Boetamac wanna go Lexus
Boetamac
Town: Kraaifontein Cape Town
Vehicle: 1996 Hilux 2,8d D/C 4X2
Real Name: Llewellyn
Club VHF Licence: n/a
Thu Jul 17, 2014 9:26 pm
Goodevening Gents
I've been threatening to go 7m in my 1996 Hilux 2.8d Dc 2X4. I just tuned a 1UZ in a Mercedes sprinter , and it was awesome!
I am contemplating the 1uz in my hilux.
Question 1:Will it fit in a 4x2?
TOYODA
Vehicle: '89 YN67R with Ford V6 3.0
Real Name: Tiaan
Thu Jul 17, 2014 9:38 pm
The short answer is YES.
With a 4x2 you dont have to worry about the transfer case. 4x2 and 4x4 engine bay is the same size. Browse/search the forum, there are a few 1uz builds that was done on 4x4s.
swartvark
Town: Gordons Bay
Real Name: Tiaan
Fri Jul 18, 2014 10:07 am
Ek het hom in en hy's LEKKER!!! :twisted: Ek het handrat behou. Het al 'n auto gery en vind handrat net baie beter.
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
Boetamac
Sat Jul 19, 2014 9:04 pm
I have read plenty of threads on the 4x4's, but they had bodylifts and the sorts. my 4x2 dont have those luxuries.
so do i attempt this,or let it be???
The reasoning to go auto is i do not wanna go source flywheel,bellhousing,clutch and the likes.....
Sat Jul 19, 2014 10:28 pm
The autobox is the easier conversion - as you say, it's already married to the box, no need to source bell / clutch etc. It'll fit just fine without a body lift, it's not a motor with high peripherals. Another nice thing is that you can leave your suspension standard, the motor weighs a lot less than your diesel, although the autobox may be a bit heavier than your current box but you still won't be adding weight - all in all it should in fact be a little lighter.
psychosaffa
Town: Glasgow
Vehicle: 96 2.4 doublecab
Real Name: manuel
Sun Jul 20, 2014 12:05 am
without a body lift you will have to do some surgery to the transmission tunnel to get the gearbox seated high enough. not a difficult job, but more labour intensive than a bodylift.
id say go for it!!
Boetamac
Sun Jul 20, 2014 8:19 pm
Is there a specific sump position i need to look for? Front sump rear sump???
Im getting all xcited here. I sold my 7mge i had on a fully functional stand in my garage just last week. the money was rite,and later in the week i dyno'd a sprinter and an E30 BMW with the lexus motors. Absolutely awesome.....
Hannes Meyer
Town: Aranos Namibia
Vehicle: Hilux V6 4.L d/c 4x4 Automatic 2014 , Land Cruiser pick-up 2012
Real Name: Hannes
Sun Jul 20, 2014 9:13 pm
Dagse, julle. Ek het 2.7 D/C 4x4 2001 Model, engine het gegaan. Nou oorweeg ek die Lexus.
Wat sal jul aanbeveel, ek het aan die vvti gedink, sommige ouens se nee, maar kan my nie regtig se waarom nie.
Inligting sal waardeer word.
scunick
Commercial Member
Commercial Member
Vehicle: FJ45 & 2004 DC 3,0 KZTE
Real Name: Nick
Sun Jul 20, 2014 10:21 pm
I have dropped both the dual vvti motor and the earlier dingle vvti 1UZ-FE motors into my Hilux and can say the dual Vvti motor is absolutely the better option, if you get the stock harness and ecu. Without the stock ecu the management of the motor is not easy to get right.
The other issue to remover is that Hilux leaf sprung rears are particularly soft and axel wrap is likely to get be a problem. We have decided to build a custom ladder bar to solve this issue... ( fitting a ladder bar generally requires a body lift)
Later
Nick
Sent from my iPad using Tapatalk HD
Hannes Meyer
Real Name: Hannes
Mon Jul 21, 2014 7:42 am
Thanks, Nick
Llew Mac
Town: Kraaifontein
Vehicle: 1996 hilux 2,8D dc Lexus v8
Fri May 27, 2016 8:55 pm
I have completed fitting the 1uz vvti in my 1996 Hilux 2,8dc 4x2. It was a five squeeze, but its in and running awesomely.
I am still at a loss with regards to a speedometer, but it is a very very nice experience......
LEXUS........ DO IT
Town: Bellville
Vehicle: Langpad (RAV4)
Sat May 28, 2016 5:34 am
Geluk.
Daar is nog n thread op die oomblik oor n speedo cluster vir n Lexus conversion .... daar is wel oplossings.
As jy dalk issues het met die fine tuning, gesels gerus met Izak by Dynotech in Brackenfell. Hy KEN daai motors, en is briljant met sy dyno setup.
Llew Mac
Town: Kraaifontein
Sun May 29, 2016 1:37 pm
Wei asseblief hit oor die meer opsies.
Watter plan is daar?
Enige opsie sal sekerlik oorweeg word...
