Gearmax/Local diff torque wrench specs?
IndianaJones7746
Town: Citrusdal
Vehicle: 84 SFA Hilux
Real Name: Ben
Wed Jul 01, 2015 9:54 am
Hi
Does anyone have torque wrench specs for the local Gearmax differentials?
I would assume the torque specs for all M75, M80/82, etc would be the same?
Torque specs for the bearing cap bolts, crownwheel to differential case bolts, etc
What should the pre-load be on the pinion bearings?
Regards
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Tue Jul 07, 2015 11:00 am
Does no one know what the pre-load or backlash or pinion depth should be?
vanthev8man
Town: wellington
Vehicle: 81 hilux 350,80 vx landcruiser,650 bombardier.
Real Name: martin
Tue Jul 07, 2015 1:11 pm
ben,
you can have all the specs,but there has to be some streetwise knolledge to assemble correctly!
just my 2c...
hilux sfa -the only real 4x4!
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Tue Jul 07, 2015 1:26 pm
vanthev8man wrote:you can have all the specs,but there has to be some streetwise knolledge to assemble correctly!
Dankie Martin, weet dit...
vanthev8man
Town: wellington
Real Name: martin
Tue Jul 07, 2015 3:42 pm
ok,
backlash for m75 to m82 = 0.12 to 0.18mm
pinion preload = ongeveer 20pond.(ek voel hom met die hand)
carrier bolts = 75 nm.
crownwheel bolts = 105nm
hoop dit help?
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Tue Jul 07, 2015 8:28 pm
Baie dankie Martin, sal definitief help, en ek glo baie ander ook.
Tim86
Real Name: Tim
Mon May 15, 2017 2:03 pm
Hi vanthev8man
Please tell me from where you attained this information? I have searched high and low, tried the agents, phoned Gearmax themselves and it seems near impossible to get hold of a workshop manual for the local diff.
Do you have a copy that you would possibly share? I need to perform an overhaul which would be problematic without the necessary info...
Thanks!
    Users browsing this forum: Bing [Bot], The Legend
