Tyre deflator test
Tyre deflator test
So curiosity killed the cat and as I do not own one of these fancy jobbs, I thought it would be interesting to see how effectively it really works.
So I pumped my wheel to 3.0 Bar, with my trusty T-Max (bit much but it was only a test....) as to see how long it would take to deflate to 0.8 Bar (tyre 245 / 75 / 16 Bridgestone Mudz) I stopped the clock at 65 seconds Then from 0.8 Bar to 3.0 Bar took an amazing 2 min 35 sec with the T-Max (once again I was impressed with this machine)
Then I did the manual test, using the valve only to deflate from 3.0 Bar to 0.8 Bar.
A staggering 3 min 6 sec, which x4 would result in 12 min 26 sec. Just out of interest, from 2.5 Bar - 1.5 Bar took approx. 35 seconds
And from 1.5 Bar - 0.8 Bar approx. 20 seconds!
For R280.00 def worth the moola :wink2:
See here: viewtopic.php?f=22&t=18435" onclick="window.open(this.href);return false;
For details or deflators you are welcome to contact me on 0eight3 307 0574 or mark @ hilux4x4.co.za
- luckyhit
- Vehicle: '04 Hilux 2.7i 4x4 d/c
- Real Name: Reinhardt
Re: Tyre deflator test
Great!! So eintlik wat jy vir my se is dat ek 'n tmax compressor ook nog moet kry?
:problem: :problem:
Dankie vir die toets!
One Life! Live it!
Daai is seker een van die beter kopies wat ek by Megabucks gemaak hetluckyhit wrote:
:problem: :problem:
- ismail
- Real Name: Ismail
Thanks for the tests!!!!!
Also gonna get me one of those deflators.
I surf more than I work
- Niel
- Real Name: Niel
Ismail, Pieter will be sending me a few extras - let me know I must keep one for you?
- andrevt
- Town: sasolburg
- Vehicle: raider d4d
- Real Name: andre
jy kan duidelik sien wie sukkel nie met werk nie........ leke tyd vir speel
ek het ook so n ou kompressortjie baie great
Toyota Hilux 3.0 D4D 4x4
Thanx Mark,
Ek's half ywerig om daai 1ste trip te doen deur die Limpopo by Pafuri sodat ek daai deflator behoorlik kan toets
Soos dit nou nog reen, mag dit dalk langer neem as wat ek beplan het :wth:
Tinus, julle sal hopelik soner eenige probleme toerchopper wrote:Thanx Mark,
Eeinige vrae oor die deflator, skree maar :wink2:
- ToyX4
- Town: Ottosdal
- Vehicle: Rocky's
- Real Name: Riaan
Ag dis gaaf van jou Markie. Net een vraag - Wanneer koop jy nou ordentlike bande?
Reeds gedoen, my nuwe stel le al lank in die garageToyX4 wrote:Ag dis gaaf van jou Markie. Net een vraag - Wanneer koop jy nou ordentlike bande?
Maar nooit weer Bridgestone vir my doeleindes nie
Dis die een ....of x4ToyX4 wrote:BFG??
- Town: Kempton park
- Vehicle: Toyota Hilux 3.0KZTE DC 4X4
- Real Name: andre
How exactly does this "magoeter" work? Is it just a pressure gauge? Or Can you deflate to exactly the pressure that you want without having to check the pressure every few seconds?
Hi Andre have a look here:shady wrote:How exactly does this "magoeter" work? Is it just a pressure gauge? Or Can you deflate to exactly the pressure that you want without having to check the pressure every few seconds?
You can deflate very fast and check the pressure whenever you want to say every 20 seconds by just pushing the back lever forward. Simple operation
Rated as the 3rd most effective deflator available
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Great salesmen Markus LoL
Hoeveel soek jy Trevor???
Here is a nice comparison of various deflators available
Check this out:
http://www.parksoffroad.com/prodreview/ ... ormain.htm" onclick="window.open(this.href);return false;
Check this out:
- Johannes van die See
Goeie video ,OOOOMS wrote:Hi Andre have a look here:shady wrote:How exactly does this "magoeter" work? Is it just a pressure gauge? Or Can you deflate to exactly the pressure that you want without having to check the pressure every few seconds?
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
What does numbers one and two look like?
Sien hier:Hilux 1 wrote:What does numbers one and two look like?
Ek dink nie ek stem heeltemal saam met hulle nie. Die twee wat hulle nr 1 en 2 rank het nie een 'n pressure gauge nie. So jy moet skat hoeveel lug jy al uit gelaat het, die unit af draai, pressure gauge opsit en dan weer die deflator as die pressure nie reg is nie of die compressor as jy hom te lank laat afblaas het. Persoonlik hou ek baie meer van die tyre deflators wat Mark hier getoets het.
Also Cassie the 2 deflators they place at the top are both permanently installed on the rims... Our deflators are not "vehicle/rim" specific....
I still have a few of these deflators available, so if you are interested or want to give a friend one for xmas, makes a nice gift
mark @ hilux4x4 . co . za
Call 08threethree0705seven4
Can also be found here: http://www.4x4direct.co.za/shop/index.p ... cts_id=103" onclick="window.open(this.href);return false;
Good idea as a gift, Mark! I have only one left! (Can order more if required though).
- Niel
- Real Name: Niel
I have some left some bags as well.
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
myself also using a T-max and an ARB deflator,great combo,thanks for the test Mark
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
Makes life so much easier and then there is still time to have another cuppaThunder02 wrote:myself also using a T-max and an ARB deflator,great combo,thanks for the test Mark
