SFA - D4D Modification (Seats)
Black Sam
Town: Mtunzini
Vehicle: Nissan Navara Pro 4x
Real Name: Gerrie
Post by Black Sam »
Has any tried to fit the complete D/Cab seats and centre console of a D4D into a SFA :?:
Dewald Posthumus
Vehicle: 2008 Toyota Hilux 3.0D4d 4x4
Real Name: Dewald
Re: SFA - D4D Modification (Seats)
Post by Dewald Posthumus »
Should not be too difficult, I remember fitting 2000 model Hilux bucket seats into a 1994 single cab Hilux with no real issues, had to replace the safety belts as well and a bit of bending of the front brackets..
Post by CasKru »
Gerrie... hoe lank is jy? Ek het op 'n stadium die 2.7 IFS se seats in my van gehad en my kop het aan die dak geraak. Dit maak ook die in en uitklim moeiliker.
Maddoglips
Town: P.E.
Vehicle: Raider 2.2 4x4; Mikem 50mm raised suspension, long range tank, Monroe gasses all round.
Real Name: Zane
Post by Maddoglips »
Gerrie
I had a set of D$D seats in my SFA, they fit very easily with only having to drill 2 holes.
Like Cassie said , however, you do sit abit higher, I'm 6ft3 and my head would only slightly.
I looked at it, and it aint a prob to lower the seats either, just a tad bit of fiddling, but easily do able.
I have the seats still if you are interested, how evr I am in PE.
Cheers Zane
Black Sam
Town: Mtunzini
Real Name: Gerrie
Post by Black Sam »
Thanx Guys I'm gonna try that,
Cassie ek is so 1.90m so sal ook bietjie sukkel.
Ek het 'n volledige stel seats voor en agter met die center console en wil als maak pas. Ek wil die V6 Hilux auto gearlever gedeelte ook inbou vir die lexus, ek is nie mal oor spitstronic se gearlever nie te hakerig :thumbup:
Dewald Posthumus
Real Name: Dewald
Nou onthou ek, ek moes die sitplekke se brackets bietjie sny en gate maak omdat hulle te hoog was, maar in my geval het ek in die eerste plek nie eintlik in die single cab gepas nie! Ek is 2.03m lank en slag so 150kg uit! Pas in niks nie!
Black Sam
Town: Mtunzini
Real Name: Gerrie
Post by Black Sam »
Ek weet hoe jy voel Dewald, ek het dieselfde probleem as 'n ding nie hoog is nie sukkel ek on in en uit te klim :laugh2: :laugh2:
Post by CasKru »
Black Sam wrote:Thanx Guys I'm gonna try that,
Ek self is 6' en dit het my gepla :shifty:
SKRIK NIKS
Town: krugersdorp
Vehicle: hilux 3.0kzte
Real Name: jan venter
Post by SKRIK NIKS »
Ek soek so stel D4D leer seats wat ek in my Ifs wil sit
Of gewoone Ifs leer seats
SKRIK NIKS
Black Sam
Town: Mtunzini
Real Name: Gerrie
Post by Black Sam »
Die modifikasie is klaar en ek moet se dit sit baie gemaklik, Bushwacker het soos gewoonlik weer gehelp en dit 'n groot sukses gemaak.
Die standaard brackets is afgesny en laer gemaak nou raak ek nie die dak nie.
Het sommer ook gou al my water outlets binne geinstaleer.
(142.58 KiB) Downloaded 194 times
(146.79 KiB) Downloaded 194 times
(122.72 KiB) Downloaded 194 times
(103.18 KiB) Downloaded 194 times
(112.28 KiB) Downloaded 194 times
Black Sam
Town: Mtunzini
Real Name: Gerrie
Post by Black Sam »
Close ups van die bracket changes :thumbup:
(115.29 KiB) Downloaded 192 times
(122.57 KiB) Downloaded 192 times
(132.35 KiB) Downloaded 192 times
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Lyk flippen mooi Gerrie.Moet se ek like daardie idee van jou om die floorboard te rubberrise. :thumbup:
Black Sam
Town: Mtunzini
Real Name: Gerrie
Post by Black Sam »
Ja Dawie dit maak die skoonmaak soveel makliker, en jy hoef nie die heeltyd voete aftevee as jy in die modder was nie, as ek klaar is vir die dag spuit ek hom met die tuinslang uit en droog af. :thumbup:
The Legend
Real Name: Dawie
En dit beskerm jou floorboard teen roes :thumbup:
Return to “Open Discussion”
