Hilux standard tyre sizes?
Jaco Versfeld
Town: Western Cape
Vehicle: Moms Taxi, 2001 Prado (The Barbie Cruiser)) Sold - Mufasa: '86 Hilux DC 4Y EFI
Real Name: Jaco
Club VHF Licence: X69
Fri Oct 17, 2008 11:45 am
What is the standard tyre size for the SFA Hilux. 87 - 94 (4Y engine)?
Does the imperial parameters work the same as the ISO standard, i.e. 265/70/R15 -> 265 the width of the tyre, 70 - the wall height, (70 the percent of the width of the tyre), R15 - 15 Inch Rim?
Kind Regards,
Jaco
Dadz Toy BFI
Fri Oct 17, 2008 11:53 am
Jaco
Try using the Search option in the Menu, you'll find a veritable gold-mine of of Techno Info that's been posted over the last year and a bit :P
(you just have to dig a bit) :wink:
ThysdJ
Club VHF Licence: HC102
Fri Oct 17, 2008 12:15 pm
Kyk bietjie hier Jaco.. Download die PDF file :twisted: :twisted: :twisted:
viewtopic.php?f=44&t=2109&p=21207
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Fri Oct 17, 2008 5:01 pm
Jaco Versfeld wrote:What is the standard tyre size for the SFA Hilux. 87 - 94 (4Y engine)?
Can be a 245x75R15 or a 215R15 IIRC (Marie Biscuit)
Jaco Versfeld wrote: Does the imperial parameters work the same as the ISO standard, i.e. 265/70/R15 -> 265 the width of the tyre, 70 - the wall height, (70 the percent of the width of the tyre), R15 - 15 Inch Rim?
Kind Regards,
Jaco
No imperial is in the case of a tyre actually a better descriptive method of displaying tyre sizes (no % of width cheetah-sh..) A 31x1.05x15 means the diameter of the rim is 15inches the diameter of the tyre is 31 inches and the tyre is 10.5 inches wide. To determine the sidewall is easy it is (31-15) /2 = 8 inches.
See this tyre size calculator http://www.dakota-truck.net/TIRECALC/tirecalc.html
Jaco Versfeld
Town: Western Cape
Real Name: Jaco
Sat Oct 18, 2008 6:39 am
Thanks a lot for the info.
Jaco
Spook
Town: Swakopmund
Vehicle: Hilux 4Y 4x4 s/cab, 3.0 D-4D
Real Name: Ockie
Thu Oct 23, 2008 11:49 am
Die ou harde tyres van die Hilux was die split rims gewees wat 'n 7x16" of 8x16" bande was. As jy dit vervang het met radials, dan was dit met 'n 31x10.5x15 band gewees wat, alhoewel net 'n 15" band is sy sidewalls hoer en maak sy omtrek dit dieselfde omtrek as die vir 'n 16" band.
nickicru
Vehicle: Colt 2.8 td
Real Name: Nick
Tue Oct 06, 2009 1:22 pm
HI All,
I need to replae my Hilux Tyres and not sure the size. I can get 245/75/15 Goodyear Wranglers AT/SA for a good price but think it's to narrow.
If the standard is 31 x 10.5 it converts to 280/75/15 if my convertion table s correct.
Can i fit the 245 or is that not an option?
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
Club VHF Licence: X248
Tue Oct 06, 2009 1:32 pm
I have 245/75/15 Firestone ATX on my lux...no probs.
:thumbup:
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
2.8 d/cab SFA
Vehicle: Yamaha R1
Real Name: John
Tue Oct 06, 2009 1:55 pm
had 245 atx, no touch, bfg muds, 31 not touch
John
nickicru
Real Name: Nick
Tue Oct 06, 2009 2:19 pm
Thanks, Will get them. Can get them for around R900 each.
I know in the "WEG" they said the new Hilux (my model is 2005) over turn (rol) and it might have to do with the tyre size. Don’t know how true that is but rather on the safe side than sorry.
louis fourie
Club VHF Licence: X101
Thu Oct 08, 2009 6:52 pm
Hallo julle Hilux manne - Ek het huidiglik 30X9.5XR15 Bridstone Duelers op my bakkie. Kan ek 31X10.5XR15 op sit sonder dat dit nodig is om modifikasies te doen?
