Speed limiter removal
- Town: Bronkhorstspruit
- Vehicle: Toyota Fortuner
- Real Name: Jan
Morning guys
Do any of you perhaps know how to remove the speed limiter on a 4.0 litre V6 Hilux?
Which wires to cut etc?
Thanks in advance.
Thanks in advance.
Re: Speed limiter removal
I wonder if that bakkie has a "speed limiter" as such. The maximum RPM is probably limited by the ECU so I don't think it is a question of cutting some wires. I also doubt that you would be able to rev it to the limiter in top gear unless the engine is "suped up a bit". It would be interesting to know.
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Ek dink ook soDie$eL wrote:As far as I know its controlled by the ECU
- Real Name: Jan
Jy kan duidelik voel hoe hy uitsny en dan weer kole gooi....
- Real Name: Jan
Daai limiter moet uit.....
- Town: Centurion Gauteng
- Vehicle: Mazda Rustler 16v
- Real Name: Jan
Dit is die speedsignal na die ECU vanaf die cluster maar die tyres gaan nie van daai soort spoed hou nie en as een bars en ondersoek deur die assuransie gedoen word gaan die hel los wees
Jan,
Met 'n regte chip kan dit gedoen word, maar soos ander Jan se, dink jy dis wys?
- Real Name: Jan
Dis nie my voertuig nie. Die eienaar wil dit uithe. Ek is heel tevrede met my kar se spoed.
- Town: Centurion
- Vehicle: SFA Hilux
- Real Name: Jacques
Vir interessantheid, op watter spoed skop die limiter in?
Ek het een slag 'n 3.0 d4d ge overtake. Die p03ph01 trek toe d005 en versnel. Ek kon met my 320d eers op 190km/h verby kom.
wees maar bly hy het nie n 3,2 DIESEL Ranger gery nie - na Kosie Swanepoel dit gechip het nie ... 200 op die GPS !!Jacques T wrote:Vir interessantheid, op watter spoed skop die limiter in?
DIT is nou bollie soek !
- Real Name: Jan
Op speedo 200.
- Vehicle: Lumina
- Real Name: Nicholas
I know my 2.7 Vigo hits the rev limiter at around 200km/h(on the clocks) in 5th. Had the limiter on my Lumina moved to 500km/h, this is done via the ECU, obviously can't do that speed but let's just say she is good for 300km/h.
Looked at having my 2.7 tuned and they can't do it via the ECU and have to use a piggy back or standalone system, so I am guessing you would need at least a piggy back chip to up the limiter on both revs and speedo?
On what planet are you living???Moonunit wrote:I know my 2.7 Vigo hits the rev limiter at around 200km/h(on the clocks) in 5th. Had the limiter on my Lumina moved to 500km/h, this is done via the ECU, obviously can't do that speed but let's just say she is good for 300km/h.
I could never get a 2.7 past 160 - and believe me I tried all ways and fashions!!!
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
My 2.7 (IFS) the limiter kick in at just over 175 km/h. Happened a few times when overtaking.I could never get a 2.7 past 160 - and believe me I tried all ways and fashions!!!
The first time I crapped myself.Thought I popped the motor
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Die scaryste oomblik vir my was toe ek 210 met n SFA op 35" tyres gedoen het, maar ek het die Golf GTI gelos.
Ek het die 7mgte daai selfde dag uitgehaal en verkoop.
aev@iburst.co.za
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
ek haal maklik op gelyk pad 160 en dan is voet nie eens reg plat nie, maar dan is die perre DORSThabogrobler wrote:On what planet are you living???Moonunit wrote:I know my 2.7 Vigo hits the rev limiter at around 200km/h(on the clocks) in 5th. Had the limiter on my Lumina moved to 500km/h, this is done via the ECU, obviously can't do that speed but let's just say she is good for 300km/h.
klink my julle moet liewer n drop kit en low profile 20'' spinners posit ....
die Hilux hy is gemaak vir die kort stokkie en die gravel pad, en die low speed ....
- Hoppy
maar dis lekker om n plat kar skrik te maak
aev@iburst.co.za
hehehehe ....
praat nou die dag met JohanT (daar langs die spoorlyn in Stikland) ....
wil n 3 reeks mos toe windgat raak .... nie geweet dat Johan se waentjie SOVEEL perde onder die bonnet het nie .... EN Johan se waentjie hanteer toe daai speedwal voor Eskom so bietjie beter as n 3-reeks op spoed ..... DAAI laatjie gaan nie gou weer n WA aanvat nie ....
My D4D hol lat hy skeit. Tot jy moet oorsit 2de rat toe. My scarieste oomblik was toe daai Amarok onder die D4D uit trek terwyl ek met die notchy Toyota ratkas sukkel om 2de te hak. Hy is beslis nie n drag queen nie. Maar hy loop sy klok vol teen n moerze steil bult af met die wind van agter.
- 4x4BEES
- Vehicle: Hilux 4.0V6
- Real Name: Kevin
mmm... Driver error??ThysdJ wrote:My D4D hol lat hy skeit. Tot jy moet oorsit 2de rat toe. My scarieste oomblik was toe daai Amarok onder die D4D uit trek terwyl ek met die notchy Toyota ratkas sukkel om 2de te hak. Hy is beslis nie n drag queen nie. Maar hy loop sy klok vol teen n moerze steil bult af met die wind van agter.
2 keer in n ry? Toe hou ek maar op en maak of ek n hammie getrek het.
