Quick clutch question
- Town: Centurion
- Vehicle: 88 Hilux DC/4x4, 77 Jeep CJ7 V8, 2010 Jeep Rubicon Unl, 2011 Rubicon 2dr
- Real Name: Andre
The clutch master cylinder on my '88 SFA is leaking. Are the clutch kits (or new master cylinders) still available? I would like to do the slave cylinder as well, are they available?
- BlumTRD
- Town: South Africa
- Real Name: David
Re: Quick clutch question
YIP midas does sell master en slave . But have a look at slave first as the unit are more prone to leakage and worn seals . They sell repair kits too
- Town: Centurion
- Real Name: Andre
Thanx, that is the answer i was hoping for!!. I think the slave is leaking (it is wet).....but the master cylinder is also leaking...it is leaking into the footwell inside the cab.
- Gunta
- Real Name: Mark
The pirate ones start leaking again after 6 months. Do yourself a favour and go and buy the OEM one its not that much more expensive.
- kfxnando
- Town: Germiston
- Real Name: Fernando
yep that also the experience that I have hadGunta wrote:The pirate ones start leaking again after 6 months. Do yourself a favour and go and buy the OEM one its not that much more expensive.
- Van
- Town: centurion
- Vehicle: 91 SFA Hilux.manual Lexus v8. Ironman Suspension. 30 inch BF Goodrich AT's
- Real Name: Hugo
Hello all i trust you are well.
I need to replace my clutch master cilinder.
Toyota quoted me R1857 for an original
Gemini quoted R307.00????
I know original is better but is it R1550 better?
Cheers H
Cheers H
Addicted to Recoil.
Grip it and Rip it, should apply to all things in life!
AFAIK there are seal kits available. Did a seal kit replacement on the 2x4 about a year ago .... all still OK. If memory serves correctly it was about R200 for the kit.
- Van
- Town: centurion
- Real Name: Hugo
Thanks Mud Dog. The master cylinder is still the original and looks pretty beat up.....
For piece of mind i might go original unless other members have success stories with generic cylinders.
Cheers H
Cheers H
Addicted to Recoil.
- Gunta
- Real Name: Mark
I had bad luck with the cheapies and eventually bought the OE.
Beat up you say? Usually just a little pitted from the atmospheric moisture absorbed by the brake fluid. Most often nothing that a little hone won't cure.Van wrote:Thanks Mud Dog. The master cylinder is still the original and looks pretty beat up.....
Cheers H
Then without trying to sway your decision, to be truthful, I've heard more positive feedback from the generics than negative. Not that it may mean much if the comments were made in the "six month" period before they started leaking.
Good luck all the same!
- Van
- Town: centurion
- Real Name: Hugo
Thanks for the feedback Mud Dog.
By Beat up I mean leaking like a "sif" :problem:
a seal kit retails for R400 odd from the stealers.
I think this will be my first option if not successful, I will try a generic.....
Thanks once again
Cheers H
Thanks once again
Cheers H
Addicted to Recoil.
