Hilux IFS 2001 Temperature Rises
- Town: Lombardy East-Johannesburg
- Vehicle: 2.7i D/C 4X4 2001
- Real Name: Craig
Need some advice as i have experienced that my Temperature gauge rises when under torque but does not overheat and have lost minimal water but cannot find a leak....looking for a reputable workshop to help with pressure testing to identify the problem.....am based in JHB
- Donkey
- Club VHF Licence: X122
Re: Hilux IFS 2001 Temperature Rises
Sometimes with a cracked/blown gasket, compressed cylinder gasses push water out via the coolant tank hence at times difficult to see a leak.
Try Rand Radiators 011 334-1158, 6 Melrose Street, Jhb CBD
Tumelo Maketekete
- Theodorus
- Town: Honeydew Jhb
- Vehicle: HILUX
- Real Name: Theo
Cant place a new post but need to ask my powersteering pump is making a zinging noice on holiday can it break im on holiday till the 3rd not driving to much what will happen if it packs up
I am here: http://maps.google.com/maps?ll=-25.891778,28.687958" onclick="window.open(this.href);return false;
Mylux
Mylux
Craig, if you're not loosing coolant except where it starts to get really hot, and only getting hot under load or at high speeds, it's quite possible that the radiator is shot. Have a look at the little fins on the radiator if they are badly corroded. Otherwise it could also be a thermostat or radiator cap problem.Shark King wrote:Need some advice as i have experienced that my Temperature gauge rises when under torque but does not overheat and have lost minimal water but cannot find a leak....looking for a reputable workshop to help with pressure testing to identify the problem.....am based in JHB
Theo, It may be a simple thing like a shortage of ATF in the reservoir. Check it. Otherwise it's on it's way out but will continue to work OK for quite a while, without any collateral damage. You can have it re-conditioned or replace it at a later stage once you are back.Theodorus wrote:Cant place a new post but need to ask my powersteering pump is making a zinging noice on holiday can it break im on holiday till the 3rd not driving to much what will happen if it packs up
Mylux
