National Luna 74L vs 90L
Derren
Vehicle: 2001 Hilux KZ-TE D/C
Real Name: Derren
Post by Derren »
Hi,
The NL 74L is a double door twin compartment fridge/freezer. The NL 90L is also a twin compartment fridge/freezer but has one outside lid with an internal lid for the fridge compartment.
The 74 and 90 have identical (according the NL website) dimensions and I gather the difference is in the insulation thickness - the 90L has less, 60mm vs 42mm or something like that.
Would that reduction in insulation be that significant? and therefor make the 74L a better choice?
Derren
Toyota Hilux D/C KZ-TE 2001
TJM Bumper, TJM XGS Suspension (with Bilstein shocks), Gomad Alu-Canopy, Snorkel, Chip & Intercooler, Dual Battery
Hyundai ix35 2.0 2011
Four Wheel Drive Club - Western Cape
Hilux4x4.co.za Club
zepplin
Vehicle: Crooza VX 80 EFI
Real Name: Steve
Club VHF Licence: HC 127
Re: National Luna 74L vs 90L
Post by zepplin »
For sure!!!!!
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
18mm less insulation is quite significant. A lot more heat loss will occur which means your fridge motor will be running for longer periods to keep everything cold. This in turn drains your batteries quicker.... :alvarin: :alvarin:
Niel
Real Name: Niel
Post by Niel »
I am with Thys on this one
Derren
Real Name: Derren
Post by Derren »
Okay, Cool (no pun intended :lol: )
Hilux4x4.co.za Club
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Post by Polarbear2008 »
It would make sense that if the case is the same size, that the insulation would have to be WAY thinner to gain that much in capacity! I have the 74 twin door and have just finished a 3 week tour of Namibia and will never look back! It was for sure the right choice!
Most 90 litres are single door fridges with the 74 having 2 doors. AFAIK it is only recently that they added the 90 TWIN (single door). Whichever NL fridge is branded as a "TWIN" has thinner insulation as it is designed as a weekend type fridge as opposed to a overlanding type fridge, meaning thinner insulation.
Benefit of a twin door is that you don't open the freezer door to get to the fridge AND I can run BOTH compartments as fridge or freezer should I chose to!
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
