Pull off problem
Ilovetoyota
Town: Polokwane
Vehicle: Toyota d4d srx 2013model
Real Name: Collen
Tue Apr 24, 2018 2:48 pm
Hi intelligent people..im owning toyota srx d4d 2.5diesel 4*2...if it happens that I dnt drive it for four(4) days n above, de day I want to drive it it doesnt move at all either in gear 1 or reverse..I cn hear very well dat de gear engaged but to me its like smthng hooked then wen I keep on reving reving while also playing wth de gear 1n reverse de time is kicks to move it sounds like smthng break smwhere in gearbix or engine then it moves smoothly wthout any problem...tried to ask many toyota garages but no answer plzz help
Hilux 1
Vehicle: 2000 Raider 2700i 4x4 Double cab. met "rock sliders" en Powerflo stainless exhaust
Real Name: Tertius
Club VHF Licence: HC137
Tue Apr 24, 2018 4:26 pm
is the hand brake released :lmao:
maybe drive shaft problem?
Tue Apr 24, 2018 4:30 pm
Sounds like your rear brake shoes are binding. They will stick and then "break free" eventually when you try and move the vehicle forward and backwards. I had the exact same issue with a vw beetle that was standing a lot.
Remove the rear brake drums and make sure that there is no rust, correct shoes, links connected correctly and clean. Make sure the brakes and handbrake is correctly adjusted.
Ilovetoyota
Town: Polokwane
Real Name: Collen
Tue Apr 24, 2018 4:47 pm
Ya hand brake released properly
Ilovetoyota
Town: Polokwane
Real Name: Collen
Tue Apr 24, 2018 5:33 pm
If its brake binding is it not support to move lightly wen u try to move?
Tue Apr 24, 2018 6:36 pm
Brakes are binding, just try a bit harder to drive it forward or backwards, but just be careful, when it suddenly realeases it will move quickly. Depending on where it is parked make sure there is space for it to move once it gets loose.
Tue Apr 24, 2018 8:34 pm
No it won't move if the brakes are binding and it means the brakes are tight even when the handbrake is released. This could be due to sticky/rusted handbrake cables or handbrake linkages inside at the brake shoe assembly.
Ilovetoyota
Town: Polokwane
Real Name: Collen
Tue Apr 24, 2018 8:41 pm
Ok sir Mars I understand u
Wed Apr 25, 2018 6:25 am
My Aygo did it twice.
It is as if the handbrake do not want to release. It happens especially if you park the vehicle either after driving in the rain or washing the car.
A friend of mine's wife bumped his Hilux against the garage wall because of the same thing.
