Right people.
So the Hilux started by cutting out for a few seconds and then driving fine for a couple of hundred Kilos.
I then suspected bad electronic connections, Checked all, l replaced a suspected bad earth. all went well for some weeks.
Went to Gauteng on Sunday for a funeral on Monday,
When i saw the Dark clouds yesterday decided to leave immediately for Louis Trichardt in stead of Thuesday morning at 03:00 Am
Ended up driving in a Massive Thunder storm and small heal
140Km South of Polokwane She dies on me, Just cuts out an no luck getting the van running again.
If i Pump the manual pump she fires up for a second or two then dies out, even after i bypassed the UNICHIP no Success, got towed to Polokwane by a FORD
Any Suggestions where to start looking will go collect the Hilux later this week.
3.0 D4D trouble shooting
- GeorgeJvR
- Town: Louis Trichardt
Kom wat wil ek bly 'n Bul!
- Real Name: Marnus
Re: 3.0 D4D trouble shooting
Definitely a diesel supply problem. My brothers D4D had a similar problem although not to the point where it stopped altogether. Did you notice more smoking of late?
What he did was to replace the whole diesel filter/bleeding pump unit (the price was surprisingly low from Toyota but I cannot remember how much now) and the problem was sorted as it was staring to loose pressure there for some reason. It would also start and run better for a short while if pumped.
Hope it is as simple as that.
- Real Name: Marnus
Another suggestion is to have it scanned for error codes as this can quickly point you in the right direction.
- GeorgeJvR
Thanks guys, as for the smoking no problems there.
- GeorgeJvR
Hi Guys
Turns out that someone pinched the power supply ( behind the cubbyhole close to the chip's connections) to the Injector module, sitting against the firewall in the engine bay passenger side.
This caused a spike that blew the module
at least she is running again.
If i do fit the chip again it will be in Pretoria / JHB
