view active topics | view new posts | register | retrieve password | login
TOS | members' articles | shop | join the club | main site | workshop manuals
Son paneel mates
The Legend
Real Name: Dawie
ORRA Call Sign: X93-
Son paneel mates
Postby The Legend » Tue Jun 28, 2016 6:07 pm
Kan iemand asseblief vir my die mates (lengte en breedtes) van die volgende son panele gee.
80W
100W
120W
150W
Town: Bellville
Vehicle: Langpad (RAV4)
Re: Son paneel mates
Postby ChrisF » Tue Jun 28, 2016 8:20 pm
Dawie Dawie Dawie ..... jy WEET mos, die antwoord is ALTYD : 4x4Direct !!!!!! :thumbup: :mocking:
http://www.4x4direct.co.za/788-fixed-solar-panels
http://www.4x4direct.co.za/fixed-solar- ... -volt.html
Town: Bellville
Postby ChrisF » Tue Jun 28, 2016 8:22 pm
80W Solar panel
Polycrystalline solar cell.
No of cells and connections: 36 (4x9)
Weight 8Kg
Open circuit voltage(Voc) - 22.2V
Optimum operating voltage(Vmp) - 18V
Short circuit current(Isc) - 5.56A
Optimum operating current(Imp) 5A
Maximum power at STC (pm) 80Wp
Dimensions: 1000mmx670mmx35mm
100W Solar panel
Weight 10Kg
Short circuit current(Isc) - 6.58A
Optimum operating current(Imp) 5.56A
Maximum power at STC (pm) 100 Wp
Dimensions: 1120mmx670mmx35mm
120W Solar panel
Weight 11.6Kg
Short circuit current(Isc) - 7.2A
Optimum operating current(Imp) 6.67A
Maximum power at STC (pm) 120 Wp
Dimensions: 1250mmx670mmx35mm
The Legend
Real Name: Dawie
Postby The Legend » Tue Jun 28, 2016 8:51 pm
Baie baie dankie Chris.Jy is inderdaad reg met 4x4 direct :thumbup:
Town: Bellville
Postby ChrisF » Tue Jun 28, 2016 9:08 pm
Dawie ek het al meer as een keer goed by hulle gekoop wat nie eens op hul lys verskyn nie !!
PRAAT met George.
Die manne maak n plan !!
Who is online
