Hi guys my SFA 88 hilux's left rear brake broke , the little pin and spring with cup came loose and now busy trying to rebuild it but this manual i got from toyota is confusing the hell out of me . If you look on attached pic it shows the left and right wheel assembly but if i look at mine it doesn't look the same , what one is the right way the left pic or the right pic ?
Workshop manual diagram :
What i saw on my brakes :
Would this be the right way ? Or not ?
Any advice would be welcome as it seems to me that the previous mechanic didn't know how to correctly assemble the brakes and that is why everything went haywire , so now i want to do it myself and do it right .
88 SFA rear brakes giving me a headace please help
Re: 88 SFA rear brakes giving me a headace please help
Hi Willie, sorry unable to assist as it has been way to long since I last worked on a SFA rear brakes
Sure someone will assis shortly
Welcome to the Forum, there is tons of info here I am sure you will find usefull
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
Willie
Sien foto,s van my 1989 SFA bakkie se agter remme.Ek hoop jy kan hieruit iets wys word.
- Attachments
- (106.87 KiB) Downloaded 534 times
- (74.35 KiB) Downloaded 534 times
- (89.6 KiB) Downloaded 534 times
- The Legend
- Real Name: Dawie
Willie,
Looking at your pictures it seems to me that you bakkie and mine doesnt use the same braking system.I would suggest you remove the right wheel drum and looks how the springs and gadgets fit together.
- Town: Harkerville WC
- Vehicle: 1990 Hilux 4Y
- Real Name: Peter
Hi Willie, I found the same thing when I did mine. I took it as an error in the manual and just put everything back the way it came out. Seemed to work fine.
- Town: South Africa
- Real Name: Craig
Dawie,
Your brakes look like they are missing a spring at the bottom of the shoes... I may be wrong though.
- NathanX4
- Town: Meyerton
- Vehicle: 1991 Toyota Hilux (4.3) 4X4
- Real Name: Nathan
Ek het self vandag my dromme begin doen. Sal wil weet hoekom toyota dit so ingewikkeld wil maak. My probleem was, daar was niks om meer te begin nie. Die spring kit wat ek gekry het is nie volledig nie en moet nou ektra plaatjies en pins gaan soek. Volgens die diagram wat ek het moet die briek skoene 'n pin op die een skoen he, soos op die photo aangeheg.
- Attachments
- (250.71 KiB) Downloaded 503 times
- Hier moet 'n pin wees.
- IMG_3135.JPG (176.7 KiB) Viewed 1709 times
