Roof rack for Steeltop canopy
Vehicle: Hilx
Real Name: Jacques
Tue Jul 25, 2017 8:48 am
Hi fellas
What roofracks are available to fit the steeltop canopy (2014 model Hilux).
Looking at buying a second hand one.
Thank you
Tue Jul 25, 2017 11:00 am
You could adapt any RR to fit quite easily. Problem is that the commercially available aluminium ones are on the pricey side, even 2nd hand, and then you might not have what would ideally suit you and your needs. So a nice option if you can weld is to make one up yourself to suit your requirements and have it hot-dip galvanised. :winkx:
