Anyone replaced Toyota Tazz tie-rods and tie-rod ends ?
KZTE Nut
Vehicle: Hilux KZTE DC 4x2
Real Name: Mervyn
Mon May 08, 2017 6:31 pm
I need to replace the tie rods and inner tie-rod ends on a Toyota Tazz. Anyone done this and give some advice or can recommend a mechanic in the Jhb or Eastern suburbs area ? I would do it myself but it looks like you need a special tool to loosen and tighten the inner tie-rod end :frustrated:
Rigger
Town: Oudtshoorn
Real Name: Martiens
Tue May 09, 2017 3:36 am
If you are mechanically challenged then better take it to a mechanic. Otherwise, no special tool required. Good old pipe wrench (bobbejaanspanner) and you are good to go. Thery are usually very tight and you should tighten them again very tight with some thread locker. And then mark the old tie rod ends before taking them off so that when you reassemble the tow in is not too far off so that you can drive to a service centre who can adjust the wheel alignment for you. Good luck
Dingo
Real Name: Scott
Tue May 09, 2017 7:09 am
You can buy the parts loose from Midas / Toyota / etc and take them with to the alignment shop, ask them to replace and do alignment all in one go.
KZTE Nut
Real Name: Mervyn
Tue May 09, 2017 11:43 pm
Thanks chaps !
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Wed May 10, 2017 7:41 am
+1
Most alignment places do it these days....even control arm bushes are press fitted right there & then
Return to “Open Discussion”
