Hazardous problem on 76 Cruiser
Baasvark
Town: Virginia
Real Name: Shane
Sun Oct 02, 2016 3:30 pm
Howzit guys,
Hope someone can help....
I have a 76 Troopy. Hazards work until trailer is hitched and then nothing . No Hazards. I had all the tail lights connected by our local wiring experts. It comes out with only the back bumper lights working (dunnno why!). The actual lights fitted to the body (rear) come unconnected...
Anyhow, if I put in bulbs in both of the indicator fittings, the hazards die... We tried a new flicjer unit but to no avail.
I'm thinking that the actual bulbs might be too big for the specific vehicle? The vehicle was purchased used so the previous owner coyld have replaced with incorrect bulbs at some time....
Any ideas?
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Sun Oct 02, 2016 3:51 pm
Replace your bulbs with led bulbs which draw less amps and see if it works.
Sun Oct 02, 2016 6:57 pm
Yep, as Dawie says. Otherwise, you will need to fit a relay to drive the trailer lights or do it electronically - not sure if an aftermarket electronic relay can be bought though, I would imagine it should be.
Baasvark
Town: Virginia
Real Name: Shane
Sun Oct 02, 2016 8:30 pm
Thanks! Will give it a go!!!
Knuppel
Town: White River
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Mon Oct 03, 2016 9:25 am
Common problem with newer cruisers, The LED option will solve your problem.
Dont fit LED to all indicator fittings otherwise the indicator unit does not have enough resistance and will then start blinking at triple speed.
If you have bullbar with extra lights then it also compounds the problem.
In SA All vehicles with spare wheels on the back need to have lights on the bumper. something to do with the angle you must be able to see both tail lights.
You can have the original lights connected but you need to get the right light fittings as the one fitted now are siply blanked off. Some people get very invative and have made them work.
In my case the original lights were working but had to fit the lower ones to be legal on my older model Cruiser
Image Link Broken
Image Link Broken
Baasvark
Town: Virginia
Real Name: Shane
Mon Oct 03, 2016 10:07 pm
Knuppel wrote:Common problem with newer cruisers, The LED option will solve your problem.
Image Link Broken
Knuppel where did you get the LED's?
My local yocals can't seem to help me....(Diesel Electric!)
Baasvark
Town: Virginia
Real Name: Shane
Mon Oct 03, 2016 10:08 pm
Why can't I see your photo?
The Legend
Real Name: Dawie
Tue Oct 04, 2016 4:14 am
Shane you can order your LED bulbs from 4x4 Direct.
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Tue Oct 04, 2016 6:24 am
Also, check the earth on the trailer plug.
My trailer deactivated the ABS! which is actually a good thing. Was also a earth problem.
Johan Kriel
Prado
Knuppel
Town: White River
Real Name: Marius
Tue Oct 04, 2016 8:48 am
Baasvark wrote:Why can't I see your photo?
Can you see this?
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Tue Oct 04, 2016 8:51 am
Baasvark wrote: Knuppel where did you get the LED's?
Those lights in there are not LED, normal incandescent globes, only the number plate lights have LED
But if you want LEDS then get from 4X4 Direct, I got my others from them
