Looking for capacitor
dalkill
Town: Cape TOwn
Vehicle: 2007 3.0 d4d DC 4x4
Real Name: Shaakir
Mon Aug 28, 2017 9:22 am
trying to save skoonsus LCD tv.
looks like power supply board busted. Samsung don't sell the board. They want you to bring it in for them to repair and will charge you arm and leg no doubt.
so i took out few components that looked dodge. got the diodes but cannot find capacitor.
68uf / 200V. Am i right to say you can actually go slightly higher for the voltage? what is the max? or should you stick to the same. Where could i find one of these? Mantech and communica don't stock it.
TOYOTA IS MY LEWE
James S
Vehicle: Hilux D4D Auto
Real Name: James
Mon Aug 28, 2017 12:30 pm
Mon Aug 28, 2017 7:04 pm
You can also try RS Spares, nothing special about that value. You can go higher voltage but just make sure the higher voltage one fits the PC board.
http://za.rs-online.com/web/c/passive-c ... 3230307626
dalkill
Town: Cape TOwn
Real Name: Shaakir
Tue Aug 29, 2017 7:56 am
thanks Guys.
I'll order from RS online rather than the one James suggested as it seem local, so delivery time should be in days rather than months.
TOYOTA IS MY LEWE
James S
Real Name: James
Tue Aug 29, 2017 9:11 am
If ex-stock at Digi-Key US, they can ship same day.
KZTE Nut
Town: Johannesburg
Vehicle: Hilux KZTE DC 4x2
Real Name: Mervyn
Tue Aug 29, 2017 7:15 pm
You tried testing the suspect capacitor ?
dalkill
Town: Cape TOwn
Real Name: Shaakir
Wed Aug 30, 2017 10:50 am
no.
was not to sure how to reliably test it with standard multimeter. conflicting reports say you need special capacitor meter to accurately test...
it was bulging at top, and had slight rust marks... at R10 each.. better just to replace it.
TOYOTA IS MY LEWE
Wed Aug 30, 2017 6:53 pm
You could also replace all the other electrolytics as well, they're cheap enough. Use the correct resin-cored solder - usually wound on a red spool, and not acid-core - usually on a black spool. Ensure you get the polarity correct when replacing caps, otherwise the smoke escapes rather violently.
Testing for capacitance values is not good enough: One needs to measure the ESR (equivalent series resistance) because this can increase with age and cause problems.
Return to “Open Discussion”
