Toyota Corolla Cambelt snapped
Other Toyotas like Twin Cam Corolla, Tazz, RunX, etc
Donkey
ORRA Call Sign: X122
Mon Feb 10, 2014 7:47 am
So on my way to work this morning, just as I onramp onto the N3 old trusty broke his cambelt :cry: , shift starts @ 07:00 so I sent supervisor SMS to notify my late coming. AA was called at 06:36 and by 07:45 platkar was on a flatbed heading home :thumbup: how's that for service?
Anyway after work today will strip and clean the engine, as I'm also day shift tomorrow, will install new cambelt on Wednesday and I just hope I didn't bend any valves.
Tumelo Maketekete
ORRA Call Sign: B15
Mon Feb 10, 2014 7:56 am
Sorry to hear of your troubles Tumelo. If you have the 1600 4AFE/4AGE motor all should be fine as it's a non-interference motor. If it's the 1300 (think 2E motor) you might have a bit of a problem
werewolf
Vehicle: Toyota Hilux 1991, 50mm lift suspension, Rear E-Locker
Mon Feb 10, 2014 8:01 am
CasKru wrote:Sorry to hear of your troubles Tumelo. If you have the 1600 4AFE/4AGE motor all should be fine as it's a non-interference motor. If it's the 1300 (think 2E motor) you might have a bit of a problem
Yip you right, any of the 4A motor do not bend valves, so Donkey if you have 4AFE or 4AGE or 4AF or the older 4A 8 valve you are ok, but if you have a 1300 (2E) I am sorry for you it does bend valve and break rockers.
Mon Feb 10, 2014 8:12 am
Hope it is not too serious boet
Donkey
Mon Feb 10, 2014 10:16 am
I have both motors, the 4A-GE (TwinCam) has once snapped a belt before, with no hassles. This one in point is the FE, thanks guys.
Tumelo Maketekete
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
ORRA Call Sign: HC105
Mon Feb 10, 2014 10:51 am
Sad news, hope you get sorted soon, lekker engines to work on :thumbup:
Scout motto:be prepared....
www.4x4direct.co.za
Email: neil@4x4direct.co.za
Donkey
Mon Feb 10, 2014 10:56 am
:thumbup:
Tumelo Maketekete
Pote
Town: Hartbeespoort
Vehicle: Fortuner D4d 4x4 & VW Passat
ORRA Call Sign: X228
Mon Feb 10, 2014 11:55 am
Thunder02 wrote:Sad news, hope you get sorted soon, lekker engines to work on :thumbup:
My first one I didn't think so. I was used to the VW engine and then this one (1.3L 12 Valve) the cam timing mark buggerd me around.
Donkey
Wed Feb 12, 2014 8:20 pm
Today bought timing/cam belt. Vehicle jacked and supported on stands, front driver side wheel off. Have never worked on this car so don't know where the marks are. Anyway, alternator loosened and fan belt inspected and removed. Loosened 4 x 10mm nuts to remove head cover. Afterwhich I could find the cam timing marks.
Below, on the block, is a timing dot also. I figure this should align with the mark on the cambelt pulley.
Can someone please confirm.
On the bigger crank pulley there is also a mark, this is the pulley that runs the fan belt, power steering pump and aircon pump, though I do not have these, this mark is the one for advancing or retarding timing. :think: It aligns to the marks on the lower cambelt cover with zero and ten degrees on it.
Is this 100%?
Tumelo Maketekete
Donkey
Wed Feb 12, 2014 8:24 pm
Had to come to work, will see if I can do it tomorrow.
Oh culprit for the snapped belt was a engine mount bolt that came loose and fell to the bottom of side and as did so cut the belt and rested on the bottom by the small crank timing pulley :aggresive:
4AFE snapped cambelt.jpg (60.83 KiB) Viewed 3072 times
4AFE Crank timing.jpg (56.29 KiB) Viewed 3072 times
4AFE Cam timing.jpg (55.62 KiB) Viewed 3072 times
Tumelo Maketekete
Town: Bellville
Vehicle: Langpad (RAV4)
Wed Feb 12, 2014 8:58 pm
valves ??
have you checked if it turns over freely and compression ratio ?
Donkey
Wed Feb 12, 2014 9:00 pm
It turns freely and I suspect no bent valves. How do I check compresion ratio? I guess there's a tool for that? :think:
Tumelo Maketekete
ORRA Call Sign: B15
Wed Feb 12, 2014 9:22 pm
Hey Tumelo... you really don't have to worry about the valves or anything else. Just line up the marks, fit the belt (and maybe tensioner seeing that you already have it open) and bobs your uncle.
Friend of mins had the same thing happen to him and after installing the new belt all was fine again
werewolf
Wed Feb 12, 2014 9:23 pm
4AFE does not bend valves. From the photo the timing mark is right. You can also check to if the 2 timing marks on the gears also line up. Look at the back of the cam gears.
Donkey
Wed Feb 12, 2014 11:27 pm
Thanks guys, will feedback soon, :thumbup:
Tumelo Maketekete
Thabogrobler
ORRA Call Sign: x223
Thu Feb 13, 2014 8:24 am
My guess woukd be cambelt on 0 degrees and timing set on the 10 degree mark?
Donkey
Thu Feb 13, 2014 8:10 pm
Thabogrobler wrote:My guess woukd be cambelt on 0 degrees and timing set on the 10 degree mark?
That plastic cover comes off, exposing a small toothed crankpulley, on the lip of this pulley is a mark, which I lined up with the dot on the block (12 o'clock position). Cam timing was easy to figure out.
After the belt was replaced, I turned the engine to ensure all marks lined up. All was in order. While at it a new tensioner was put in, and I noticed the lower engine mount was broken, this too was replaced. Having put everything back in order, it started first time without hesitation. It is still on stands as I want to wash off dirt at the bottom of the engine tomorrow.
Thanks to all for your input. I'm actually chaffed with myself right now :yahoo: :dance1: :excited: :excited: :excited:
Tumelo Maketekete
Town: Bellville
Thu Feb 13, 2014 8:30 pm
nicely done ! :)
Froll
Town: Vioolsdrift
Vehicle: 1995 2,4 D/C Hilux SFA 4X4 , 2010 4.0 V6 Fortuner 4x4
Real Name: Roger
ORRA Call Sign: N/A
Thu Feb 13, 2014 8:34 pm
:clap: :clap: :clap:
ORRA Call Sign: B15
Thu Feb 13, 2014 8:56 pm
Excellent... give your self a pat on the back
Sun Feb 16, 2014 11:35 am
:yahoo: :celebrate: :yahoo: :celebrate: :yahoo:
Awesome boet, glad all is okay :thumbup: :thumbup:
Return to “Other Toyotas”
