Last week, the engine of my 'Lux caught fire after the fuel hose to the carburettor came loose and sprayed fuel all over the (hot) engine. Thank Heavens for things like fire extinguishers! Still ended up having to replace all hoses, belts, some wiring, distributor cap, fan and cowling! Should'nt complain, it is still cheaper than replacing the whole bakkie!
Upon cleaning the effects of the fire (and the fire extinguisher), I found that the Brass coupling between the rubber hose and the carburettor had come loose. Upon speaking to people more knowledgable than me, I was told that this brass coupling is an interferance fit (read pressed in) into the carburettor, and that they have been known to work loose!
So, if you drive a vehicle fitted with a Weber 38 carb, check that coupling!
I have been advised to have the hole for the coupling tapped, and a threaded coupling made up for it. Failing that, at least to wire the hose to the carb itself.
http://www.4x4community.co.za/forum/sho ... hp?t=14313
