Sideshaft for Hilux Imported Diff.
Looking for something? Ask for it here.
scott west
Vehicle: 93 Hilux
Real Name: Z
ORRA Call Sign: HC 117
Tue Apr 11, 2017 8:48 am
I need a right sideshaft for a rear imported Diff .
Mine is damaged where the bearing is pressed onto the shaft and is leaking oil.
Do anybody know where I can get one.
Thanks.
Z
'93 Hilux 4Y EFI
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Tue Apr 11, 2017 9:34 am
Toyota usually still carry the spares, otherwise N1 4x4 in Pretoria
Happy trails
Nic
SFA '87 DC "Rooies"
The Legend
Real Name: Dawie
ORRA Call Sign: X93-
Tue Apr 11, 2017 4:33 pm
Gemini Johannesburg
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
ORRA Call Sign: X248
Thu Apr 13, 2017 7:10 am
Contact Barry Drenth on this forum.. got mine from him.
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
scott west
Vehicle: 93 Hilux
Real Name: Z
Tue Apr 18, 2017 11:04 am
Can anyone please confirm if this is the correct sideshaft for hilux imported diff.
Side Shaft L&r Suits Yn65 -930
Thanks.
Z.
'93 Hilux 4Y EFI
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Tue Apr 18, 2017 12:35 pm
Look up Allen (Hoppy) on the forum, he'll know for sure
Happy trails
Nic
SFA '87 DC "Rooies"
Wayne
Vehicle: Hilux 2.7 4x4
Real Name: Wayne
Wed Apr 19, 2017 3:17 pm
Are you sure that it needs to be replaced.
The oil seal runs on a ring that is pressed on next to the ABS ring.
Sometimes the ring is pushed too far and the oil seal cant seal.
Hoppy can confirm this
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Wed Apr 19, 2017 5:40 pm
ABS? Not on the SFA Hilux. The oil seal on the front axle is a raised section on the axle. Mine was leaking because the seal had worn a groove in the mating surface. I had it welded up and then turned back down to the correct OD.
Happy trails
Nic
SFA '87 DC "Rooies"
scott west
Vehicle: 93 Hilux
Real Name: Z
Thu Apr 20, 2017 8:22 am
More or less what had happened to mine and will also be fixed by welding and turning.
Thanks guy's for all the comments and info.
Z.
'93 Hilux 4Y EFI
Return to “Wanted”
