Help needed - Removing steering box from SFA
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
- Club VHF Licence: X248
Hi
Martin explained that I would require a special (and expensive) tool/puller to remove the power steering box from the SFA and the drag link that is attached to it.
Also, the bakkie is in my driveway and cannot turn at all, so I cannot tow it anywhere..
Anyone has such a tool, know where I can get.hire one, and can maybe help me remove the bugger?
Regards
Otto
Regards
Otto
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Re: Help needed - Removing steering box from SFA
Waar bly jy?
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
Hi Thabo
Roodekrans, West Rand near Kugersdorp...
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Nee, ek weet waar om dit bekostigbaar in Pretoria te kry.
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
Hulp sal waardeer word....
Praat jy nou van die tool, of van 'n ander steering box?
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Tool
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
The drag link is easy to remove, just remove the cotter pin and then unscrew the threaded cap until it is loose enough to come off the pitman arm from the steering box. removing the pitman arm from the steering box is usually where the issues come in. However you may be able to remove the steering box from the column and then take it as a unit to be fixed
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
niclemaitre wrote:The drag link is easy to remove, just remove the cotter pin and then unscrew the threaded cap until it is loose enough to come off the pitman arm from the steering box. removing the pitman arm from the steering box is usually where the issues come in. However you may be able to remove the steering box from the column and then take it as a unit to be fixed
Thx, will try it out...
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
- Froll
- Town: Vioolsdrift
- Real Name: Roger
- Club VHF Licence: N/A
Use a 4 lbw hammer and hit it on the side a few times. this should loosen the taper. Even with a puller you have to still hit it some times.
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
i wouldn't hit the pitman arm while the box is still in, the arm will never come out like that and you just damage the box even more.Froll wrote:Use a 4 lbw hammer and hit it on the side a few times. this should loosen the taper. Even with a puller you have to still hit it some times.
you should be able to get the box out with the pitman arm on, once its out the put it on an anvil or big piece of metal and then hit it with a 4lbs hammer
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
Thx. I'll try to get it off this weekend and send it in to check whether it can be fixed/overhauled...
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
- Town: Springs
- Vehicle: '2013 2,5 D4D D/C 4X4 Hilux
- Real Name: Jan
Otto laat weet wat het gebeur en waar jy hom herstel het aub. My steeringbox lek olie en wil dit ook graag laat reg maak.
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
Quick update. Tried to remove the box on Saturday...no luck.
The Aircon pump is in the way and the is very little space to work with in there...so I was not up for removing the aircon pump as well, and will have to send the bakkie in...
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
- mcw
- Town: krugersdorp
- Real Name: Martin
- Club VHF Licence: X100
Hi Otto
Het al die bakkie ingevat om te laat regmaak
Martin
Martin
