Posting Pictures Using An Image Hosting Website
How to upload a photo
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Sat Sep 22, 2007 7:24 am
In order to help us keep the memory usage on the forum within acceptable norms it is recommended to upload your collection of pictures to an Image Hosting Website. By doing so, you also keep all your photos in one place so you can then share them with friends and family or re-use them on another forum again by simply coping and pasting links to your pictures.
I have used a few of the free to use sites and have pictures hosted at more then one. At the moment I am using http://www.photobucket.com. I have found this site to be the easiest to use of the one I have tested.
To create an account go to http://www.photobucket.com and click on the "JOIN NOW" button. Fill in your new user name and password details and on the next page your personal details and click the "I ACCEPT SIGN ME UP" button. That is all that is needed to create your now account.
To upload photos to this site is easy. You can simply upload everything into the main album or if you want to keep your photos organised you can create "Sub Albums" for your different sets of photos.
To create a Sub Album is easy. You simply type the name of the new album in this block and click "SUBMIT"
Select the Sub Album here:
Click "BROWSE" to select the photos to upload and click "UPLOAD" to start uploading.
This screen will appear when uploading:
The larger the file sizes to more time it will take. Refer to this article viewtopic.php?f=21&t=295 to see how to get your file sizes smaller.
To now use your uploaded photos in a post on this forum or when doing a PM is easy. Simply click on this box below the picture you want to use, to copy the necessary code.
Then go to the posting you want to use the photo, select the position in the text where you want to place the picture and paste the code (press CTRL+V)
This is all there is to it.
Enjoy sharing your photos.
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Thu Oct 11, 2007 9:00 pm
benhur
Thankyou for all this effort that you have gone to to post all this info, I have logged on with my work address as it seems that I am already a member of this web site, will have a look and see with what name or pass words, I am busy uploading some pic's at the moment, thus will just follow your instructions and see what happens, not sure about the size etc
simoan
ORRA Call Sign: HC101
Thu Oct 11, 2007 9:03 pm
Hi Simon,
Try keep the sizes to no larger than 640 x 480, which is a nice size and doesn't hog too much bandwidth.
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Thu Oct 11, 2007 9:07 pm
simoan
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Thu Oct 11, 2007 9:08 pm
Ok too large but very nice cool pic. :wink: :) :lol:
simoan
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Thu Oct 11, 2007 9:11 pm
simoan
Thu Oct 11, 2007 9:14 pm
Hi Simon,
Looks good! :P
And the size is fine, 640 x 480.
BenHur
Real Name: Bennie
Thu Oct 11, 2007 9:21 pm
Simon the size is good just as it is but you must compress it more to get the file size down so that we can all save on bandwidth. See this article on compressing and resizing.
By compressing at 70% I brought the file size down to 110k without noticeable difference in quality.
Sifu-Lux
Town: Port Elizabeth
Vehicle: Used to drive a '91 SFA Hilux YN67R 4x4 ,Full OME, ARB lockers front and rear, Ford 3L V6, 35mm axle move, 33" General Grabber X3's and dual transfer cases....... Keep her safe Mud Dog!
Real Name: Andrew
Fri Oct 12, 2007 8:17 am
Hey Bennie, I see you were "also" the 999,999 lucky winner on Photobucket :lol: :lol: :lol:
Sifu-Lux....I will miss you
BenHur
Real Name: Bennie
Fri Oct 12, 2007 3:01 pm
Cheez, do you also get tired of winning all sorts of competitions and draws all the time :lol: :lol:
Christian Kuun
Town: Stellenbosch
Vehicle: 2008 Tuna V6 4x4 Manual
Real Name: Christian Kuun
Tue Apr 08, 2008 9:14 am
Sorry, just needed to test the upload.
Easy enough to also just right click on a photo, go to properties, highlite the URL, copy it, and paste it in your post. Highlite it in the post and click on the Img button.
The URL should look something like this http://lh5.google.com/gumbootkuun/RtfKK ... imgmax=512
and [IMG] should be infront and behind the URL
Wynkop Kuun
O82 6l5 8lO5
Tue Apr 08, 2008 5:23 pm
Yes, but the last image will be preceded by a slash, thus:
([img])http://whateveryouwant.com/123xyx.jpg([/img])
In the example above, the round brackets () at the beginning and end would be removed for the actual link.
