Getting 4X2 unstuck
KZN KZTE
Town: Himeville
Vehicle: 2000 2700i 4X2 D/Cab
Real Name: Pierre
Sun Sep 28, 2014 5:46 pm
Hi all,
I've just 'downgraded' to a 4X2 again after many years in a 4X4.
Was wondering - what is the best tips/advice/equipment to carry along in case you get stuck in a 4X2 - especially the Hilux with it's light tail and plenty power on tap.
1. High lift jack
2. Spade
3. 50kg on the back axle or get someone to stand at the back (safely). Rocking action might also help
4. Winch (sparewheel could be buried to act as anchor point)
5. Traction Mats
6. Deflate tyres (carry compressor to inflate)
7. Make-shift 'winch' using spinning back wheel (careful, slow and straight)
8. Buddy in a 4X4 although getting stuck might be unplanned so make sure you have reception and contact numbers handy
Any other tips we can add to the list that might help others?
Cur: 2000 Toyota Hilux 2700i 4X2 (Missing V6 power)
Pre: 2001 Pajero 3.5 V6 Manual Gen3 (Lemon)
Pre: 1999 Pajero 3.5 V6 Auto (Written off )
Pre: 2002 Nissan X-Trail 2.5 4X4 Auto (Still a Softy)
Pre: 2001 Toyota Hilux KZTE 4X2 (Hard suspension killed me)
Pre: 1995 Range Rover Classic 3.9 V8i Auto (Broke down too much)
Tow: Venter Botswana (Sold)
TOYODA
Vehicle: '07 Hilux V6 A/T 4x4 & '89 YN67R with Ford V6 3.0 & '12 Suzuki Jimny (SWAMBO)
Real Name: Tiaan
Club VHF Licence: X139
Sun Sep 28, 2014 6:08 pm
KZN KZTE wrote:I heard of someone who fastened a strap to the rim of the spinning back wheel and used that to winch it around the outside of the tyre
I saw this trick on DSTV. 2 guys in a Jeep.
I'm just worried that the strap will slip off the tyre, but it worked out well for them.
Sun Sep 28, 2014 6:20 pm
1, 2 & 5 are good options to carry with you. If your 2x4 doesn't have a locker, you can use your hand-brake to act as a 'fiddle-brake', but I wouldn't recommend doing this regularly. ;-)
ThysdJ
Club VHF Licence: HC102
Sun Sep 28, 2014 6:56 pm
Weight on the back will aid with traction. Deflating tyres wiĺl also help. The strap trick on the back wheel can work but you need to do it very slowly and straight. Take a 1 2 and sand tracks and a buddy with a 4x4.
KZN KZTE
Town: Himeville
Real Name: Pierre
Sun Sep 28, 2014 7:26 pm
ThysdJ wrote: Deflating tyres wiĺl also help.
Thanks - forgot about it - Will add to original list in post
Sun Sep 28, 2014 11:53 pm
A few 114x38x1500mm SAP will help when you have lifted the truck with the highlift.
Kaspaas
Town: Somerset - Wes
Real Name: Cobus
Tue Sep 30, 2014 8:46 am
This is from an old discussion I had with Cassie here on the forum:
I have done this in the past, if Im stuck in deep mud.
Even on my old 4x4 SFA with no difflock it works wonders.
Besure to use a strong log or "wooden dropper" and rather on steel rims than mags.
Depends on the seriousness, and if your in an area where there is no anchor.
Firstly it gains alot more traction, but the main positive of this it lifts the diffs and under carridge from the mud.
Breaking the sucktion of the mud.
:thumbup:
