Reset fuel light on a 3.0 D4D Hilux
Aquanaut
Town: Durban
Vehicle: Hilux 3.0D4D
Real Name: Basil
Tue Apr 10, 2012 8:56 am
I know this is a pain for many.
Just been to the dealer to have my fuel filter replaced as the light stayed on and did not flash.
Anyway, the sequence is as follows to reset the light.
Once the filter has been replaced and the wire plugs are loose,
1. replace the both wire plugs
2. switch ignition on, at this stage the fuel light will still be on.
3. remove the positive terminal from the battery and wait for 1 minute.
4. this resets the whole computer, gauges everything.
5. After 1 minute, replace the positive terminal.
6. switch on the ignition and the light will be off.
Hope this will help others who need to replace a filter while travelling in the bush. :thumbup:
Regards
Basil
Tue Apr 10, 2012 9:03 am
The only logical reason why it should come is either because it has water in it or due to a faulty plug wire. How often do you replace your filter?
I know Toy only replace at say 90 000km......but this is no good. Do replace it every 10 000 - 20 000km's :beg:
Aquanaut
Town: Durban
Real Name: Basil
Tue Apr 10, 2012 10:23 am
According to the dealer, the light will come on and flash if the filter has water in it, and if the light stays on without flashing, the filter is dirty and needs to be replaced. the computer picks up that the there is a difference in the in and out pressure and activates the light.
I bought the vehicle second hand with 44000 on the clock and it has now got 48550km. the light came on during my trip to Lesotho and I had it changed this morning.
Normally I carry a spare fitler which is quite easy to replace, but I did not know how to reset the light. Now I know the sequence and will be carrying at least two spare filters when travelling long distance.
I will be replacing filters every 15000km seeing that it is no longer required by the dealer to change on service intervals, they only replace when the light comes on and I have not yet seen a dealership in the middle of the desert.
So know how to replace a filter and know how to reset the light.
Basil
jacques kotze
Town: Nelspruit.
Vehicle: Prado 4,0 V6, dual battery & 3.0 D4d S/C 4x4,front replacement,12000lbs winch.
Real Name: Jacques
Tue Apr 10, 2012 10:32 am
Thanks Basil, I also had a similar problem on my way to Malelane, the Toy dealer also explained to me the sequence to reset the light, can't remember everything he said, but he didn't say anything of disconnecting the battery. But if you say that it works I will do it next time. Thanks
Aquanaut
Town: Durban
Real Name: Basil
Tue Apr 10, 2012 10:46 am
Hi Jacques,
Even with the filter being 'dirty' before reaching Sani Pass, my vehicle still averaged 12.7 km per litre from Durban to Oxbow and home via golden gate. Not bad and the one thing that has prevented me from buying a Hilux in the past was the high fuel consumption, this D4D motor is great, couldn't believe the power and consumption, very impressed.
jacques kotze
Town: Nelspruit.
Real Name: Jacques
Tue Apr 10, 2012 10:51 am
Aquanaut wrote:Hi Jacques,
Don't know how you managed to get 12.7 km/l, The best I ever got with my 3.0 d4d was 10km/l driving 120 km/h. Even when I was in Namibie driving 90 - 100km/h I only got 9 - 10 km/l. But I had a chip in that I took out after I was in Namibie, from then I got 10 km/l @ 120km/h.
Aquanaut
Town: Durban
Real Name: Basil
Tue Apr 10, 2012 2:09 pm
Reset my KM/L computer when I left Durbs, filled up at Himeville and had 23 km left according to my range on the computer before I ran out of diesel, this when I pulled in at my home. According to Garmin, 857km travelled
Maybe it is a long freewheel from 3500m above sea level in Lesotho to Durban. :)
jacques kotze
Town: Nelspruit.
Real Name: Jacques
Tue Apr 10, 2012 2:15 pm
Aquanaut wrote:Reset my KM/L computer when I left Durbs, filled up at Himeville and had 23 km left according to my range on the computer before I ran out of diesel, this when I pulled in at my home. According to Garmin, 857km travelled
Still very good consumption :thumbup:
rebuilder
Town: Adelaide
Vehicle: Toyota camry altise. Till I find a replacement hilux.
Wed Apr 11, 2012 6:19 am
With our diesel in SA I recomend you replace the filter at every service. To reset the light is quick and easy - With ignition off, unplug the top plug from the fuel filter housing, Start the vehicle and quickly put the plug back in. Light will go off after 3 sec. Job done. 10 seconds.
There is a madness about been mad that only a mad person can understand.
Diesel and dust is where home is at.
Wed Apr 18, 2012 2:29 pm
rebuilder wrote:With our diesel in SA I recomend you replace the filter at every service. To reset the light is quick and easy - With ignition off, unplug the top plug from the fuel filter housing, Start the vehicle and quickly put the plug back in. Light will go off after 3 sec. Job done. 10 seconds.
