4Y Rev counter not working
- Ogre
- Vehicle: Toyota Hilux SFA
- Real Name: Ockert
Please help!
Where must I start looking for the problem, what's the color code of the rev counter wire or from where to where does the wires go. I'm close to start using alcohol or something.
Re: 4Y Rev counter not working
Not sure .... think it picks up the pulse from the coil. Might just be a loose wire.
- Town: Centurion
- Vehicle: 1988 SFA DC Lexus
- Real Name: Driko
Havent worked on a 4Y in ages but if i remember correctly it has a 2 pin plug on the distributor - one is ignition feed in to the system and other is Revcounter output , cannot for the life of me remember if it picks up Revcounter signal from the Igntition module or directly from coil though but the signal gets generated at the dissy so best bet would be to start testing from their , ideally with an oscilloscope to see if you receive any kind of signal going out to the revcounter
- Vehicle: 2008 Toyota Hilux 3.0D4d 4x4
- Real Name: Dewald
As far as I can recall there is a rev counter connection pipe that goes into the engine close to the spark plugs? I had that issues once after headgasket blew. and the guys forgot to attach this pipe.
- LouisZ
It is Black with red dots on. The on that is black with the red stripe in is the ignition.
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Do you have a points or electronic dissy?
- Donkey
- Club VHF Licence: X122
Proper term is Mothers Milk, which by the way you have not supposed to have stopped. Hope you are sorted outOgre wrote:Please help!
Tumelo Maketekete
- LouisZ
Ok the wiring for the Ignition(Black wire with red stripe) and the Revcounter(Black wire with red dots) will run just behind the battery towards the engine. Easy way to look is to id your watersensor on the head, look for the wire(sure the colour is yellow/green), this will run into the same harness as the ignition and rev counter harness.
- Ogre
- Real Name: Ockert
Thank you so much guys for all your help! I'll give it a shot this weekend. Regards.
- GeorgeJvR
- Town: Louis Trichardt
How do I test the re counter, I did get ign and earth what reading should P give? Or what should I give P on the cluster to trigger the revcounter
Kom wat wil ek bly 'n Bul!
Just P on the cluster ... maybe it helps!GeorgeJvR wrote:How do I test the re counter, I did get ign and earth what reading should P give? Or what should I give P on the cluster to trigger the revcounter
- Ogre
- Real Name: Ockert
Finally got my bakkies rev counter working.
- Real Name: Marnus
What was wrong? Perhaps someone else can gain from your experience.
- Ogre
- Real Name: Ockert
It was the wires LouisZ said I must look for, found the wire and plugged it in and it works. Thanks again guys.
