Spray painting - Requirements?
I want to get myself a descent compressor for general use and spray painting (automotive type of spraying). What is the minimum tank size and air flow rate I should look at. I would like to pay as little as possible but also know that penny wise, pound foolish.
So I just want to get the correct "balance"
Also, when buying a spray gun, gravity feed or suction feed?
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
Re: Spray painting - Requirements?
i have a gravity feed de-vilbis (R700) about a year ago and it works great for general use.
they say 200L is minimum. i'm using a 50L ABAC for the last 5 years and hasn't given me a days trouble.
i want to go to a 280L 3 Phase ingersol rand, because i want to use more air tools, but those are R16500 now
Thank you sirTarquin wrote:i have a gravity feed de-vilbis (R700) about a year ago and it works great for general use.
I have an Ingersol Rand 100lit and a 50lit for carting about if I need to. The 100lit copes fine with continual spraying, even do small sand blasting jobs with it and it's worked 23yrs for me without any hassles .... I once had to top up the crank oil, took less than 100ml. Otherwise I only clean the air filter .... still has the original belt on it. The 50lit is less than a year old and I've sprayed successfully with it, no problem.
I have both gravity feed and suction ..... prefer the gravity feed, but if it's a bigger job then I use the suction because it has a larger capacity. Usually spray at about 2½ bar with the gravity and about 3 - 3½ with the suction. You can achieve a little bit finer mist with higher pressure but you get quite a bit more over-spray .... just wastes paint.
Many of the smaller compressors don't provide an unregulated take-off or a water trap. Try get one that has those things .... if no water trap, you can always fit one .... essential for automotive quality spraying.
- blom
- Town: Landrovia
- Real Name: Blom
cas
op die compressor is jy op jou eie
maar spraygun gravity fed nothing else. 1.4mm nozzle en jy kan maar die cheapies koop hulle werk lekke
Grensvegter van LANDROVIA
- Oupa Stig
- Town: Johannesbug
- Real Name: Mickey
Baie belangrik vir spraypainting:
Tandeborsel
Listerine.
Skrop jou bek goed voor jy begin spray, want as jy 'n ordentlike "gas masker" dra is die eerste ding wat jy in-asem die vorige uit-asem....
En spandeer maar bietjie tyd om daai gun agterna mooi skoon te maak, anders vind jy hier by die derde keer as jy hom gebruik dat hy nou nie meer so netjies sprei nie.
Spray painting is 'n kuns wat my bemeester het. Met die hoeveelheid runs wat ek kry moet ek krieket gaan speel vir die Proteas.
Tandeborsel
Listerine.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Nevermind die kompressor! Die belangrikste is n goeie kwaliteit gesig masker. Die soort met vervangbare lugfilters.
Die rede hiervoor is dat motorverf "hardner" in het (2k tipe verf). Dit is soos sement, m.a.w. die proses hou aan gebeur ten spyte van hitte of koue en as mens genoeg daarvan inasem, gaan jy ernstige asemhalingsprobleme opdoen!
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Froll
- Town: Vioolsdrift
- Real Name: Roger
- Club VHF Licence: N/A
Built my own compressor about 5 years ago. Used a big handy gas bottle, 2.2 Kw motor and a twin cylinder head. Works very good, cant remember the costs but it was around R4500. New compressors at that stage were about R6500. I use mostly a gravity feed spray gun, works much better when spraying a roof as the h/p gun tends to touch the roof when spraying. I would rather use a bigger compressor and have too much air than have to wait for air to build up.My opinion.
- Piesang
- Town: Grabouw
- Real Name: Pieter Pieterse
Ek het die fout gemaak om net gou in die toe garage net 'n 10x20cm plaat clear coating te gee vir toets sonder om my masker op te sit, was vir 4 dae op kronies medikasie vir asma .Polarbear2008 wrote:Nevermind die kompressor! Die belangrikste is n goeie kwaliteit gesig masker. Die soort met vervangbare lugfilters.
Ek het met 'n beperte budget 'n 25lt kompresor gekoop, maar die een met die selfde kop as die 50lt, agterna toe daar nog 'n paar rand was 'n 2de handes 25lt tenk gekry en die een bo-op die ander gesit en gekoppel, raak nie somme uit lug nie. Ook 'n gravity gun, net die fout gemaak om my druk te hoog te stel, toe kry ek dat hy verf uit druk waar hy nie moet.
Thank you all for the replies. Now I can at least make much more informed decisions when purchasing the equipment.
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
Look on the junkmail...CasKru wrote:Thank you all for the replies. Now I can at least make much more informed decisions when purchasing the equipment.
I picked up a 150ltr compressor in good condition for R600 and it works like a bomb.....
[rimg=206x128]
[rimg=206x128]
Bad choice of words when talking about compressors!MOFASA wrote:Look on the junkmail...CasKru wrote:Thank you all for the replies. Now I can at least make much more informed decisions when purchasing the equipment.
But seriously, they need to be checked, tank needs to be inspected .... condensation inside (even though vented) causes rust errosion of the walls, especially at the bottom where it lies. Can cause a tank to rupture and blow up if the errosion is deep enough. So beware of older 2nd hand units.
I have a gravity feed spray gun and one of them very small compressors, think it is 50 litres. Works fine for me, sometimes it even switches off while I am spraying. Has been using it to spray everything I built and about 8 years ago even sprayed my Golf Bakkie with it. I like the small size because it does not take up much space in the garage and I can take it anywhere I like with ease.
