBird (a mach 3+ aircraft), and found this rather interesting...
"To allow for thermal expansion at the high operational temperatures the fuselage panels were manufactured to fit only loosely on the ground. Proper alignment was only achieved when the airframe heated due to air resistance at high speeds, causing the airframe to expand several inches."
This means that the old SFA Hilux was probably also built with these speeds in mind?
Re: SFA Hilux built for Mach 3
Think you could be on to something there Ewald
What did it say about "breaks" then
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
I've had mine on Mach 2 (200km/h) and i can assure you the gaps grow even larger and the wind noise is deafening, stopping it is another story!
Still far too slow for proper expansion to be achieved... You must do at least 2000kmh plus...
The 4Y will never do this...????
- mushroom
- Town: krugersdorp
- Vehicle: '16 Legend 45 DC 4x4M
- Real Name: James
I somehow think Jeremy Clarkson would find it easier to kill the fighter jet than a Hilux (well, he couldnt even get that right)
Q20 if its stuck, duct tape if it moves
Yes it can ... but it will probably get burnt to a crisp by the after burner of the Blackbird....DOELLOOS wrote:Still far too slow for proper expansion to be achieved... You must do at least 2000kmh plus...
- Hoppy
Maybe he should tow one behind a jet and improve the aerodynamics!
Well, they built 32 of these, of which 12 apparently had breakages, and ended up crashing... (because they didn't use the 4Y engine, but then the speed would've been a problem...)Dadz Toy BFI wrote:Think you could be on to something there Ewald
They didn't say anything about the BRAKES....
Well, if they could fit a boat engine on the back of a Hilux, surely they could fit a Jet engine???CasKru wrote:Yes it can ... but it will probably get burnt to a crisp by the after burner of the Blackbird....DOELLOOS wrote:Still far too slow for proper expansion to be achieved... You must do at least 2000kmh plus...
Met of sonder diff loc?DOELLOOS wrote:Well, if they could fit a boat engine on the back of a Hilux, surely they could fit a Jet engine???CasKru wrote:Yes it can ... but it will probably get burnt to a crisp by the after burner of the Blackbird....DOELLOOS wrote:Still far too slow for proper expansion to be achieved... You must do at least 2000kmh plus...
You're getting silly nou nê :wth:
It would have TWO 4Y Engine's man = real power
Sonder agterklap...
- Jet.jpg (31.55 KiB) Viewed 1773 times
- mushroom
- Town: krugersdorp
- Real Name: James
I reckon better fuel efficiency out of the jet engine than the 4Y :D
- Town: 11
- Vehicle: 111
- Real Name: Hannes
Traction gaan 'n probleem wees
But no match for the 22Rmushroom wrote:I reckon better fuel efficiency out of the jet engine than the 4Y :D
Hmmm.....ja, instead of applying brakes all you do is shut the tailgate?! :wth:
- Hoppy
I'll opt for a sunroof and a parachute!
- Town: Cullinan
- Vehicle: Ford :Toyota
- Real Name: Barry
- Club VHF Licence: HC237
Hoppy where did you get that mineshaft??? :D
Wat ek is is net genade
Wat ek het is net geleen
- Hoppy
It had a Celica Supra 3.0 Turbo motor at that stage(the pic on the left), it could do 200 on an uphill with one gear to go, i took it out before it killed me.
- Spartan
- Town: Vanderbijlpark
Watter een die 2JZ GTE twin turboHoppy wrote:It had a Celica Supra 3.0 Turbo motor at that stage
MOBILITATE VINCERE
Spartan
Spartan
Wat maak dit nou saak????? Weet Krygkor dat die Hilux eintlik 'n Mach 3+ cockpit sonder vlerke en enjin is?????
Ons moet nou vlymskerp wees boys, hierdie bakkies gaan nog GROOT geld werd word....
