IFS Questions
Bazzer
Vehicle: Toyota Hilux 2700i DC 4x4, Toyota Hilux 3.0D4D 4x4 Auto
IFS Questions
Post by Bazzer »
My 2.7 went in to have the gearbox redone and a new clutch fitted. When I collected it I drove it home, about 2km. I went fishing up in Zambia for 12 days and on my return my wife had used the vehicle. She said that there is a noise coming from the right front wheel. When I checked I saw that the place that repaired the gearbox had locked the wheel hub on the right and my wife drove it like that for about 300km at speeds exceeding 100km/h. The vehicle was in 2H for all of the above. Will this have damaged anything?
Hilux 1
Vehicle: 2011 Raider 4x4 Double cab 4.0 V6
Real Name: Tertius
Club VHF Licence: HC137
Re: IFS Questions
Post by Hilux 1 »
I might be wrong, but i do not think so..... otherwize i would have stuffed mine up a long time ago. I keep mine locked for long periods of time(so 2 weeks at a time) espacially when i forget that it was locked.
Re: IFS Questions
Post by CasKru »
Nope... you should be fine. You don't have to unlock hubs as long as you drive in 2H. The reason the hubs are there is to minimise fuel consumption and vibrations by unlocking the hubs
Bazzer
Re: IFS Questions
Post by Bazzer »
Tx guys, next question. My clutch was replaced with the gearbox rebuild, now when it idles there is a whining noise coming from the clutch area which dissapears when I depress the clutch pedal. Should I take it back and have them look at it?
BlumTRD
Town: South Africa
Real Name: David
Re: IFS Questions
Post by BlumTRD »
Take it back .
Sounds like trow-out bearing .
Did the replace clutch plate or
Complete new kit .
Sent from my BlackBerry
Gideonvanzyl
Vehicle: Hilux 2.7 D/C 4x4
Real Name: Gideon
Re: IFS Questions
Post by Gideonvanzyl »
I have the same problem. I had my clutch also replaced recently. I asked about the noise when ideling and was told the 2.7's are known for their noisy gearboxes. I am not a mechanic so can't say. I know it did not make the noise before the clutch was replaced. However, the clutch performs well and I have no problem with performans.
I do however also have a sqeek sound when the vehicle has reached its operating tempreture. It's only when you depress the clutch that the sound goes away, but while ideling and driving this sqeek appears. I have sprayed q20 where the sound comes from but this only helps for a day or so. Don't know what else to do about it.
Below the gearbox on the left side is a rubberboot, this has to do with the clutch and you can partially remove it, its from here I get the annoying sqeek sound.
You don't perhaps have this problem also?
Toyota Hilux 2.7 Legend 35 (Bullnose) 2003 d/cab 4x4 with Cooper Discoverer AT 3's on with unichip and Powerflow exhaust. Name: Blouwillebees
4x4Maniac
Vehicle: 2011 Jeep Wrangler Rubicon Unlimited (JKU) 3.8 Auto
Real Name: Werner
Club VHF Licence: X120
Re: IFS Questions
Post by 4x4Maniac »
Hi Guys, I have the same squeeky noise from my clutch and when warmed up the noise is gone... i have also noted that when pressing on the clutch a little bit the noise is there again... Like as id the clutch plate isn't pushed back enough and squeeks on the pressure plate. From what I have heard, this isnt serious and secondly it is either the pilot bearing in the front of the gearbox or the fork that catches slightly. One day when I open the gearbox up, I'll have a good look to see what's up.
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Re: IFS Questions
Post by Polarbear2008 »
They call this the "sonbesie" noise (chickeda [spelling?]). It is caused by part in the cluch release mechanism and Toyota released a technical memo about this. They are supposed to treat this part with some sort of Lithium grease and the noise will be gone. It is not only on the 2.7 but the KZTE as well.
TSA seems not to know about this as by bakkie came back from a clutch replacement with the same noise and they also tried to tell me that it is like that!??!! Most of us would say release bearing or such, but some searching on the Net revealed this info.
Problem is that the gearbox needs to be removed for this lube to be done, so get it done sooner rather than later (labour!!) or learn to live with it.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
4x4Maniac
Real Name: Werner
Re: IFS Questions
Post by 4x4Maniac »
Thanks Theunis,
Thought it is something simple!... In my case I'm going to live with it, besides its not as bad as it seems...
So lesson learned, lube-up with some grease and don't get someone who works on race cars everyday to change your clutch, even if it is on the 23rd of December @ Zwartkops raceway.
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
IISARGE
Town: brackenhurst ext2
Vehicle: 2700i 4x2 hilux
Real Name: kenneth
Re: IFS Questions
Post by IISARGE »
good day bazzer when you did all on gearbox and clutch did they replace the thust bearing becuse it sounds like the thurst bearing to me when you push the clutch pedle in and out yes i agree with blumtrd :evil:
Piece of Cake...!
Spanky
Vehicle: 2011 Toyota Hilux D4-D 4x4 Dbl Cab
Real Name: Jan
Re: IFS Questions
Post by Spanky »
Shall we continue this old thread?
I have had this problem on my FJ62 cruiser since forever and it drove me crazy. I accepted it as part of an old vehicle and did the Q20 thing to get rid of my OCD issues every so often..
So the FJ62 is now gone and i aquired a d4-d - and voila! - the sonbesie/kriek has returned to haunt my issues agian :(
Sjoe Toyota!? 20 years later and still the same kriek?
ismail
Vehicle: Hilux '03 2700i SC 4x4
Real Name: Ismail
Re: IFS Questions
Post by ismail »
Classic we had 3 2.7s all with that whine. .....
I surf more than I work
