Mobile Antennas - Mounting Instructions
Repcom Communications
Wed Apr 22, 2015 11:03 am
Mobile Antennas – Installation Instructions
Packing List
1x Antenna base and RG58 cable and PL259/6 connector,
1x Whip or coiled whip,
1x Plastic packet with cover nut,
1x Plastic packet with either a SS10 spring / open loading spring or whip adaptor,
M6 x 10 button head screw, M6 spring washer, allen key and whip tip.
STEP 1: Remove antenna from package.
Make sure all parts are available and there is no physical damage.
STEP 2: The antenna is designed for mounting on a flat surface.
The whip can be mounted in an upright position.
STEP 3: Mounting: (See Fig.)
Mobile Antenna Swivel Base.jpg (22.01 KiB) Viewed 1477 times
Drill/cut a 19mm hole on a flat surface. Feed the cable through the hole
followed by the antenna base.
Secure base with cover nut. (Use 27mm spanner.)
STEP 4: Secure whip to the base, using M6 x 10 screw and spring washer.
(See Fig.)
Adjust whip to an upright position.
Tighten screw with 4mm Allen key.
STEP 5: Run coaxial cable via shortest route to radio.
Cut off any excess cable.
Terminate cable using the appropriate coaxial connector.
PREPARING THE PL259 CONNECTOR:
PL259 Connector.jpg (5.83 KiB) Viewed 1477 times
Trim and bare the Antenna cable as in the sketch below. Screw the braided, stripped cable into the Antenna Connector firmly, then solder the inner cable to the centre pin of the Connector pin, taking care not to short it out.
Trimming RG58 Cable for PL259 Connector.jpg (12.98 KiB) Viewed 1477 times
PL259 Cross-section.jpg (48.94 KiB) Viewed 1477 times
PDF DOWNLOAD:
Wed Apr 22, 2015 2:55 pm
Guys, the standard Zara60 type antenna is supplied with four metres of antenna cable. If you wish to use a roof console, you will need a longer cable.
We now carry two Zara60 antennas, one with the standard four metre cable, but the other will have EIGHT metres of Cable.
When ordering radios or antennas, please ensure you use the correct designation:
Zara60 - 4 metres cable
Zara60/8 - 8 metres antenna cable.
There is a small price difference and this will be included in the new May 2015 price list which should come out in a week or two.
ZARA60 Spec Sheet.pdf
(524.46 KiB) Downloaded 30 times
Return to “Repcom Communications”