Andries
Town: Dordrecht
Vehicle: '94 2.2 4Y Hilux S/C, '87 2.2 4Y Hilux D/C
Real Name: Andries
Wed Apr 09, 2008 11:22 pm
Weet iemand of daar 'n probleem met photobucket is?
Ek kry nie my foto's op die forum nie.
Eerstens as jy op image klik, het dit gewoonlik blou geword. Nou gebeur niks.
As ek dit uiteindelik gehihgligt kty en Ctrl+V druk gebeur weer niks!
Help asseblief!!!!!!!
Piesang
Town: Grabouw
Vehicle: '99 Hilux SRX d/c 4x4
Real Name: Pieter Pieterse
Thu Nov 27, 2008 12:09 pm
Ek het al die voorige fotos van my van die program af opgelaai en nou kry ek nie my fotos ge'copy' op die program om dit af te laai nie. :thumbdown: :thumbdown:
Kan iemand help asb :oops: :oops:
ORRA Call Sign: B15
Thu Nov 27, 2008 12:58 pm
Click op die direct link lyntjie dat hy blou word (highlight) en terwyl hy blou is druk Ctrl + C.
Druk dan net Ctrl+V weer aan die kant
BenHur
Real Name: Bennie
Thu Nov 27, 2008 6:16 pm
Ek het agtergekom PhotoBucket is lately temperamenteel. Soms moet jy twee keer op die text click voor hy copy somtyds moet jy Cntl+C gebruik soos Cassie genoem het. Dis vanaf hulle die website aan hulle kant ge upgrade het met sy nuwe voorkoms of iets wat ek dit optel.
ORRA Call Sign: B15
Fri Nov 28, 2008 5:39 am
BenHur wrote:Ek het agtergekom PhotoBucket is lately temperamenteel. Soms moet jy twee keer op die text click voor hy copy somtyds moet jy Cntl+C gebruik soos Cassie genoem het. Dis vanaf hulle die website aan hulle kant ge upgrade het met sy nuwe voorkoms of iets wat ek dit optel.
Ditto... en waar mens voorheen al die foto's se links ens onder aan die fotos gesien het (album view) sien mens dit nou net as jy jou muis oor die betrokke item beweeg. :evil:
Maverick131
Vehicle: Hilux 3.0 D4D
Real Name: Jacus
Mon Jan 31, 2011 6:37 pm
Dankie vir die inligting! Maklik as mens net weet hoe...
Life can be a tough journey - So drive a Hilux!
Earth Wanderer
Town: Noordhoek
Vehicle: Hilux Raider 3l KZTE 4 x 4
Real Name: Wendy
Thu Oct 04, 2012 9:54 pm
I've downloaded photo bucket and resized my pic to 640 x 480 but it seems to still come out larger than I'd like.
Will have to play around with all these new sites a bit as the I used a different program before.
I hope I get this right!
Earth Wanderer
Town: Noordhoek
Real Name: Wendy
Thu Oct 04, 2012 10:12 pm
http://s1322.photobucket.com/albums/u57 ... ia%202012/" onclick="window.open(this.href);return false;
Trailrider
Town: George
Real Name: Johann
Wed Nov 28, 2012 10:28 am
My fotos is op Photobucket en oor die algemeen 700 wyd. Baie is ge"crop" so die hoogte verskil.
Ek sien die forum vat niks groter as 640x480 nie. Is daar 'n manier om dit kleiner hier te post sonder om alles te gaan resize, weer op te laai en weer alles in my report te gaan in paste?
Ek is aktief op meer as een forum. Dit is egter maklik om die report eenkeer te skryf en met almal te deel, maar lyk my ek gaan die hele oefening moet oor doen om dit hier ook gepos te kry?
Maverick131
Real Name: Jacus
Thu Sep 03, 2015 3:15 pm
Family_Dog wrote:Yes, but the last image will be preceded by a slash, thus:
With the new Forum site, will this code format still work?
Fri Sep 04, 2015 9:22 pm
Yep, it should.
Return to “Photo Upload”