Groete
Thabogrobler
Club VHF Licence: x223
Fri Oct 09, 2009 1:32 am
louis fourie wrote:Hallo julle Hilux manne - Ek het huidiglik 30X9.5XR15 Bridstone Duelers op my bakkie. Kan ek 31X10.5XR15 op sit sonder dat dit nodig is om modifikasies te doen?
Groete
Jip, geen probleem.
louis fourie
Sun Oct 11, 2009 7:19 am
Hallo
Sal die 31X10.5X15 bande pas op die 30X9.5X15 rims?
Groete
Louis
ThysdJ
Sun Oct 11, 2009 8:22 am
Louis ... Laat waai maar... daai rims kan 33"s ook vat... :thumbup: :thumbup:
TJV
Vehicle: 3.0 liter D4D Fortuner,, Roof rack and VHF radio
Real Name: Theunis
Club VHF Licence: X 110
Sun Oct 11, 2009 11:42 am
Louis
Ek het van 245-15 na 31/10.5 - 15 toe oorgegaan 'n paar jaar terug op my 2.7 2000 model wat standaard is. Ek moes 'n bietjie aan die stuurstoppe stel en daar is 'n marginale intervlak tussen die regter kantste band en die windskerm wasser waterbottel. Ek het ook nie meer treeplanke nie en enkelkajuit moddervlappe voor op wat in 'n sekere kondisie so effens raak. Het nou ongeveer 60k so gedoen en geen skade is nog op die plastiek dele nie.
Groete
TJV
louis fourie
Sun Oct 11, 2009 2:04 pm
Theunis, waar sit die stuurstoppe, en met hoeveel het jy dit gestel? Raak die regter wiel enigsins aan die waterbottel, of het die stuurstop stelling gehelp?
Groete
Louis
TJV
Real Name: Theunis
Sun Oct 11, 2009 9:23 pm
Louis
Die meganiese stoppe sit aan die voor en agterkant van die askop wat kan draai. Jy sal sien daar is sulke halfronde glystroke op die onderste wensbeen waarteen die stoppe druk as jy skerp draai. Wat ek gedoen het is om die stoppe te stel sodat daar nog so 5mm oor is voordat die band iets raak. As dit nog raak moet jy dit verder wegstel aangesien daar redelikke beweging en kragte is tydens dinamiese beweging van die wiel. Onthou net om die sluitmoere weer vas te maak as jy klaar is.
Die band vang nog teen die waterbottel maar daar is nog nie skade nie. Dit is egter ook net wanneer daar skerp na links gedraai word.
Groete
Theunis
RSCHEEPERS
Town: MOSSEL BAY
Vehicle: 2003 TOYOTA HILUX RAIDER D/C
Real Name: RINUS
Fri Jul 06, 2018 11:47 pm
Naandsê Hilux-manne,
Ek het 'n 2003 Toyota Hilux Raider D/C. Op die oomblik het ek 245/75R15 Dunlop A/T-bande op.
Tussen die 31x10.5R15 en 30x9.50R15 BFGoodrich All-Terrain KO2-bande, watter een sal julle aanbeveel en hoekom?
Dankie by voorbaat.
Groete
Rinus
Harold
Town: Howick
Vehicle: 1998 Hi-lux 2,4 S/cab (p); 1997 Hi-lux 2,4 D/cab (p)
Real Name: Harold
Sat Jul 07, 2018 5:40 am
Stanadrd size for 1980 to '88 SFS Hilux's was 215x15; the earlier HiLux's were 16" split rims
Harold (Greytown, KZN)
Chase86
Vehicle: 90 Hilux SFA 4Y DC
Real Name: Chad
Thu Jul 12, 2018 9:09 pm
Hi Harold, I have a 90 SFA DC, I fitted 215 75 r15, but they look so small! haha. I've heard the 90's came with 225's.
Has anyone looked in an owners manual to see what is spec'd by Toyota?
Thanks a mil!!
Hilux SFA 4Y '90 DC
    Users browsing this forum: Baidu [Spider], Family_Dog