:thumbup: :thumbup: :thumbup: Tx for the advice, did this and it works :yahoo: :yahoo: :yahoo:
Mon Oct 07, 2013 11:19 am
The first time I replaced the filter on my D4D was when I gave it the first service at 100 000ks. It did not look as if it had ever been replaced. The light did not come on however. Since then I have been replacing it every 20000ks. The light has never come on before. At 220 000 k's I replaced it and two weeks ago after a trip to Vaalwater the light came on and stayed on. I replaced the filter but it really did not seem to be that dirty. I used this procedure posted by rebuilder to reset the light.
"With ignition off, unplug the top plug from the fuel filter housing, Start the vehicle and quickly put the plug back in. Light will go off after 3 sec. Job done. 10 seconds."
Works perfectly! Thanks for the Tip. :yahoo:
Hilux Brett
Town: Brisbane
Vehicle: 2008 Toyota Hilux Diesle 3L 4x4
Real Name: Brett
Sat Nov 30, 2013 7:41 am
Tried this tip and I confirm that it does the Job - ""With ignition off, unplug the top plug from the fuel filter housing, Start the vehicle and quickly put the plug back in. Light will go off after 3 sec. Job done. 10 seconds."
jacques kotze
Town: Nelspruit.
Real Name: Jacques
Sat Nov 30, 2013 8:41 pm
Hilux Brett wrote:Tried this tip and I confirm that it does the Job - ""With ignition off, unplug the top plug from the fuel filter housing, Start the vehicle and quickly put the plug back in. Light will go off after 3 sec. Job done. 10 seconds."
Thanks Brett, did like you explained and it worked. :thumbup: :thumbup:
Vigo77
Town: Lusaka
Vehicle: Hilux Revo d/c 2.8gd6
Real Name: David
Wed Jul 16, 2014 9:03 pm
Hi there been having this problem of light going on every few hundred kilometers. I took both my tanks down cleaned them and there was not much debri in the tank. A friend of mine removed tanks for the second time and found that the suction piece with very fine filter over it was completely clogged up with debri. We blew out the whole system fitted it back and reset the light and the problem is solved. I noticed this is a common problem on the vigo specially as you come up north towards Zambia where I am based with terrible fuel :thumbup: happy driving
Thu Jul 17, 2014 7:38 am
Thanks. Good information!
Raino001
Vehicle: "D-Rod -- Thomb Raider" Hilux Raider D4D 4X4, 33" Muds, Body lift , 76 Free flow
Real Name: Raino
Tue Sep 02, 2014 11:25 am
Hi
Reset D4D diesel filter light
What you need to do is the following,
1. Replace the filter.
2. Keep the top sensor unplugged
3. Start ( idle )
4. Re connect the top connector (quickly )
5. Switch off and start again ( problem solved ) ---no need to disconnect battery ;-)
Tue Sep 02, 2014 12:13 pm
Actually you don't need to let it idle. You can simply turn on the ignition without starting the vehicle.
Stuart Baak
Town: Douglasdale
Vehicle: Hilux Legend 40 RB DC auto
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 6:42 am
Aaaand so my fuel light came on yesterday on my way home from Tonteldoos (Yes - It's an actual place...) so off to my local stealers with a tub of vaseline and credit card, I will be replacing it myself. Will try take pics so we can all do D-I-Y :D :lol:
Mon Feb 16, 2015 6:50 am
You don't need to get the diesel filter from the dealers. The Gud filter number is G1142 and the Fram number is C10353. I have been using either of these filters for the past 157000 Kilometers. You can also try Goldwagen. The only real "trick" is that you should make sure that the ring is tight when you screw it back on again. Get some reference point and make sure that it is in the same position. I have seen where the ring was not on tight enough. It did not leak but the filter element disintegrated.
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 7:01 am
My only issue is mechanical warranty so am I not held to buying the Stealers filter? Last thing I want is a warranty claim rejected :roll:
Mon Feb 16, 2015 7:21 am
I can assure you that they do not take out every filter and check if it has an original Toyota part number on it. In many instances they do not even pick up when a performance chip was fitted to the vehicle and in some instances where the dealers pick it up they say or do nothing about it and a performance chip is a much more likely reason for them to refute a warranty claim than fitting a replacement filter from a reputable brand in between regular service intervals
Should they not replace the filter anyway if the bakkie is still under a service plan? When I replaced the filter on my lux at 100 000 ks (The first time I serviced it) the filter was horrendous! I asked a former Toyota mechanic about it and he said they do not replace the filter if the light isn't on. I cannot vouch for the truth of this but I can tell you that by the look of things it wasn't replaced.
a Warranty claim can only become an issue if the diesel pump or injectors fail. If you think there is a reasonable prospect of this happening then by all means buy the Toyota filter. I can assure you it's not going to fail because of you fitting a Gud filter. Toyota probably sources its local oem filters from Gud anyway.
