Diesel fuel filters
- honn1
- Town: Umhlanga
- Vehicle: 2010 Hilux D/C D4D
- Real Name: Robert
Diesel fuel filters
Just had bad news that my injector pump is badly damaged due to loads of sludge and dirt from diesel fuel tank and fuel line. It an old 1999 Hilux that never given any trouble and got 420000 on clock. Unfortunately had to have tank flushed, pump and injectors completely overhauled. Been told to fit an extra fuel filter in line. Does anyone know what is the best diesel fuel filter to get and from where?
- Kaaskrul
- Town: Port Elizabeth
- Vehicle: 2018 Hilux X-Cab 4x4 Dakar
- Real Name: Pierre
Re: Diesel fuel filters
Racor.
But expensive.
But expensive.
- honn1
- Town: Umhlanga
- Real Name: Robert
Thanks will check them out. Worth paying if it's gonna save me the cost I just had to spend.
Donaldson
- hansman
- Town: pretoria
- Vehicle: hilux sfa
- Real Name: hans
Racor water separator and GOOD filter in one cost a bit but is still cheaper than injector pump overhaul.
Hansman&Vaaltyn
Hansman&Vaaltyn
- honn1
- Town: Umhlanga
- Real Name: Robert
Anyone know where I can buy a Donaldson 4x4 heavy duty filter kit from? P903316. It's a new kit available for 4x4's.
Donaldson has branches all over SA :)
http://www.donaldson.co.za/" onclick="window.open(this.href);return false;
- honn1
- Town: Umhlanga
- Real Name: Robert
Donaldson don't have the New P903316 kits in South Africa so going with the Racor Kit. Comes with mounting plate, all hardware, 2 filters(1 spare). Is expensive at R2120 but gotta do it. Anyone know where i can get it cheaper?
- Town: Centurion
- Vehicle: 89 SFA 4x4, D4D 3l DC 4x4
- Real Name: Coenie
Hi Robert,
In Pta there is a kit available I think around R1800 for Donaldson with water separator and filters 2 micron. The okes behind the counter say it is the D4D kit, so I would think that it will work for you.
If you need help I can go and source it for you.
Regards,
Coenie
Regards,
Coenie
- honn1
- Town: Umhlanga
- Real Name: Robert
Thanks very much. I got the Racor Kit. Same price as Donaldson. Also 2 Micron. The Donaldson agents by me told me they don't do a filter for my bakkie. Think they were just no prepared to even help.
- Real Name: Marnus
Waar in Pretoria?Vrystaat wrote:Hi Robert,
Regards,
Coenie
Dankie
- Reinart21
- Town: Secunda
- Vehicle: Toyota Hilux 3.0 D4D 4X4 D/C 2011 - ONCA Bullbar Dastek Unichip 76MM S/S Freeflow Leveling Kit. Hilux SFA '97 D/C OME Suspension extra long range tank', V8 coming soon!
- Real Name: Reinart
+1Mars wrote:Waar in Pretoria?Vrystaat wrote:Hi Robert,
Regards,
Coenie
Dankie
- Town: Centurion
- Real Name: Coenie
Hi julle by PTS Filters Gezina 012 335 9127.
Ek het al 5 op gesit. Baie vinnig en geen probleme met toevoer of so nie....net gemoedsrus.
Ek het al in die glasie vuilgoed gesien wat die Donaldson gekeer het wat die OEM gemis het. En dit was deur Toyota vervang op die laaste diens.....
- Real Name: Marnus
Dankie Coenie!
- pietdevs
- Town: Mosselbay
Model of part nr asb Coenie?
- Real Name: Marnus
Volgens Coenie noem hulle dit die D4D Kit.
- Town: Centurion
- Real Name: Coenie
Hi,
Ja jy kan net vra vir die d4d kit.
Groete
Groete
- Vehicle: 2wd pre runner hilux vigo
- Real Name: David
Hi guys , I fitted the racor fuel water separator and also bought the Donaldson D4-D filter kit for my next (out of warranty) service.
Donaldson d4d PartNo K663
regards Davie
regards Davie
- Real Name: David
K6632
