hilux sweef oor die pad na nuwe bande
3.0 D4-D
Town: ofcolaco
Vehicle: fortuner 3.0 D4-D,hilux 2007 V6 4x4
Real Name: ben
Post by 3.0 D4-D »
Middag Almal
Ek vandag nuwe bande laatopsit en al die nodige laatdoen soos balenseer en alignment.Toe ek later op die oop pad kom voel dit of die bakkie sweef op die pad teen hoer spoed as wat in die dorp gery is.Die stuurwiel is reguit en voertuig trek nie na n kant nie,as ek stuurwiel los loop voertuig mooi reguit.Ek het band druk gekyk en soos ek altyd gepomp op 2.2 bar maar dit voel nogsteeds op voertuig sweef.ek het eers BF GOODRICH A/T 31 10.5 R15 op bakkie gehaad en na 70 000 km hulle vervang vandag met BRIDGESTONE DUELER A/T 31 10.5 R15.
enige raad sal welkom wees
Groete
Ben
TOYOTA,NET DIE BESTE IS GOED GENOEG
2004 kzte 4x4 rip
mossie89
Town: Paarl
Vehicle: Toyota Hilux D/C 4x4 4.0 v6
Real Name: Riaan
Re: hilux sweef oor die pad na nuwe bande
Post by mossie89 »
ek het die selfde probleem gehad toe ek van BFs
A/t na Kumo M/T toe gegaan het maar jy raak dit gou gewoond. n Mens raak seker gewoond aan die B/Fs se stywe 3 ply side wall en nou voel dit of jy oor die pad sweef met die 2 ply side wall bande
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Club VHF Licence: HC105
Post by Thunder02 »
Ben, may I ask why 2.2 Bar?
Scout motto:be prepared....
www.4x4direct.co.za
3.0 D4-D
Town: ofcolaco
Real Name: ben
Post by 3.0 D4-D »
Dankie vir info Mossie.
Thunder.I have a 2009 fortuner also on Dueler tyres.the tuna's tyres is also pumped at 2.2 bar.The tuna got 200 000 km on the clock and I Get close to 90 000 km on a set of tyres.Also I do not get uneven tire wear at all.Toyota said that it should be pumped 2.1 but i have been pumping it from day 1 at 2.2 bar
2004 kzte 4x4 rip
Post by CasKru »
Keep in mind that for the first 200 to 500km the tyres still have there no stick coating which they use to get the molded tyres out of the molds. This will definitely have a effect on grip.
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Post by Thunder02 »
3.0 D4-D wrote:Dankie vir info Mossie.
Thanks Ben, I run mine at 2.6 bar,hence the question. I must add I'm heavy loaded at all times. :thumbup:
www.4x4direct.co.za
Post by pietpetoors »
Did they do a proper job on the alignment?
I also use 2.2 bar without a load and find it to work fine for me on BF KM2 MT's. I don't know the duellers, but what Riaan about sidewall stiffness said makes some logical sense, - whether this is the reason or not might be debateable.
Kagiso
Vehicle: Datsun SAFARI aka LOBO, Nissan Patrol GQ
Real Name: Mac
Post by Kagiso »
Ry jou nuwe Dueller met 2,6 bar druk die eerste 1,000 Km dan kom jy af na 2,0 bar of wat vir jou gemaklik is.
Die Dueller het meer buigbare sywande en sal aanvangklik meer "meegee" in die smeergroewe in die pad volg. Dit voel soos sweef. [Die Patrol doen dit ook met die Cooper STT's maar baie minder met die Khumho . ]
Outreach2Africa - In support of Missionaries of Africa: Helping God's children doing God's work.
on't bring God down to your level of faith ... bring your faith up to His level!
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
I recently changed from BF's to Gabbers. Old Swartvark also feel very light and loose on the road...weird feeling.
I guess it is a combination of all above.
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Ek het die nuwe generasie (697) Duelers op my bakkie en kan glad nie kla dat hy sweef op die pad nie.
Jaws
Town: Sharonlea
Vehicle: 2009 D4D 4x4
Real Name: Herman
Post by Jaws »
Die is definitief wielsporing, my doen dit ook nou nadat TWT die wielsporing gestel het. Dieselfde bande was perfek voorheen
:thumbup:
Post by Thabogrobler »
The Legend wrote:Ek het die nuwe generasie (697) Duelers op my bakkie en kan glad nie kla dat hy sweef op die pad nie.
Sekerlik sal SFA eienaars dit nie voel nie!!
'n Kombinasie van standaard los gevoel op die pad en geen vermoe om meer as 100km/h te haal nie!!
:blackeye: :tease:
The Legend
Real Name: Dawie
:laugh2: :laugh2: :laugh2: Thabo my SFA kan met gemak 120 km op die oop pad doen en nog steeds het ek geen probleem dat hy sweef oor die pad nie.Selfs as ek die stuurwiel los op 120 km loop hy soos op spore reguit in n lyn.
Return to “Open Discussion”