The most important thing is to do what you are comfortable with. I was just hoping to save you some Vaseline!! :mrgreen:
I forgot to mention that the GUD and FRAM filters are one and the same filter.
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 7:48 am
Mars wrote:I can assure you that they do not take out every filter and check if it has an original Toyota part number on it. In many instances they do not even pick up when a performance chip was fitted to the vehicle and in some instances where the dealers pick it up they say or do nothing about it and a performance chip is a much more likely reason for them to refute a warranty claim than fitting a replacement filter from a reputable brand in between regular service intervals
No worries Mars, I also hope to save from the stealers - one of the many great features of this club!!! :cooldude:
Unfortunately no service plan, only mech warranty. I will Check out the GUD filters. And ya, OEM is probably just a special branding from GUD. In this day & age, as much saving on vaseline as possible :silent: I have to take my truck in for the "Slight shudder on pullof" - seems the bearings are gone. there is indeed upward/downward play. Will see what the Mech Warranty says about it. ;) :crazy: :think:
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 9:57 am
Help asb, filter changed, now car won't start. Been pumping the knoppie but no turnover
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 10:15 am
Post Changed as no need for panic here :crazy: :crazy: :tease:
Mon Feb 16, 2015 10:33 am
Hey Stuart, give Allen (Hoppy) a call on
0721291160.
He will be able to help you.
Hope you get it sorted :thumbup:
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 10:52 am
Okay So I am officially a Numty.
So what happened was, Removed the entire fuel filter housing from the engine bay, obviously disconnecting the 2 wires and the 2 hoses (Inlet/Outlet)
When I had changed the filter, put everything back and started pomping that little knoppie. Nothing was happening, couldnt start (Suction from fuel pump etc) nada, niks. So I disconnected the outlet (to the engine) and saw that the pump WAS working, as I could hear the air movement. Turns out, It was the wrong air movement.... It was the Inlet pipe from the tank side that was making the noise. When I re-connected the fuel line, the o-ring became unseated and obviously once it was connected, there was no Vacuum to suck in the fuel from the tank...
So, Note for everyone else. If you disconnect the fuel inlet, MAKE SURE THE LITTLE O RING IS in it's HOME! :crazy: :crazy: :crazy: :crazy: :crazy: :crazy:
Problem solved, Bakkie running again. Damn what a panic... I have no other wheels haha
Mon Feb 16, 2015 10:56 am
Glad it is sorted boet :thumbup: :thumbup:
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 10:58 am
4x4BEES wrote:Glad it is sorted boet :thumbup: :thumbup:
Thanks Kev! What a leaning process.... :subscribed:
Mon Feb 16, 2015 12:26 pm
Sorry I missed your panic there Stuart. Happy you got it sorted. The devil is in the detail but at least your experience can help someone else who has the same thing happening to them. Did you battle to get the ring back on tightly?
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Mon Feb 16, 2015 12:28 pm
It was a challenge but if you press the base of the filter housing against the ground and push the top down, the ring tightens quite easily :thumright:
Tue Feb 17, 2015 6:49 am
Did you remove the entire filter housing from the bakkie?
Stuart Baak
Town: Douglasdale
Real Name: Stuart
ORRA Call Sign: H61
Tue Feb 17, 2015 6:50 am
Yebo yes
Tue Feb 17, 2015 7:37 am
No wonder you battled. Next time only disconnect the electric plug on top and the fuel line running to the high pressure pump. (The one that points more toward the front of the engine). There is still more than enough room to undo and tighten the ring that holds the assembly together. All you need to do is put some pieces of cloth down so as not to spill diesel inside the engine bay.
johanvb
Town: Welgelegen Cape Town
Vehicle: Toyota Legend 45
Mon Nov 14, 2016 10:13 pm
Hi
Today I bought a GUD diesel filter, removed the filter...changed the O-ring...but the filter back....reset the warning light, started the vehicle...there is a slight very slight leak of diesel from the filter...am I over tightening the filter..or what else am I doing wrong. i have even tried the old o-ring..stil the same..
Rigger
Town: Oudtshoorn
Real Name: Martiens
Tue Nov 15, 2016 5:08 am
Is the cup that the filter goes in right up againts the top part with the 'nut'. Make sure it goes right to the top before you start to tighten that nut otherwise there is still a gap between the two parts and hence the leak
Tue Nov 15, 2016 10:09 am
Argree with Rigger. The big o-ring that fits around the filter housing is quite a tight fit so I will normally first seat the top part on the bottom part (cup) by hand to make sure that the gap is even all around and the top part is seated securely on the bottom part before I screw on the ring. Some firm pressure from above is normally enough to seat the top part. You can clearly feel is slipping over the o-ring and seating. That way you do not need to use the ring to pull the top part into position on top of the cup and it is also easier to judge how tight the ring is when you tighten it. Check that the gap is even all the way around before you screw on the ring. It needs to be quite tight.
johanvb
Tue Nov 15, 2016 1:20 pm
Thanks for the advice.
Much appreciated.
