Hi All
What is the correct oil for Gbox, tcase, front diff and local (gearmax) rear diff?
And how much of each.
Correct Oil for SFA GBox and Tcase and Diffs
- Big D
- Vehicle: SFA Hilux 2.2 BFi
- Real Name: Deon
Re: Correct Oil for SFA GBox and Tcase and Diffs
Deon, jy behoort info hier te kry:
http://www.hilux4x4.co.za/manual/index.php" onclick="window.open(this.href);return false;
Indien nie, skree :wink2:
- Big D
- Real Name: Deon
Thanks Mark
But I need more Help
The Workshop Manual says:
Gbox: 75w90
Tcase: 75w90 or API GL5 or GL4
Diffs: 80w90 or SAE 80W
Mayfair Gearbox (they redid my Gbox) says:
Gbox 75w90
Tcase 85w140
Trail Gear (suppliers of my low range gears) says:
Tcase : 80/90W GL5 wees
Gearmax (local diff supplier) says
Diffs: 85w140 GL5
Any Help on chosing the correct one?
Gbox: 75w90
Gbox 75w90
Tcase 85w140
Diffs: 85w140 GL5
Big D wrote:Thanks Mark
Gbox: 75w90 The owner's handbook says EP SAE 80W-GL4 Transmission oil
Tcase: 75w90 or API GL5 or GL4 You can use the same as the gearbox.
Diffs: 80w90 or SAE 80W The owner's handbook says ISO 460 85W 140 GL5 for rear diff (local G/max) ---- EP 90 GL5 for front diff (import)
Gbox 75w90 Same as what the handbook says.
Tcase 85w140 Maybe they feel a diff oil is better .... can't do harm if that's what they used.
Tcase : 80/90W GL5 wees Follow their reccommendation.
Diffs: 85w140 GL5 Same as what the handbook says.
- Club VHF Licence: X93-
Very interested
My workshop manual says
Front and rear diff HYP 80W90
Limited slip diff HYP H-LS90
Transfercase HYP 80W90
Eish confusing
Eish confusing
- Ryperd
- Vehicle: 1994 Hilux D/C 2.2 Petrol (4Y SFA)
- Real Name: Rudi
I've just put 85w140 (Shell Spirax) in my front diff. Should I drain it and put in 80w90 (or EP90)?
