SIFU's SFA Hilux
- Bloues
- Town: Roodepoort
- Vehicle: Hilux 2.2 D/C
- Real Name: Solly
Re: SIFU's SFA Hilux
Looks Stunning and welcome to "the Hilux Forum"....enjoy the lux !!!
Bloues
(Nie blou bul maar SHARKS ondersteuner)
Don't fence me in.....
'91 D/Cab 2.2(4y) AKA - Bloues. Lifted Suspension, Dual Battery, 80Liter Freezer, Bridgestone Dueler A/T, 29Mhz Radio, Mud Creeper Winch(Aus), EasyAwn Rooftop Tent, Roofrack, Garmin Nuvi, Long Range Fuel Tank, Jacks+straps for landi recovery.....
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
Justin, I payed R 110 ea from Ferrobrake (CBS). Mechanic at work organised them for me.
I had Powerflow make me a new set of manifold downpipes for the V6 today as the old downpipe on the passenger side used to touch the chassis when running downhill under compression.
They did a great job. Now I have a proper two into one connector, and a flange joint installed so I can remove them if I have to remove the gearbox.
Going to TweeWater with Barto tomorrow to play.
Sifu-Lux....I will miss you
- Town: Port Elizabeth
- Vehicle: Hilex
The hilux impressed everyone again at Twee Water.
Here's my trip report:
http://www.ec-offroad.co.za/trip-report ... ember-2009
Barto de Koning
- Sifu-Lux
- Real Name: Andrew
Decided to get a new engine spec plate made, long overdue, as its been 3 years since I did the conversion.
Etched in stainless steel plate.
Came out quite well if I do say so myself
- Cookie Monster
- Real Name: Justin
Looks Great
The etched s/steel plate is a nice touch man
If only more conversions were as neat as this nê, you've set the bar high my friend
Well Done Andrew
How's it running nou
Well Done Andrew
- Sifu-Lux
- Real Name: Andrew
It's all in the detail - you take more time when you do it yourself. No one to blame if it looks bollie :evil:
Running sweet Rich Fed her last week, 5 liters of Delo 400 and some new antifreeze
Will have to anesthetise her for the axle move :wth:
- Cookie Monster
- Real Name: Justin
Well Andrew is well on his way was there last night and the front axil is out already and I am sure the van will look awsome when complete
- Sifu-Lux
- Real Name: Andrew
With the axle move done, I was bored today
So I decided to clean up the home made underbelly guard which protects the bottom of the radiator/power steering pipes and pulleys. I removed it to fit the adjustable torque rod.
I originally made it out of aluminium chequer plate from an old BOB autoteller machines floor.
Somehow the FNB blue colour never really matched the rest of the vehicle
So I gave it a clean and resprayed it. Now it looks much better.
Looks really funky Andrew
Yello MTN
Yello MTN
One of these days the HILUX emblem will be replaced with CATERPILLAR !OOOOMS wrote:Looks really funky Andrew
Yello MTN
- Sifu-Lux
- Real Name: Andrew
Ha Ha. You joke, today when buying the spraypaint (sunshine yellow to match the OME shocks ) I see you get "Caterpillar Yellow" as well.
It actually looks very close to the CAT colour ... but yes, of course I was joking.
- Sifu-Lux
- Real Name: Andrew
I have been meaning to do a few minor jobs on the Lux, but the axle move has kept me busy, so today I finally got around to tackling them :)
First off was to fix the weak rear braking. I have read about modifying the LSPV rod height on the Lux to fix this problem. I did my OME suspension about 3 years ago, but never really got around to compensating for the increased rear suspension height. My Lux's rear lifted about 50mm after the new springs were fitted.
I used my spare bits I had and cut the threaded section off the bit that fits to the axle, and then welded on a new longer threaded section I had made.
I then fitted the new part and adjusted the mounting point of the LSPV rod about 50mm higher.
After two test drives and a bit of adjustment, the rear brakes are now better, and the Lux brakes a bit better overall. Not perfect, but an improvement.
- Sifu-Lux
- Real Name: Andrew
With the brake mod done, I then set about cutting some aluminium sheet and made up a heat shield for the drivers side exhaust manifold downpipe. This area gets quite hot, so this should protect all the wire, fuel lines and speedo cable.
I used the existing threaded holes in the chassis to fasten the heatshield, and placed two chassis washers behind it to space it slightly away from the chassis rail.
With that done, I also made up a heat shield to reduce the amount of heat on the spare tyre. The 265/75R15 tyre I use as a spare pretty much takes up all the space and is very close to the exhaust. I cut some slots in the aluminium and then bent them slighlty inwards to create an offset so the shiel stood away from the mounting points. I then fastened it with to hose clamps.
Works like a charm :D
8 ) .. ... And no rattles or resonance from these plates throughout the rev range? That exhaust is very close to the tyre ... good idea!
- Sifu-Lux
- Real Name: Andrew
Will check for any resonance tomorrow. I haven't driven it yet
If it does resonate, often you can overcome this by putting a crease along the edge of the plate, or a slight fold, maybe even just top and bottom (stiffens the plate - less flexible). Hope you don't have any hassles!
- Sifu-Lux
- Real Name: Andrew
Had a good play in the sand and on the back tracks behind Summerstrand in PE this afternoon after the Recovery demonstration put on by EC Offroad Adventures.
This gave me a good chance to test the new setup on the Lux, and the performance of the 33's.
My Lux performed faultlessly, not even a resonation from all the heat shields
The 33 MT's definitely performed well on the sand. I had a chance to check a bit of the wheel articulation, and got no rubbing yet. So this looks positive.
All in all, a great afternoon.
Looking good and good to hear that there were no 'issues'.
- Sifu-Lux
- Real Name: Andrew
On the continuing efforts to reduce noise, I bought some 10mm thick SPX33 foam rubber from Sondor today, and lined the bonnet. I also bought some plastic clips to fit into the factory holes in the bonnet to secure the lining without having to use glue.
The SPX can take 120 Deg C, so lets see how long it lasts without shrinking
- 519franco
- Town: Richards bay
- Vehicle: 87 Hilux 3L v6 Ford
- Real Name: Franco
i see you have a a/c can you take a pic of the brackting a spacing for me please i wana put a/c in but iam stuck at the pump thanks
HAPPILY BUILD 3L V6 1987 TOYOTA HILUX
viewtopic.php?f=136&t=18393" onclick="window.open(this.href);return false;
FORD> Full Off Road Damnation
FORD> Its not oil leaks,, its swearing power
Sponser: MY DAD
Builder: ME: FRANCO DU PLESSIS
- Sifu-Lux
- Real Name: Andrew
Hi Franco, I am catching some rays in Mauritius this week, will have a look when I'm back
- Town: Caledon
- Vehicle: Toyota
- Real Name: Charles
Hi SIFU LUX
Weet jy dalk waar kan ek bellhousing kry vit Toyot hilux 1998 gearbox na ford v6 engine.
Dankie
Dankie
- Sifu-Lux
- Real Name: Andrew
Hi, sorry don't know. Google "Gilo Engineering" I remember they used to do these, good luck
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
Where did you get the clips please?Sifu-Lux wrote:I also bought some plastic clips to fit into the factory holes in the bonnet to secure the lining without having to use glue.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
- Sifu-Lux
- Real Name: Andrew
